OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Dec 18, 2019 at 12:21 PM
    #5161
    sdfuller88
    sdfuller88 Well-Known Member
    Reno, NV
    I appreciate the concern but I am well aware of what may happen and have taken precautionary steps.
    Let's get the thread back on track!
  2. Dec 18, 2019 at 1:11 PM
    #5162
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Lame.
  3. Dec 18, 2019 at 2:57 PM
    #5163
    Capt. Nemo
    Capt. Nemo Member
    Call me a noob and not contributing anything to this thread, but unlike some of the keyboard cowboys on here (and other forums I’ve been on) - I have first hand experience boosting cars that weren’t originally designed to be boosted. I made points earlier that are valid, and if a reasonable person took a long hard look at what I’m trying to say, it would make sense.
    The OP has done a TON of work building a business on tuning these engines and putting R&D into this turbo endeavor. I have nothing but respect and a little bit of jealousy. I’d love to be able to do this type of thing full time, but I’m too far into a career to change things up now.
    Tuning is an art, and will make or break a FI build. The OP has mastered these engines, and is perfecting the tunes on these trucks. Like he mentioned, typical tuners aren’t messing with these engines and a local tuner isn’t going to know where to start.
    As long as the OP has the ability to remote tune, provide data logging abilities with the kits, and provide the customer support needed to tweak each individual set up - I’d say he’s hit this out of the park and wish him the best of luck.
  4. Dec 18, 2019 at 3:02 PM
    #5164
    ajmogen
    ajmogen Well-Known Member
    Aaron
    Wisconsin
    OR MT TACO T4R YARIS MT Corolla Hatchback MT
    Start your own expert thread on the pitfalls of FI
    I'm sure it'll get a ton of traffic
  5. Dec 18, 2019 at 3:02 PM
    #5165
    seelyartacus
    seelyartacus Well-Known Member
    San Diego
    '16 TRD Sport 4x4, grey, tech&tow pkg
    FNWheels six shooter matte bronze, Falken WildPeak M/T 295/70/r17, All-Pro Expedition leafs, Fox Factory 2.5 w/ res (front/rear), Icon billet UCA w/ sphericals, custom sliders, 4.56 re-gear, RCI bed rack , Tepui RTT, Prinsu Designs Cabrac, CBI T3 alum front bumper, CBI T3 rear bumper with dual swing away and tire carrier, 20in light bar, Warn VR10s winch, Factor 55 fairlead, flatlink, and hitch recovery point, All-pro alum skid, Rotopax, CMC, Timbren bump stops, rear Rigid Duallys, Rigid Dually ditch lights, ARB awning with LED lights, Currie F9 rear axle housing w/ Strange Engineering 3rd memb and ARB air locker., rear diff beather relocation, ARB compressor under hood, Bussman panel, 3d printed switch panel,OVTune ECU
    i'd take base
  6. Dec 18, 2019 at 3:03 PM
    #5166
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    He has the ability to do custom remote tuning. However, trying to schedule time for all of the custom tuning will be very difficult
    ihatemytruck likes this.
  7. Dec 18, 2019 at 3:41 PM
    #5167
    Shellshock
    Iowa
    Not when there’s only 4 available kits lol
    he could just roll out small batches initially. Say 10-20 a month.
  8. Dec 18, 2019 at 3:45 PM
    #5168
    soggyBottom
    soggyBottom Well-Known Member
    A few months ago I had a Audi Q7 with a 2.0T. the turbo lag drove me crazy while trying to go slow over rocks in some mild off-road situations. It was a constant jump between bogging down or spinning all 4 tires. You may have said it already, but when is the power coming on with the testing so far?
  9. Dec 18, 2019 at 3:57 PM
    #5169
    16taco-trd
    16taco-trd Well-Known Member
    Mat, any thoughts on my post about possibly passing emissions without the Cats near the engine for someone not under the tight scrutiny of California.
  10. Dec 18, 2019 at 4:27 PM
    #5170
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Full boost is under 2000 rpm. Peak torque is TBD, I expect it to be around 2800-3200 rpm.
    It's quite controllable though, although my truck has larger mud tires so that could be a factor. The one thing, which I have tested already, is tuning of the torque converter makes a huge difference in how the truck responds and accelerates.
    Fully unlocked the truck moves smoothly, accelerates strong, but the torque converter being unlocked is obvious. The truck doesn't really "wake" up in movement until about 2500 rpm.
    Now the opposite. Fully locked. RPM stays very, very low. (Cruising around I rarely saw above 2500 rpm in any gear). Boost comes strong and fast. Moves the truck pretty effortlessly, but also controllable.
    The con to that is, with the TC fully locked mpg is no good in the city.
    One thing for certain is, the turbos on the truck completely change the dynamic of how it responds, shifts, and behaves.
    With TC lock up it's possible to drive almost entirely under 2000 rpm, by generating around 2-3psi.
    How quickly boost can be generated with this setup is exactly what the goal was with this from the beginning.
    I do plan to make a catted version, will it pass emissions, likely. CARB approved? Unlikey.
    Base kit tuning (engine side) is pretty much done. Bigger turbos, injectors, and fuel pump go on Sunday (assuming time is available).
    If we can't get the base Garrett's in a timely manner we may have to offer the base kits with the Borg Warner versions.
    They aren't worse in performance, but they do say "FoMoCo" on them.
    Unlikely thought, Garrett is expecting to have many ready in January.
  11. Dec 18, 2019 at 4:54 PM
    #5171
    ScottyR
    ScottyR Well-Known Member
    Vancouver BC
    2016 DCLB TRD Sport
    The TRD sport has the same set up. Good to know it will work with dual batteries!
  12. Dec 18, 2019 at 4:59 PM
    #5172
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    Correction, TRD Sport models still has the ABS there. It is TRD OffRoad and TRD Pro that do not have ABS as they have Crawl Control instead.
  13. Dec 18, 2019 at 5:01 PM
    #5173
    TacoTim85
    TacoTim85 Well-Known Member
    Vancouver, Washington
    2007 4Runner Sport Edition 4WD (Current)
    :bananadance::bananadance::bananadance:
    Now this is what I'm talking about!
  14. Dec 18, 2019 at 6:13 PM
    #5174
    06ltd
    06ltd Well-Known Member
    Maryland
    2019 TRD OR 6MT
    Can you imagine the hundreds of thousands of miles this engine would last if you spent all your time under 2k rpm?
  15. Dec 18, 2019 at 6:42 PM
    #5175
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    It depends. And is load dependent.
  16. Dec 18, 2019 at 6:56 PM
    #5176
    06ltd
    Maryland
    2019 TRD OR 6MT
    2-3 psi with forged internals? Seems like a bulletproof combo to me
  17. Dec 18, 2019 at 7:04 PM
    #5177
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Not what I am saying.
    Say someone runs a hill every day at 1200 rpm in 3rd after just starting the engine. 2500-3000 RPM isn't necessarily hard on a modern engine.
  18. Dec 18, 2019 at 7:26 PM
    #5178
    BlkdOuT
    BlkdOuT Well-Known Member
    2017 Tacoma trd sport 4x4 MT TT
    Great so I'd have to explain to everyone why I drive a Ford Tacoma EcoBoost
    d.ustn, slow.taco, Sleipnir and 3 others like this.
  19. Dec 18, 2019 at 7:32 PM
    #5179
    Shellshock
    Iowa
    I’d dremel that shit off before install
  20. Dec 18, 2019 at 7:34 PM
    #5180
    BlkdOuT
    Yeah that shit'll buff out alright
Thread Status:
