OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Dec 11, 2019 at 11:09 AM
    #4781
    Captndarty
    Captndarty Well-Known Member
    2017 Magnetic Grey limited
    Those numbers were deducted from simple math and since 50% could mean anything I went with peak numbers. I deduced so based on the new numbers of the 3.6L wrangler which Mag has the actual number listed and there pretty high for a similar engine.
  2. Dec 11, 2019 at 12:03 PM
    #4782
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    They revised their potential power without releasing any other info to support the revision.
    Seems like a best guess place holder until actual results get released.
    I think 50 percent is a good estimate. It's a big blower for a v6.
    But until we see hard data I wouldn't take any HP claim as fact.
    Fun fact is harrop and Manson both using the same blower so we will get to see which company out tunes the other hehehe.
    Looks like Harrop hasn't released any estimate on power figures. Smart move I think.
  3. Dec 11, 2019 at 12:16 PM
    #4783
    Speedwaytacotuesday
    Speedwaytacotuesday I love riding in my wife's Taco :p
    Calgary, Alberta
    2016 TACO LTD, 88 4runner, 4th Gen 4Runner
    TRD S/C 2.3" pulley mild ported Portmatched/cleaned intake runner Ucon EMS/cam gears/160 t-stat 840cc injectors 255 LPH walbro fuel pump Urd equal length headers Urd competition y-pipe AFE 3” Exhaust Vibrant resonator Oil Catch can Ratio-tek valvebody upgrade 3" bilstein/OME lift Dakar rear 7-leaf pack 32" KO2's load range C Stealth custom wheels Ray-10's Volk Te37X’s Tundra front 13.3” brakes Custom fab rock sliders LC-2 wideband autometer boost gauge Cravenspeed gauge pod mount Scangauge 2 SC MODS: Pulley ripp mod/belt wrap mod/ fleetrunner belt/ tensioner stop delete mod/ bypass jet delete mod
    Exactly, same blower used on the Maggie for the 5.7 Tundra as you already know, which is quite large, also considering the larger 4.0 1gr-fe out of the 4Runner is only utilizing the 1320. The real difference between the Harrop and Magnuson will be the intercooler and heat exchangers and of course as you mentioned tuning.
  4. Dec 11, 2019 at 12:17 PM
    #4784
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Yes. If you can't drain the oil faster than it's being fed out the seal its going to most likely go.
  5. Dec 11, 2019 at 1:20 PM
    #4785
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    But that’s still 415 at the crank. Which will result in about 355-ish at the wheels. Which is still less than what mat is predicting his twin turbos will make
  6. Dec 11, 2019 at 1:28 PM
    #4786
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    Just to update you (not complaining)
    That MAF housing has Not showed up yet
    thanks again on the help with that :)
  7. Dec 11, 2019 at 1:34 PM
    #4787
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Might double check that
    I remember him saying WHP on the last twins setup but most of his other numbers since have been normal HP
    :notsure::mudding:
  8. Dec 11, 2019 at 1:47 PM
    #4788
    Speedwaytacotuesday
    Calgary, Alberta
    Def good point. In the end if one didn’t care about the warrantee and willing to put forth supporting mods, both the TVS blower and twins have significantly more head room to make more power. If us jelly boosted 2nd gen guys had these options we’d be squeezing every ounce of power until our motors goes boom.:bananadead:
    That’s why I’m jumping ship. I promised never to say Turd Gen again:D
  9. Dec 11, 2019 at 1:54 PM
    #4789
    Anchovy
    TRD Ferguson
    The old mid-mount setup he had a dyno run of about 400whp. He said he scrapped the mid-mount setup for a top-mount and he said that top-Mount will likely perform better
  10. Dec 11, 2019 at 5:16 PM
    #4790
    OVTune
    OVTune
    There is no "likely" ..it blows away the mid mount.
    And yes our results were measured at the hub (without wheel).
    It's more than 400 crank.
    The best part I think is it's quiet. Not obnoxious. The VTA setup on our truck is very mild. Exhaust (stock) is actually quieter than stock truck at idle.
    It has a very "OEM" type of feel
  11. Dec 11, 2019 at 5:44 PM
    #4791
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    I’m betting they’re getting a wiff of Mat’s numbers and decided to change the pulley sizes a bit. Maybe. :)
  12. Dec 11, 2019 at 5:55 PM
    #4792
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Oh that's a great feature. But I know turbos. That is not the best part.
    pinochle and jerzsubbie like this.
  13. Dec 11, 2019 at 7:17 PM
    #4793
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Might have to move out of California so I can get these haha
  14. Dec 11, 2019 at 8:03 PM
    #4794
    Jimmyturbo
    Jimmyturbo Well-Known Member
    Jimmy
    2017 Tacoma trd off road
    Icon stage 8 long travel suspension
    I’m in Cali and definitely going for the twinz
    you only have to smog every two years I believe.
    if you wrench even just a bit it shouldn’t be hard at all to just take them off and revert to stock.
    Will be a great opportunity for any engine maintenance. Or FArkle polishing you may want to do
    maybe I’m just weird and don’t see this as a problem really?
  15. Dec 11, 2019 at 8:12 PM
    #4795
    Brostjoe
    Brostjoe Well-Known Member
    British Columbia
    2017 Limited DCLB
    50% on Magnuson is nice to see. I think this kit will take majority of the market and Matt’s twin kit aswell. Harrop based on the pricing of the Tundra kit will be higher. Majority already don’t like the $6495 price tag of a Magnuson.
    A Magnuson with a OV Tune possibly different pulley will be the supercharger kit of choice.
    Twin kit from OV as it sounds like will hit a better price point, more potential and more efficient for amount of boost vs output at rear wheels.
    Speedwaytacotuesday likes this.
  16. Dec 12, 2019 at 6:02 AM
    #4796
    jerzsubbie
    jerzsubbie Well-Known Member
    Davidson, NC
    ‘13 GX460
    I agree that Magnuson and OVT TT will be the top choices, but I think it will be the other way around. Considering the better efficiency, presumably more complete tune, and lower price point of the OVT TT, I think it'll be the best seller. The one thing that could prove me wrong, is their limited reach/marketing vs Magnuson.
  17. Dec 12, 2019 at 6:16 AM
    #4797
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    describe significantly? :thumbsup:
  18. Dec 12, 2019 at 6:42 AM
    #4798
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    I'd like to know too.
  19. Dec 12, 2019 at 7:44 AM
    #4799
    msapers
    msapers Well-Known Member
    Scott
    Los Angeles
    2017 TRD Off Road DCSB V6 MT
    It's goint to take several folks purchasing different kits and driving them in real world conditions before a clear "best" emerges. "Best" meaning overall power output, drivability, noise, longevity, cost and legality. Then it will come down to what you really want from your truck. Personally, I think my truck, running OVT 2.0 Beta has plenty of top end power. Where I want an increase is idle to 3000 rpm. My hot rodder's brain immediately says that a supercharger is the answer, but I have very little turbo experience and I'm genuinely curious as to how the turbos will perform. I have an open mind.
  20. Dec 12, 2019 at 8:42 AM
    #4800
    OVTune
    OVTune
    taco 16, 05Taco4x4, Jrgymie and 41 others like this.
Thread Status:
