OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Jan 2, 2020 at 7:35 AM
    #5501
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    So will the right side turbo be close to where the ARB Twin Air compressor mounts?
  2. Jan 2, 2020 at 8:19 AM
    #5502
    Speedwaytacotuesday
    Speedwaytacotuesday I love riding in my wife's Taco :p
    Calgary, Alberta
    2016 TACO LTD, 88 4runner, 4th Gen 4Runner
    TRD S/C 2.3" pulley mild ported Portmatched/cleaned intake runner Ucon EMS/cam gears/160 t-stat 840cc injectors 255 LPH walbro fuel pump Urd equal length headers Urd competition y-pipe AFE 3” Exhaust Vibrant resonator Oil Catch can Ratio-tek valvebody upgrade 3" bilstein/OME lift Dakar rear 7-leaf pack 32" KO2's load range C Stealth custom wheels Ray-10's Volk Te37X’s Tundra front 13.3” brakes Custom fab rock sliders LC-2 wideband autometer boost gauge Cravenspeed gauge pod mount Scangauge 2 SC MODS: Pulley ripp mod/belt wrap mod/ fleetrunner belt/ tensioner stop delete mod/ bypass jet delete mod
    Are you planning on offering the base kit the ability to run the 12-14 psi or will 10 psi be the cap?
  3. Jan 2, 2020 at 8:27 AM
    #5503
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Sounds like that's a possibility. If so, the air compressor can be mounted elsewhere with ease. The turbos not so easily.
  4. Jan 2, 2020 at 8:39 AM
    #5504
    jerzsubbie
    jerzsubbie Well-Known Member
    Davidson, NC
    ‘13 GX460
    If boost is linear and we assume a stock truck makes 225whp, then higher boost would look like this.
    WHP ___ PSI
    225 __ 0
    325 __ 6
    358 __ 8
    392 __ 10
    425 __ 12
    458 __ 14
    10psi would be absolutely perfect IMO! I may also be wrong and all that down low torque could be a total game changer giving us a ton of what this truck is missing, exactly where it's missing. Personally, I'd love to get the kit, run it at 6psi, and have the ability to switch to 10psi with relative ease (maybe wastegate spring & tune).
    Lord Helmet likes this.
  5. Jan 2, 2020 at 8:40 AM
    #5505
    Hawks4life
    Hawks4life Well-Known Member
    Joe
    25 Tacoma Pro
    Full PPF, tinted windows, hood struts, hitch pod reverse light.
    So here in NM I'm at 7000 ft. how much HP loss do you think I will be at, and what recommendations, i.e. how much more boost and any
  6. Jan 2, 2020 at 8:42 AM
    #5506
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    if there's a switch or easy way to switch max boosts that would be great. 6-10 psi daily driving, 10+ race mode, but for offroading when I gotta be rough on the truck I would like to detune it maybe slightly below 6 psi.
    jerzsubbie[QUOTED] likes this.
  7. Jan 2, 2020 at 8:47 AM
    #5507
    Shellshock
    Iowa
    I feel like boost psi is becoming the new shift point argument
    I’ll go with what mat recommends and not worry about it. He knows these trucks better than anyone else.
  8. Jan 2, 2020 at 8:55 AM
    #5508
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Yeah but if u run 31.6 PSI in your tires and atmospheric pressure at 4,221' with octane booster in the truck you should be able to run a 6.42 psi spring in the waste gate. It's simple scientific geology.
  9. Jan 2, 2020 at 8:57 AM
    #5509
    Turd Hawg
    Turd Hawg Well-Known Member
    2018 DC SB OR AT (Sold)
    Ha, was just thinking the same. Tune for 8psi, tune for 9psi, tune for 8.5....
    Dirk Diggler likes this.
  10. Jan 2, 2020 at 9:03 AM
    #5510
    Speedwaytacotuesday
    Calgary, Alberta
    Hahaha true..but is there a tune for 14psi
    Seriously
  11. Jan 2, 2020 at 9:05 AM
    #5511
    Speedwaytacotuesday
    Calgary, Alberta
    Trying to see a way out of going with the big boi’s but I think I know what I must do
  12. Jan 2, 2020 at 9:07 AM
    #5512
    Shellshock
    Iowa
    Buy once cry once
    no one has ever complained about having too much power
    ihatemytruck, mZiggy and 20tacoma17 like this.
  13. Jan 2, 2020 at 9:10 AM
    #5513
    Speedwaytacotuesday
    Calgary, Alberta
    Those are truly words of wisdom my friend
    ihatemytruck likes this.
  14. Jan 2, 2020 at 9:13 AM
    #5514
    Shellshock
    Iowa
    Or buy once, decide you want more and make someone a sweet deal when you upgrade lol
  15. Jan 2, 2020 at 9:15 AM
    #5515
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    This is true. The smaller kit will have its limits at around 12psi. The bigger kit approximately double that but you can always run the bigger kit at 10-12psi and always have more if you want it.
    Speedwaytacotuesday likes this.
  16. Jan 2, 2020 at 9:19 AM
    #5516
    Max713
    Max713 Well-Known Member
    Max
    Eugene, OR
    2017 MGM TRD OR
    Any chance of dyno results of 8 or 10 psi on the base kit?
    Don't even need a chart, just curious of "official numbers". 325whp looks great, just hoping for a little closer to 400whp without stepping up to the powermax's.
  17. Jan 2, 2020 at 10:20 AM
    #5517
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    If, and this is an "if" right now. If I can setup some custom code, I can use the purge valve to run a boost controller, and press the ECT button you bump up a few psi.
    This has been planned from the beginning because ECT will also be switching to a different map on the boost tunes.
    That's an "if" though. I need to sort out the code.
    I don't plan on doing a dyno on 10psi right now. I want to get baseline numbers out for both kits first.
  18. Jan 2, 2020 at 10:22 AM
    #5518
    Max713
    Max
    Eugene, OR
    2017 MGM TRD OR
    That would be beyond cool...
    I'm going to go out a on limb and assume squeezing close to 400whp out of the base kit is pretty attainable without further modification?
  19. Jan 2, 2020 at 10:27 AM
    #5519
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    What are the drawbacks, if there are any, of running increased boost as opposed to low boost?
  20. Jan 2, 2020 at 10:29 AM
    #5520
    whitedlite
    USA!
    3RD Gen TRD 4WD
    Drawbacks are simple. more power more problems, same with money.
    Of course there's no guarantee you'll experience more problems, but there's more probability, but it will be worth it.
Thread Status:
