OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Dec 14, 2019 at 10:51 AM
    #4921
    Hayrod
    Hayrod New Member
    Jared
    Texas
    2018 TRD off-road MT
    OME 2.5" lift, 17x9 rims, 33x10 tires, kicker speakers, weathertech floormats, bell and buzzer delete, OVtuned
    I have a manual, it will hold sixth gear all day long (just not much pep).
  2. Dec 14, 2019 at 10:53 AM
    #4922
    Shellshock
    Iowa
    it’s got quite a bit of pep if you are cruising down the interstate. I can tow in 5th all day and there’s only been a few spots out west I couldn’t do in 5th.
  3. Dec 14, 2019 at 11:25 AM
    #4923
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    you be our local test subject. In your neck of the woods I presume there are no emission requirements like I have here in the hood. I'm holding out hope for the SC. If Mat bails on his SC I will look at Under Dog - probably shit can the entire idea if there is no Tune with transmission logic revision to match competitor products. I will just pretend my Audi is my Toyota with BOOST!
  4. Dec 14, 2019 at 11:31 AM
    #4924
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Yeah yeah. I know lol
    I want to do the SC!
    Amchuge and Shellshock[QUOTED] like this.
  5. Dec 14, 2019 at 12:30 PM
    #4925
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Washington state is moving to emission free in 2020 so whoever is feeling froggy get ready to hop
    dondecontente likes this.
  6. Dec 14, 2019 at 12:38 PM
    #4926
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    I don't see this being an issue. Factors for it are usually waiting too long on oil changes, DI turbo engines trying to get away with running 87, and small displacement.
    The cams, in our case can be used to control total cylinder fill at very low rpm so even at higher boost psi we can control pressure bleed off before the valves close.
  7. Dec 14, 2019 at 12:54 PM
    #4927
    uploadadventure
    Dixon, Mo
    I don’t have emissions where I live. Do have inspections, but I know a guy lol
    ihatemytruck likes this.
  8. Dec 14, 2019 at 8:40 PM
    #4928
    iDrew
    iDrew I spend too much on vehicles...
    Andrew
    Edmond, OK
    '16 TRD Off-Road DCSB
    STOCK AF
    That's awesome! I actually blew the 2.0 in my previous ST due to LSPI, so this is very reassuring.
  9. Dec 15, 2019 at 5:27 AM
    #4929
    Jrgymie
    Jrgymie Tuf MuddR
    Jeff
    Glastonbury, CT
    18 DCSB CEMENT TRD SPORT 4x4
    ^^I've had my eyes on the TT setup since it will provide the most low end HP/torque (area under the curve) but the recent developments with the multiple SC kits have me contemplating which one suits me best. So... trying to narrow down my choice btw the 2 types of SC (centrifugal vs roots) first then eventually BTW the TT kit and SC kit.
    I feel that the roots SC (linear power, slightly more low end torque) would suit the Taco needs better than the Rotrex (exponential power curve, more high end power). My impression is that the Rotrex only provides power at higher RPM's and under more throttle. Since there is plenty of power with our 3.5 at the high end I feel like the Rotrex would not be addressing what this engine lacks.
    Also, those on TW who've had the roots SC with other engines always seem fond of the setup and continue to recommend it. Sometimes its not always about the peak HP/torque dyne numbers but how that HP/torque is applied and the drivability of the setup.
    For me, it's going to be btw a roots SC kit versus the TT kit. Regardless of kit, would prefer OV tuning given the time and developments Mat has made with this engine. Exciting times for the 3rd gen Taco owners.
  10. Dec 15, 2019 at 5:49 AM
    #4930
    Brostjoe
    Brostjoe Well-Known Member
    British Columbia
    2017 Limited DCLB
    Roots and TT will be the favourites for sure.
    TacoTim85 likes this.
  11. Dec 15, 2019 at 5:50 AM
    #4931
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    I m in the same boat. I like the roots for lower temps and not needing to tap into the engine oil. Sounds like it's going to be significantly more expensive than the TT though.
    Brostjoe likes this.
  12. Dec 15, 2019 at 6:57 AM
    #4932
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    The particular Magnuson and Harrop superchargers that were recently unveiled for the 3rd gen are actually screw type superchargers, not roots. This is a good thing though, as a screw type makes more power and is more efficient than a roots. With that said, I would be shocked if either of those kits can hold a candle to low end toque that the twins will produce. They also won’t be nearly as efficient.
    That is not to say they won’t haven’t plenty of power on tap, it just wont be what you can get from a properly tuned TT setup, running relatively small turbos like Mat has put together. It’s great to see so many options coming to the table, and it looks like there will be something to keep everyone happy if you’re willing to pony up.
  13. Dec 15, 2019 at 8:18 AM
    #4933
    Speedwaytacotuesday
    Speedwaytacotuesday I love riding in my wife's Taco :p
    Calgary, Alberta
    2016 TACO LTD, 88 4runner, 4th Gen 4Runner
    TRD S/C 2.3" pulley mild ported Portmatched/cleaned intake runner Ucon EMS/cam gears/160 t-stat 840cc injectors 255 LPH walbro fuel pump Urd equal length headers Urd competition y-pipe AFE 3” Exhaust Vibrant resonator Oil Catch can Ratio-tek valvebody upgrade 3" bilstein/OME lift Dakar rear 7-leaf pack 32" KO2's load range C Stealth custom wheels Ray-10's Volk Te37X’s Tundra front 13.3” brakes Custom fab rock sliders LC-2 wideband autometer boost gauge Cravenspeed gauge pod mount Scangauge 2 SC MODS: Pulley ripp mod/belt wrap mod/ fleetrunner belt/ tensioner stop delete mod/ bypass jet delete mod
    It’s a TVS with 4 lobes and 160 degree twist which makes it look like a screw but I believe it’s still considered a roots. A Whipple would be a screw type. URD offers a nice 2.3L oversized whipple kit for the later 1grfe engines.
  14. Dec 15, 2019 at 8:32 AM
    #4934
    konerri
    konerri Member
    Because turbo sounds way better
  15. Dec 15, 2019 at 9:16 AM
    #4935
    jerzsubbie
    jerzsubbie Well-Known Member
    Davidson, NC
    ‘13 GX460
    I’m fairly confident that with the small turbos that Mat is using, and being top mounted, the turbos will spool so fast that we’ll get all the low end power that this truck needs, if not more.
    I have nothing against SC but turbos seem like the way to go for this engine and most applications of it.
  16. Dec 15, 2019 at 9:47 AM
    #4936
    motogeek
    motogeek Taco Tueday? Tacos Everyday!
    Tacomeat
    America
    Tacoma SR5 TRD 4x4
    2.5 Toytech Inch Lift 285 Cooper SST
    So I'm at about 60k on my truck. Does anyone know the factory warranty on drive and engine on the 3rd gen? I'm going to assume that you will forfeit the warranty with the turbos applied?
  17. Dec 15, 2019 at 9:47 AM
    #4937
    OVTune
    OVTune
    it is very torquey and I'm off road again.
    4 low is very controllable. But also in boost it picks up fast.
    4 high hahaha wow. The way the torque picks up is just phenominal
    2w off road just constant spin
    iDrew, PB FAB, TacoTim85 and 5 others like this.
  18. Dec 15, 2019 at 9:53 AM
    #4938
    Shellshock
    Iowa
    power train warranty is 60k
    motogeek[QUOTED] and joey.taco like this.
  19. Dec 15, 2019 at 10:04 AM
    #4939
    OVTune
    OVTune
    Tested, really thrashing it:
    2WD off road
    4 high off road
    4 low off road
    really beating on it, stomping the pedal in 4 low, revving to 6500.
    Just back to back to back. full throttle from a dead stop to top of 2nd in 4 high, 15 times in a row.
    on the road and off the road.
    not only does it respond beautifully but no issue whatsoever. nothing is breaking yet.
    this is on about ~8-10psi
    ancient11, Torspd, pinochle and 10 others like this.
  20. Dec 15, 2019 at 10:06 AM
    #4940
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    We want videos! Lol
Thread Status:
