OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Dec 10, 2019 at 6:54 PM
    #4761
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    This my friend, is how you blow turbo seals.
  2. Dec 10, 2019 at 7:27 PM
    #4762
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    There's probably too many variables to be able to calculate accurately no?
    Mike O likes this.
  3. Dec 10, 2019 at 7:36 PM
    #4763
    soggyBottom
    soggyBottom Well-Known Member
    I think we can get some good estimates. A ballpark number is better than the alternative.
  4. Dec 10, 2019 at 7:51 PM
    #4764
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I mean he has it in another vehicle. It works, that part is obvious haha.
  5. Dec 10, 2019 at 8:01 PM
    #4765
    soggyBottom
    Sure and as I said earlier, I believe that mat has tested this and it works but there are 100 posts stating openions on the subject. I just get tired of hearing arguments with no proof or references.
    As a side note, the skyactive engines look like they use 30 weight oil which would flow differently. I suspect that this favors the Tacoma because the lighter oil would flow faster.
    Anyone have any idea what kind of oil pressure the 3rd gen makes?
    Edit
    I found some math stuff online. As a rough start, does 22 seconds to flow 1 liter sound reasonable? This is for a 1/2' tube at a height of .5 meters, 20 weight oil at 100c.
  6. Dec 10, 2019 at 9:35 PM
    #4766
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    The turbos have design specs for inlet and outlet size. The varying pressure in the return line depending on oil pan circumstances (various differing temperatures, engine speeds, angles of orientation, etc) isn't something that can easily be calculated. At least not without installing sensors in the pan and/or return line.
    Since it's not inexpensive/quick to calculate these factors Mat and his team appear to be taking general industry knowledge into account when designing and testing the kit.
    I'm comforted by the fact that Mat will be performing real world testing... at the same time I realize that the first dozen or so of us installing this kit are going to be part of the testing and learning process.
  7. Dec 10, 2019 at 9:45 PM
    #4767
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Again....we have proof on the skyactive. It's been done before. If that's not enough, it's being done on the 2gr-fks currently with Matt already. That's proof as crystal clear as it gets. If u need to quantify it, then be my guest, probably be beneficial to the fence sitters.
  8. Dec 11, 2019 at 7:00 AM
    #4768
    Chwilli88
    Chwilli88 Member
    You do know that turbo seals don't actually blow right? They wear over time and then leak. The wear can be accelerated by out of balance shafts or coked up bearings. They are mechanical seals that actually seal via gas pressure and thermal expansion.
    Reh5108[QUOTED] and Skydvrr like this.
  9. Dec 11, 2019 at 7:27 AM
    #4769
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    The twin turbo system is going to be more popular. There's no doubt about it.
    Jrgymie, joey.taco, lapoltba and 7 others like this.
  10. Dec 11, 2019 at 8:55 AM
    #4770
    roth_nj
    roth_nj Well-Known Member
    2017 DCLB trd off-road bbp
    whats the cost looking like on the TT kit? this is a super general rough ballpark question.... the supercharger kits are 6,500 correct? is it going to be in the same area or cheaper?
  11. Dec 11, 2019 at 9:03 AM
    #4771
    OVTune
    OVTune
    Supercharger wasn't that much.
    Not ready to post TT kit price yet. We had a price point on our mid mount. But that's scrapped.
  12. Dec 11, 2019 at 9:17 AM
    #4772
    roth_nj
    sorry, not yours but the couple at sema
  13. Dec 11, 2019 at 9:19 AM
    #4773
    OVTune
    OVTune
    Yea,
    Magnusons S/C is $6495 according to their website.
    If that is with tune, or without, is unknown.
    Harrops S/C price is unknown as of right now.
    our TT kit will be significantly less than either of them.
    go2cnavy, joey.taco, Bascoma and 13 others like this.
  14. Dec 11, 2019 at 9:24 AM
    #4774
    Captndarty
    Captndarty Well-Known Member
    2017 Magnetic Grey limited
    Looks like Magnuson has updated their HP specs from 30% now to 50% increase in power. 415hp/395lbs seems fantastic to me. Hope this will create a targeted benchmark for all other SC setups.
    joey.taco, jerzsubbie and Trock like this.
  15. Dec 11, 2019 at 9:25 AM
    #4775
    roth_nj
    cool... thats all the answer i was looking for
  16. Dec 11, 2019 at 9:33 AM
    #4776
    Gen3TacomaOBX
    S
    Where do you see the 415/395 numbers from them?
    All I see is "up to 50%" which can mean just about anything (a specific low/mid rpm for example.)
  17. Dec 11, 2019 at 9:40 AM
    #4777
    OVTune
    OVTune
    Videos come this weekend.
    Driving videos, boosting videos. The good stuff.
    Was suppose to a week ago but stuck doing orders,
  18. Dec 11, 2019 at 9:42 AM
    #4778
    Kclamer
    Kclamer Well-Known Member
    Konstantin
    2018 Toyota Tacoma TRD Off-Road 4x4
    2.5" lift, 4.88 gears
    I think I would still go for a supercharger even if it costs more money, seems like a simpler setup that is less likely to have problems. When I had my Audi biturbo all I thought about was when the ko3s would fail and I had a 6k bill to have them swapped out.
    Same thing with the 6.4L Powerstroke Turbo. The turbos put more load on the cooling system, heat up the engine bay, reduce the lifetime of engine oil, have complicated plumbing, more difficult to tune, add lag into the powerband.
    its not everyones cup of tea but just my preference. I hope OVTune makes a kickass tune for the Harrop SC when it comes out as that will be the one Im getting.
    Bertw192 and GoldenBrew like this.
  19. Dec 11, 2019 at 9:57 AM
    #4779
    naked farmer
    naked farmer Well-Known Member
    Nor Cal
    ‘17 B.Red Off Road
    Any testings or observations with mpg and the tt?
  20. Dec 11, 2019 at 10:50 AM
    #4780
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Boost porn :rofl:
    Shellshock likes this.
Thread Status:
