OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Sep 2, 2018 at 3:46 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    I would think with the proper tune 450SHP would be a reasonable expectation. Twin turbos are going to take forever to spool. Twins may not be needed, plenty of boost and faster spool time with single turbo with a intercooler. Still would need 5,000RPM+ for maximum HP.
    No grill obstructions of any kind when running a intercooler.
    johnnyblender likes this.
  2. Sep 2, 2018 at 3:58 PM
    ajsabra
    ajsabra Fully locked 3rd gen
    Sin city
    2016 Tacoma DCSB 4X4 Manual
    Front suspension : Extended travel Kings with Total Chaos UCAS Rear suspension : Deaver progressive AAL w/out overload & Kings Rims : SCS SR8 17" Tires : Bfg KO2s 285/70/R17 ARB Compressor ARB Lockers front and rear with 4.88 gears Nitro 4.88 Gears TRD Pro Grill, and fogs Headlight BHLM Rigid Radiance 32 stealth mounted.
    So @OVTune cats removed..... Will I still be able to pass smog, and not have a CEL?
    hr206 likes this.
  3. Sep 2, 2018 at 4:02 PM
    here4cake
    here4cake Well-Known Member
    Depends on how it's set up. On the BMW 335i I had, first turbo was fully spun up at 1800RPM. Second turbo kicked in later. There was zero lag feel.
  4. Sep 2, 2018 at 4:05 PM
    TelosHedge
    TelosHedge tiny moron
    Central NC
    18 Inferno Sport DCSB 4x2
    Yup. As Mat has mentioned, looks like we'll have different turbo options depending on the tq curve wanted.
  5. Sep 2, 2018 at 4:11 PM
    robssol
    Rob
    S. Wisconsin
    NO! and NO!
    Trouble_The_Tacoma likes this.
  6. Sep 2, 2018 at 4:21 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Normally a twin turbo v6 would have some lag. Not an issue in this case for a few reasons.
    The engine uses a single exhaust port for all cylinders on each bank. No individual runner manifolds. 3 cylinders > 1 exit > right to the turbo.
    We also have an option for an extremely fast spooling 13T.
    I expect, when all said and done this kit will be very popular and will remain competitive in price to any supercharger while blowing away the superchargers power.
    For example, the 4.0L engine with the TRD SC, using smaller pulleys put down *around* 350whp or less.
    Our base 13T kit beats that number.
  7. Sep 2, 2018 at 4:24 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Exactly what I’m thinking. The way this thread is going, it’s going to look like these kits will be flying off the shelves. But how many will really be buying them
  8. Sep 2, 2018 at 4:30 PM
    KkelX4
    KkelX4 Well-Known Member
    2017 Tacoma TRD OR
    RTT Rack
    That's a different setup. Compound turbos. Works great for inline engine configurations.
    With twin turbos on a V engine generally you'll see two identical turbos for pressure balance reasons. Unless your joining both exhaust exits prior to entering the turbo. But on the Tacoma that would put the turbos far down and underneath the truck. Not a good position for an off-road vehicle. It would also have noticeable lag over a twin system on this application.
    On a different note,
    I was fjording a couple rivers this weekend, and I had water higher than the turbo location in that photo. Would that be a problem for this setup @OVTune ?
    robssol likes this.
  9. Sep 2, 2018 at 4:34 PM
    OVTune
    OVTune
    I will need someone with a MT interested in testing, but that's later.
  10. Sep 2, 2018 at 4:35 PM
    KkelX4
    2017 Tacoma TRD OR
    RTT Rack
    Good, awesome. It was just a thought I know it's a sealed system, and am familiar with turbos but not overly familiar with how they perform in adverse conditions.
  11. Sep 2, 2018 at 4:35 PM
    Whitetail Assassin
    Whitetail Assassin Well-Known Member
    Tedric
    West Virginia
    2024 Underground TRD Off-Road 6 Speed MT
    Dibs! I’m in VA keep me posted. I have a manual.
  12. Sep 2, 2018 at 4:35 PM
    Weirich
    Weirich Drunk_taco
    Travis
    2016 Tacoma access cab TRD Offroad
    OvTuned 4.88 R&P Hypertech speedometer calibrator Rough country 6" lift Toyo open country 285/75R17(old) Cooper STT Pro 315/70r17 Archive garage shackle flip Tough country uni ball uppers Icon 2.5 6" front coil overs Icon 2.5 CDC 6" rear shocks OME cs047r rear leaf packs AllPro HD Sliders Tom woods double cardin single piece drive shaft Magnaflow exhaust Black rock D window rims(old) ICON 17x8.5 Rebound CBI T3 full guard front bumper Smittybilt x20 10k winch HEISS 20" single row light bar ARB on board air compressor
    How does it work for testing everything? Is it all done on your test vehicle?
  13. Sep 2, 2018 at 4:40 PM
    robssol
    Rob
    S. Wisconsin
    Like I said a lot depends on the tune. There are other details to be worked out. Engine will most likely run warmer (spark plug swap). If your not already running synthetic oil you’ll have to switch (for the turbo) and is there enough room up front for all the additional pipeing.
  14. Sep 2, 2018 at 4:41 PM
    TelosHedge
    Central NC
    This is a big statement people. If Mat's quick spool kit is promising to beat out 350whp, we could very accurately assume that the GT25R setup could produce 400+whp. We could very easily be in the realm of a 200whp increase over untuned stock.
    marinemonkey and robssol like this.
  15. Sep 2, 2018 at 4:44 PM
    #35
    Kamille.bidan
    Kamille.bidan Well-Known Member
    2017 Blue TRD OR MT
    Does the 3.5 have forged pistons from the factory?
  16. Sep 2, 2018 at 4:51 PM
    #36
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Feel free to use my Taco if you come out to El Paso lol :(
    Shellshock likes this.
  17. Sep 2, 2018 at 4:51 PM
    #37
    OVTune
    OVTune
    Forged crank, forged rods. Pistons do not need to be forged to handle boost.
    More information will be revealed in a few weeks
  18. Sep 2, 2018 at 4:53 PM
    #38
    KkelX4
    2017 Tacoma TRD OR
    RTT Rack
  19. Sep 2, 2018 at 4:54 PM
    #39
    dagsamp
    dagsamp Unknown Member
    Marla
    16' TRDOR DCSB OV Tune
    OV Tune
    The crankshaft and connecting rods are. Pretty sure he mentioned offering billet connecting rods too
  20. Sep 2, 2018 at 5:01 PM
    #40
    82abnmedic
    82abnmedic Well-Known Member
    Florida
    2018 TRDSPLB
    I have no idea if the taco will be anything like an eco, but just google f150 eco turbo problems. Should keep you busy for awhile. Im not knocking OVs abilities at all, just not going there again. I traded my f150 at 35k miles, couldnt take it anymore.
Thread Status:
