OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Oct 24, 2019 at 7:41 AM
    #4101
    L-SCHLEGS
    L-SCHLEGS Well-Known Member
    Nashville, TN
    2017 CEMENT TRD PRO
    I cruise at 75 around 2,000-2,200 rpm with 35s and 5.29s
    there is only like a 200 rpm difference between 4.88 and 5.29. But gears are one of those things you only want to do once. And that extra 200 rpm or so really pays off on the highway.
    Pablo8[QUOTED] and Shellshock like this.
  2. Oct 24, 2019 at 7:42 AM
    #4102
    Shellshock
    Iowa
    And towing. or if you are heavy. or in the mountains.
    BassAckwards, double_duez and Pablo8 like this.
  3. Oct 24, 2019 at 7:43 AM
    #4103
    L-SCHLEGS
    Nashville, TN
    2017 CEMENT TRD PRO
    Exactly, which is why I still would recommend 5.29s even for a stock AT.
    Pablo8 likes this.
  4. Oct 24, 2019 at 7:59 AM
    #4104
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    Man
    I’m gonna make a comment a little out of my knowledge and I’m gonna go research it later
    but this occurred to me this morning after OVs post
    If this taco motor really reaches into the 500whp and so on and so forth
    if you have your factory Toyota gears in the rear
    And you give it the juice
    man
    It’s more than likely all gonna let go like a grenade...
    I cannot imagine a factory Toyota AT truck rear gears in a sport or off-road model handling that much power.
    Cause my whole rear axel went boom at 25k miles ODO just driving down the city roads to get from food back to my house
    and the factory gears at least in second gen tacomas were notoriously weak even in nitro gear and ARB ect ect ect
    Edit:
    I don’t mean to imply the gears would fail immediately after the tune and boost of choice
    but man it’s not gonna take long
  5. Oct 24, 2019 at 8:05 AM
    #4105
    Shellshock
    Iowa
    I agree if its a sport. if its a OR / PRO / MT they have a 8.75" rear end instead of the 8" in the AT (non OR/PRO) and I have yet to see someone explode one of those.
  6. Oct 24, 2019 at 8:09 AM
    #4106
    su.b.rat
    su.b.rat broken truck
    yeah, but those 8.75's are pretty new and it's not like those units have been put through the high powered ringer yet. i like the idea of big power on this truck, too, but i'm also seeing that in reality as a likely $25k project because of these details. the question with 500+ is where is the weakest link? and then the next one... there will be more than one.
  7. Oct 24, 2019 at 8:18 AM
    #4107
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    I have lol
    Actually
    Last week
    2015
    joey.taco likes this.
  8. Oct 24, 2019 at 8:23 AM
    #4108
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Easy
    first it’s your axel
    Then it’s gonna be your leaf springs
    Then it’s gonna be the frame
    then it’s gonna be ladder bars to reduce twist and dive or rise of the axel under load and brakes
    Then it will be brakes or brake booster
    Then I’d imagine it’ll start being direct driveline like driveshaft joints
    Mind you all of this is based on use in 2wd
    in 4wd you will have more planted instant response when you tell it to go
    but that means a litany if other issues in that scenario
    my first guess would be unit bearings and then spindles
    Edit: at a certain level the severity of these listed plausible problems will just come down to your maintenance and keeping up on it before things become issues
    like fixing leaks or changing fluids more frequently
    More hardware checks ect
  9. Oct 24, 2019 at 8:34 AM
    #4109
    Shellshock
    Iowa
    someone blew up an 8.75?
    Caboose117[QUOTED] likes this.
  10. Oct 24, 2019 at 8:39 AM
    #4110
    naked farmer
    naked farmer Well-Known Member
    Nor Cal
    ‘17 B.Red Off Road
    4.88 or 5.29 for a tt setup? I’m thinking 4.88 with force injection would be The ideal combination.
    Doomsday likes this.
  11. Oct 24, 2019 at 8:41 AM
    #4111
    su.b.rat
    i previously mentioned somewhere that I'm into the TT idea on this truck, but would only do it as a complete custom rebuild with all that, or just whatever is needed realistically. I'm calling it $100k LT go nuts rebuild. maybe it's a dream but I've made those reality before, so I'm sure i can do it. but this is my DD now.
    Amchuge and Caboose117[QUOTED] like this.
  12. Oct 24, 2019 at 8:48 AM
    #4112
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Full floater replacement axel with 35 spline axels and a beefy 9” or 10” is gonna be in the ballpark of 5-6k depending on what level of specs you want in it.
    front suspension long travel you’re looking around 10k said and done maybe a little more
    -shocks
    - new uppers and lowers
    -new axels
    -long travel related gusseting like frame or spindle gussets
    then you’re looking at 1600 ish for heavy duty leafs (I’m aiming a bit high on the price)
    And then you’ll need
    -new shackles
    -new perches
    Nuts and bolts stuff
    Unless you’re gonna link the truck in the rear
    then
    It’s a lot more
    links alone for my truck were 3k
    Then cage and whatnot will be easily 15-20k by the end (total front to rear)
    plus a new fuel cell... that’ll be 3-5k plus all the needed junk with that..
    and seats will probably set you back about 2700 for a 4 seater
    and gears front and rear will probably be in the 3-4k range depending on manufacturers and install cost
  13. Oct 24, 2019 at 8:59 AM
    #4113
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    I see the marines symbol on your profile.. man the sign up bonus must've really increased from what that marine salesman told me in high school ;)
    kidding of course, i'll live vicariously through you i suppose.
    Shellshock and auskip07 like this.
  14. Oct 24, 2019 at 9:46 AM
    #4114
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    OEM 3.73 gears, holding 550wtq, currently. 2nd Gen.
  15. Oct 24, 2019 at 10:20 AM
    #4115
    Jbarth
    Jbarth Well-Known Member
    Albuquerque, New Mexico
    2019 TRD OR
    I thought 4lo actually multiples torque to the front and rear axles far surpassing what the expected increased in torque from the two snails or supercharger.
  16. Oct 24, 2019 at 10:35 AM
    #4116
    crepr12
    crepr12 Well-Known Member
    25 Limited Hybrid
    So did any 18 Taco owner ever bite on OVtune's offer?....quickest way to clear a room....ask to borrow 5k
  17. Oct 24, 2019 at 10:38 AM
    #4117
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    I thought diff failure was due to low diff oil from factory?
    Torspd likes this.
  18. Oct 24, 2019 at 12:00 PM
    #4118
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Been out since 2016
    Perm retired list
  19. Oct 24, 2019 at 12:01 PM
    #4119
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    I believe you
    I still wanna see it
    Pics? vids?
  20. Oct 24, 2019 at 12:01 PM
    #4120
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    There are a couple class actions I’ve seen here and there in regards to the 16’s and 17’s having warped axel shafts from the factory.
    but
    Improper fill of fluids can always contribute to early failures
Thread Status:
