OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Oct 18, 2019 at 1:17 PM
    #3981
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    PTP Turbo blankets, out of Austin, Texas. Then and www.Heatshieldproducts.com. Best two I have found.
    SC4333 likes this.
  2. Oct 18, 2019 at 1:39 PM
    #3982
    NamelessTaco
    NamelessTaco Well-Known Member
    Jeremy
    Washington MO
    N/A
    PTP is a good company, I was on a budget and couldn't afford their blankets at the time.
  3. Oct 18, 2019 at 4:01 PM
    #3983
    Jrgymie
    Jrgymie Tuf MuddR
    Jeff
    Glastonbury, CT
    18 DCSB CEMENT TRD SPORT 4x4
    Top mount, bottom mount, or roof top mount turbos. Don't care. Just want to boost this damn Taco. Whatever Matt finds to be the most reasonable aftermarket TT option; I'm in.
    Curious to see Matt's SC kits dyno numbers though. Heart is set on TT kit but if the SC kit shows good numbers and is available sooner...
    jerzsubbie likes this.
  4. Oct 18, 2019 at 4:41 PM
    #3984
    jerzsubbie
    jerzsubbie Well-Known Member
    Davidson, NC
    ‘13 GX460
    What this guy said. I just want some dang TT boost. I’m not as high maintenance as some of these pansies.
    pinochle likes this.
  5. Oct 18, 2019 at 5:16 PM
    #3985
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    @OVTune. I'm not asking for much - just a CARB approved SC with catted dump tubes and the proper tune for my 04B04 4.88 BBP. Thanks! In the mean time I will just enjoy the awesome tune you have blessed us with.
    TWTaco likes this.
  6. Oct 18, 2019 at 5:20 PM
    #3986
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    The whole “CARB” compliant thing is, in fact, asking for a lot
  7. Oct 18, 2019 at 5:26 PM
    #3987
    GoldenBrew
    Golden, Colorado
    Ask and maybe receive. Agreed and understand. Maybe after SEMA Mat will have another avenue/purchaser of his Tune product(s) to match up with the Gen3 SC coming which is in the CARB compliant process.
  8. Oct 18, 2019 at 6:42 PM
    #3988
    Turd Hawg
    Turd Hawg Well-Known Member
    2018 DC SB OR AT (Sold)
    I don’t know much about turbo vs supercharger. The more I read, I find that a supercharger will provide more power down low, although they are less efficient. A supercharger sounds like what this engine needs, why are so many looking towards higher rpm gains?
    I tow a lot and need off the line power straight from idle. Don’t care about zipping around at 5k+ Rpm, a supercharger is what I want right?
    TWTaco likes this.
  9. Oct 18, 2019 at 6:45 PM
    #3989
    Stormtrooper1
    Stormtrooper1 Well-Known Member
    my bad. I forget sometimes this is a truck and center of gravity is not an issue, nor is weight. But heat is an issue when pushing 550-600whp.
  10. Oct 18, 2019 at 7:15 PM
    #3990
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Not necessarily. A turbo can provide as much if not more torque down low, while being significantly more efficient. Technology has changed a lot over the years when it comes to turbos. Then you have the superchargers. There are roots and screw type, and of those, a screw type is going to be ideal (but not an option for our engine at this point) then there is centrifugal (like what mat is using.) the centrifugal has advantages in terms of installation, although doesn’t bring on low end torque as quickly as a roots or even more so, a screw type blower. It will also be outperformed by a properly designed turbo setup in terms of low end torque and power across the entire spectrum, at the sacrifice of simplicity.
    The s/c does win hands down in terms of easy installation and mechanical simplicity.
    So in a nutshell there are pros and cons to both, and a lot more than meets the eye to the layman.
  11. Oct 18, 2019 at 7:29 PM
    #3991
    Turd Hawg
    tough decision i guess. I searched google just now, supercharger versus turbo, and all say the supercharger is for down low, maybe those sites are out of date I’m not sure, they certainly differ from what I read in this thread.
    I wonder if some are just partial to turbos and create reasons why they’re just as good down low.
    At first I thought I’d wait for dyno results, but OV himself said to ignore dyno results below 3500rpm on his graphs, so I’m not sure really how to tell which is best. I doubt driving both is in the cards.
  12. Oct 18, 2019 at 7:34 PM
    #3992
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Can't generalize, BUTTTTT a relatively small turbo each on on both banks of three on a quick revving, higher compression engine with a decent piston stroke (both adding to low end) is going to spool up quickly and make relatively gobs of torque at a low RPM and actually also be a relatively flat torque curve.
  13. Oct 18, 2019 at 10:42 PM
    #3993
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    I want to see 15psi so bad I get a boner just thinking about it
    CO_Taco125, Amchuge, Alesimo and 2 others like this.
  14. Oct 18, 2019 at 10:45 PM
    #3994
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Too many variables for a blanket statement. Turbo technology has come a LONG way.
  15. Oct 19, 2019 at 6:03 AM
    #3995
    NamelessTaco
    Jeremy
    Washington MO
    N/A
    The setup Matt is trying to do is equal to the EcoBoost v6, quick power and swift response. A Centrifugal blower is not quick on power since their based off a turbocharger inlet. A positive displacement blower is like the whipple, while we wont see one on a Tacoma, it would make a taco insanely bad ass.
    Hawk373 and GreyBaldTaco like this.
  16. Oct 19, 2019 at 11:24 AM
    #3996
    Jrgymie
    Jrgymie Tuf MuddR
    Jeff
    Glastonbury, CT
    ^^well summarized and 100% agree. Turbos are the way to go for this engine but the SC kit will be a close second place, especially if you are self installing and want a simpler system. Not mention that the SC kit may be available sooner which will be very tempting. Will be nice to have options.
    SC4333[QUOTED] and Amchuge like this.
  17. Oct 19, 2019 at 11:53 AM
    #3997
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    Magnuson is coming out with one. It's on their site now.
    SC4333 likes this.
  18. Oct 19, 2019 at 1:43 PM
    #3998
    Double Phister
    Double Phister Punch it Chewie
    Sacramento, CA
    2017 DCSB TRD OR [SOLD]
    A turbo can vary it's speed based on boost pressure. A superchargers speed is coupled to the engine speed. Without a bypass on the supercharger it only makes max boost at max engine RPM. The supercharger will have the advantage of near instant power for any given speed (it feels almost like a larger displacement engine). Smaller modern turbos are very fast at spooling now so this ins't a big disadvantage anymore. A turbo will generally make more boost at any RPM than a supercharger. Really small turbos may fall on there face at upper RPMs but that just means you drive it different and shift to adapt. I'll take a turbo any day.
  19. Oct 19, 2019 at 1:52 PM
    #3999
    Inferno__Taco
    Inferno__Taco Well-Known Member
    Georgia
    2016 DCSB 4x4 TRD Sport
  20. Oct 19, 2019 at 1:56 PM
    #4000
    GoldenBrew
    Golden, Colorado
    but he said he was not going to get CARB approved. CARB approval means a lot if you need to meet emission requirements. I'd go hands down with Mat for the SC but no CARB = no deal.
    sig916 and Inferno__Taco[QUOTED] like this.
Thread Status:
