OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Sep 6, 2018 at 10:41 AM
    #361
    boodjohn
    boodjohn Well-Known Member
    If you are going to compress air (millions of molecules), the probability of molecules bouncing off each other is 100%. In a confined and restricted space, when you to force air (at room temp) into it, they bounce off each other more frequently causing heat/dissipation. If you were to fill the tanks with cooler/cold air, you can fit more air into the tanks because the air molecules are more less likely to be moving.
    What the turbo does is compresses the air, then runs it thru the intercooler so that these molecules are compact and DENSE. It flows to the engine where they inject fuel with pressurized/cool air which will cause more efficient combustion. Running cooler air means the housing for the pistons wont be as hot. Therefore, your engine is running cooler and more efficient.
  2. Sep 6, 2018 at 10:44 AM
    #362
    SContiVT
    SContiVT Back in a Toyota
    Central Vermont
    2010 Tundra Rk Wr/2023 WRX/2023 Ford Exp
    Unless you are running an intercooler water sprayer, the air will not be colder than ambient, which is what goes into the cylinders with NA.
  3. Sep 6, 2018 at 10:52 AM
    #363
    PatricNV
    PatricNV Well-Known Member
    Patric
    Reno, NV
    2018 Cement TRD OR Access Cab
    OV Tune Skinny tires Trail Gear Sliders
    I don't know anything about how a turbo works but would it delete any emissions stuff. I looked up Nevada and this is all I could find. The smog guy opens the hood and closes it before connecting the OBD plugin to his machine. I am guessing he is looking for modifications that might delete any smog devices. From Matt's pics so far it doesn't look like it will be super obvious there is a turbo?? Any speculation on whether this would fail on the scan only? I might stop by one of these little smog huts and ask the guy. I'll report back if I get any details.
    "Nevada uses On-Board Diagnostics (OBDII) Testing for 1996 and newer vehicles. The operator will connect an analyzer to the OBD computer in your vehicle. Data from your vehicle will indicate whether its emissions systems are operating properly and within emissions limits."
  4. Sep 6, 2018 at 10:52 AM
    #364
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    No, it wont be cooler than ambient, but that's not what is being discussed. If I'm not mistaken, people were saying that an intercooler essentially serves no purpose. And that isn't true.
    You have your ambient air temp. Turbo makes it hot. Intercooler cools it down (although not as cool as ambient temp). It enters engine.
    This is why the hotter the ambient temp, the hotter your BATs will be
    Thaitoy, xxTacocaTxx, Chipi3s and 3 others like this.
  5. Sep 6, 2018 at 10:53 AM
    #365
    boodjohn
    I like to think of an intercooler as a A/C machine on steroids. Which mains purpose is to provide cooler temperatured air molecules than at ambient temp. If the pressurized air exiting the intercooler is Ambient temperature, then the intercooler is not doing its job. Plain and simple. You are more likely going to run into engine failure due to high temps, pistons cracking, housing cracking over the course of running your vehicle.
    Intercooler water sprayer is to help adjust your intercooler temperature "externally." If your intercooler is running above manufacturer's guidelines, then yes, a intercooler sprayer may be helper. You probably be running your turbos too high liek high PSI or some shit like that.
    Be careful.
  6. Sep 6, 2018 at 10:55 AM
    #366
    Double Phister
    Double Phister Punch it Chewie
    Sacramento, CA
    2017 DCSB TRD OR [SOLD]
  7. Sep 6, 2018 at 10:57 AM
    #367
    SContiVT
    Central Vermont
    I was specifically responding to the comment on the air cooling down the cylinders, that's not where the efficiency will be gained.
  8. Sep 6, 2018 at 10:58 AM
    #368
    boodjohn
    I would like to hear how it works then.
    Open ears.
    xxTacocaTxx likes this.
  9. Sep 6, 2018 at 11:02 AM
    #369
    SContiVT
    Central Vermont
  10. Sep 6, 2018 at 11:02 AM
    #370
    Double Phister
    Sacramento, CA
    Compressor side of turbo takes ambient air and compresses it. During compression air is more dense and also hotter.
    Air is passed through intercooler to reduce temps. Temps will still be above ambient.
    Compressed air leaving the intercooler enters the engine. It's already hotter than it would be without a turbo. This dense charge air is then ignited with more fuel than a non-turbo would use because there is more air. The increase air and fuel make for an even hotter combustion event.
    TL:DR. Forced induction engines run hotter.
    NC_Pinz, SC4333, xxTacocaTxx and 4 others like this.
  11. Sep 6, 2018 at 11:13 AM
    #371
    StevoNB
    StevoNB Well-Known Member
    NB, Canada
    2020 DCSB TRD Sport 6MT
    In an air to air intercooler, it’s not possible for the air exiting the intercooler to be lower than ambient temperature, unless using another external form of cooling at the same time. It’s also nothing like an A/C system, since there is no use of refrigerant for cooling.
    Kevindust, Chipi3s and SContiVT like this.
  12. Sep 6, 2018 at 11:13 AM
    #372
    boodjohn
    Wait, why would air temps still be above ambient temperature after the intercooler?
    I'll take a look at the video soon but here was my understanding.
    exhaust from engine spools turbo takes in air from outside and compresses it (now hotter)
    Hot air runs thru intercooler (now cool air)
    Cool air enters engine for combustion which exits as fumes.
    Fumes then help spool turbo once more while leaving exhaust pipes.
  13. Sep 6, 2018 at 11:13 AM
    #373
    Double Phister
    Sacramento, CA
  14. Sep 6, 2018 at 11:14 AM
    #374
    SContiVT
    Central Vermont
    Ambient air is the temperature outside of air intake, or pre-charge air.
    Mike O likes this.
  15. Sep 6, 2018 at 11:15 AM
    #375
    StevoNB
    NB, Canada
    That is how it works. If ambient air is 75 degrees Fahrenheit, then the intercooler cannot cool the air from the turbo below 75F.
    hbaade, xxTacocaTxx and SContiVT like this.
  16. Sep 6, 2018 at 11:16 AM
    #376
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    :fistbump:
  17. Sep 6, 2018 at 11:18 AM
    #377
    Double Phister
    Sacramento, CA
    Intercooler can't get the temps lower than ambient. It's all about heat transfer. If you leave a hot cup of coffee on your desk it will not get colder than the room it's in.
  18. Sep 6, 2018 at 11:19 AM
    #378
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    you're correct, but the intercooler air is not cooler than ambient, only cooler than it was once compressed.
    xxTacocaTxx and mZiggy like this.
  19. Sep 6, 2018 at 11:19 AM
    #379
    whitedlite
    USA!
    3RD Gen TRD 4WD
    you mention nothing of the taste. it's disgusting.
    BEAR_KNIFE_FIGHT and SContiVT like this.
  20. Sep 6, 2018 at 11:20 AM
    #380
    SContiVT
    Central Vermont
    :amen::rofl::fistbump:
Thread Status:
