OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Dec 30, 2019 at 9:37 AM
    #5381
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    Not that I haven't done that before..
    But other people have educated me for not living in the OVtune threads.
  2. Dec 30, 2019 at 9:53 AM
    #5382
    iDrew
    iDrew I spend too much on vehicles...
    Andrew
    Edmond, OK
    '16 TRD Off-Road DCSB
    STOCK AF
    Doesn't locking the converter generate a bunch of heat? Curious about transmission temps. I could be way wrong though.
  3. Dec 30, 2019 at 10:05 AM
    #5383
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Is that 7k rpm? :eek:
  4. Dec 30, 2019 at 10:06 AM
    #5384
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I think it's the opposite. Locked up converter means you're not relying on the oil for torque transfer. Less heat
    iDrew[QUOTED], 420taco and Shellshock like this.
  5. Dec 30, 2019 at 10:08 AM
    #5385
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    The graphic says 6,768 RPM max.
  6. Dec 30, 2019 at 10:08 AM
    #5386
    Skydvrr
    Nick
    YMH
    Black '17 OR
    TBH, idk how to read these haha. Pretty good guestimate though.
  7. Dec 30, 2019 at 10:11 AM
    #5387
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    I highly doubt the turbos will get hot enough while OffRoad to risk blowing up from a sudden cool down while crossing some water
    Reh5108 and ihatemytruck like this.
  8. Dec 30, 2019 at 10:26 AM
    #5388
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    locked converter = less heat.
    Also transmission temp is in that graph.
    =JSG=, Sleipnir, ihatemytruck and 2 others like this.
  9. Dec 30, 2019 at 10:28 AM
    #5389
    Skydvrr
    Nick
    YMH
    Black '17 OR
    170 is surprisingly well. I hit 242 idiling in this wretched AZ heat.
    jerzsubbie and double_duez like this.
  10. Dec 30, 2019 at 10:32 AM
    #5390
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    Am I reading this correctly? Magenta and cyan lines are two turbo'd runs while the red line is stock?
    What's up with the stock run? Why is it so janky sub 3500 rpm? Is that a gear shift?
  11. Dec 30, 2019 at 10:33 AM
    #5391
    OVTune
    OVTune
    On stock tune you can't floor it under 3500 rpm or it will downshift, so we made the best run that we could.
  12. Dec 30, 2019 at 10:38 AM
    #5392
    Doggman
    Alabama
    2017 TRD OR MT
    Fair enough. Will be interesting to see the low RPM comparison with an MT truck.
  13. Dec 30, 2019 at 10:45 AM
    #5393
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I bet in 3rd at like 40mph, full throttle would be way too fun.
  14. Dec 30, 2019 at 11:23 AM
    #5394
    Doggman
    Alabama
    2017 TRD OR MT
    Yeah no doubt. I ventured over here because of your post in that other thread. Your post and my following handful of clicks may end up being quite costly. The gains/price ratio seems monstrous. Panning out to be far more tempting than I ever expected possible in the early days of development.
    Skydvrr[QUOTED] likes this.
  15. Dec 30, 2019 at 11:45 AM
    #5395
    TacoTim85
    TacoTim85 Well-Known Member
    Vancouver, Washington
    2007 4Runner Sport Edition 4WD (Current)
    So basically 450 lb ft of torque at 1350 rpm? Am I reading this right? o_O
    Doggman, Skydvrr and Shellshock like this.
  16. Dec 30, 2019 at 12:13 PM
    #5396
    OVTune
    OVTune
    Likely a little bit less, there is some correction due to temp, and also torque converter tuning at play here to make this happen.
    I need to correct my post. This was achieved with an unlocked converter.
    Fully locked torque is much flatter, but less, below 2000rpm
  17. Dec 30, 2019 at 1:36 PM
    #5397
    CO_Taco125
    CO_Taco125 Well-Known Member
    '17 TRD OR DCSB
    Blackhawk Tune, Falken Wildpeaks, Falcon Suspension, KMC XD, KC flexpods, KC Pro6 bar, Kicker speakers, Sound Ordnance sub, MTX amp, interior vinyl wrap
    HP is at 322 on the initial dyno.... Will that increase with TC locked? I know these trucks are pretty fast once you get into the power band, so I'm guessing the increased torque down low will make it quicker off the line.
  18. Dec 30, 2019 at 2:06 PM
    #5398
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    My understanding is that unlocked the TC will generate heat and waste energy but you get a torque multiplication effect similar to being in 4LO. The engine is spinning faster than the transmission input from the torque converter.
    when it’s mechanically locked it’s transmitting power straight through with no inefficiency, but as the engine and tranny are physically locked together you don’t get the slip and rpm increase with unlocked TC.
    iDrew likes this.
  19. Dec 30, 2019 at 5:39 PM
    #5399
    soggyBottom
    soggyBottom Well-Known Member
    I think it'll be just fine. The torque on that graph is down so low that the HP is still relatively low. Even if we exaggerate the numbers and say the truck makes 800ft/lbs at 1300RPMs, it's still only 200hp (RPM×TQ÷5252=hp). I think the current low end numbers should make the truck very fun while still being easy to control.
  20. Dec 30, 2019 at 9:41 PM
    #5400
    TacoTim85
    Looking forward to seeing the next update after more tuning. :cool::cool::cool:
    Go ahead and buy yourself a stick shift Tacoma soon ... right after the doc clears you to use that arm :D.
Thread Status:
