OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Jan 17, 2020 at 8:08 AM
    #5881
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
  2. Jan 17, 2020 at 8:09 AM
    #5882
    roth_nj
    roth_nj Well-Known Member
    2017 DCLB trd off-road bbp
    im so confused with life......
    tune, dump tubes, twin turbos, gears, shelby gt350.................................
    joey.taco, d.ustn, TacoRD16 and 3 others like this.
  3. Jan 17, 2020 at 8:35 AM
    #5883
    gumpjr23
    gumpjr23 Well-Known Member
    2016 Double cab Off Road
    I have been slacking a little in this thread (caught up on maybe the last 30pages) have the base kit numbers been released? I know we're all waiting on the powermax numbers..
    Money not being a major issue, but bang for buck being more relevant.
    Thanks guys!
  4. Jan 17, 2020 at 8:52 AM
    #5884
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Yeah they're out there somewhere
  5. Jan 17, 2020 at 9:00 AM
    #5885
    soggyBottom
    soggyBottom Well-Known Member
    But those still use standard port injection as the primary fuel source right?
    Sleipnir likes this.
  6. Jan 17, 2020 at 9:03 AM
    #5886
    Max713
    Max713 Well-Known Member
    Max
    Eugene, OR
    2017 MGM TRD OR
    gumpjr23[QUOTED] likes this.
  7. Jan 17, 2020 at 9:13 AM
    #5887
    Speedwaytacotuesday
    Speedwaytacotuesday I love riding in my wife's Taco :p
    Calgary, Alberta
    2016 TACO LTD, 88 4runner, 4th Gen 4Runner
    TRD S/C 2.3" pulley mild ported Portmatched/cleaned intake runner Ucon EMS/cam gears/160 t-stat 840cc injectors 255 LPH walbro fuel pump Urd equal length headers Urd competition y-pipe AFE 3” Exhaust Vibrant resonator Oil Catch can Ratio-tek valvebody upgrade 3" bilstein/OME lift Dakar rear 7-leaf pack 32" KO2's load range C Stealth custom wheels Ray-10's Volk Te37X’s Tundra front 13.3” brakes Custom fab rock sliders LC-2 wideband autometer boost gauge Cravenspeed gauge pod mount Scangauge 2 SC MODS: Pulley ripp mod/belt wrap mod/ fleetrunner belt/ tensioner stop delete mod/ bypass jet delete mod
    I’ve been back and forth on those numbers. Unless the base kit can squeeze another 50hp/tq with more boost I will be essentially going backwards in power. Will have to see the powermax numbers.. Hmmm what to do?
    gumpjr23 likes this.
  8. Jan 17, 2020 at 9:20 AM
    #5888
    mkivsoopra
    mkivsoopra Member
    2018 Tacoma TRD Off-Road
    Ready for base kit :)
  9. Jan 17, 2020 at 9:23 AM
    #5889
    naked farmer
    naked farmer Well-Known Member
    Nor Cal
    ‘17 B.Red Off Road
    I’m ready to purchase a kit
  10. Jan 17, 2020 at 9:24 AM
    #5890
    Max713
    Max
    Eugene, OR
    2017 MGM TRD OR
    He said 380+ is definitely possible with the base kit. Those number are at 6psi, he also says the base kit will be capable of 12-14psi. I'm hoping for 400whp myself :D
  11. Jan 17, 2020 at 9:31 AM
    #5891
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    That's on 6psi.
    run our fuel pump controller and fuel pump and run more boost.
  12. Jan 17, 2020 at 9:32 AM
    #5892
    Rexus Ranger
    Rexus Ranger Well-Known A-Hole
    Albert
    Reno, NV
    2018 TRD Off-Road
    I just bought another car, so no go for me. I'll be on the sideline cheering people on. :thumbsup:
    SC4333 and Skydvrr like this.
  13. Jan 17, 2020 at 9:34 AM
    #5893
    TWTaco
    TWTaco Well-Known Member
    Dave
    That was a question i had ,will the fuel pump controller and fuel pump work with base kit and is it recommended or is it more of a must have?
  14. Jan 17, 2020 at 9:35 AM
    #5894
    Max713
    Max
    Eugene, OR
    2017 MGM TRD OR
    Required for more than 6psi?
  15. Jan 17, 2020 at 9:37 AM
    #5895
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I have no idea, obviously, but I bet it's around 12-13psi before you run outa fuel.
  16. Jan 17, 2020 at 9:37 AM
    #5896
    OVTune
    OVTune
    I tested *up to* 10 psi with the completely stock fuel system. (PEAK of 10psi, not 10psi @ rev limit. Tapering down to about 5psi at rev limit, peak 10psi at about 2000 rpm) and it was OK, but beyond that definitely it's needed.
  17. Jan 17, 2020 at 9:37 AM
    #5897
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    Not going to read back but I asked for an explanation a good while back about horse power ratings on his graphs or even words. I was having a hard time seeing value in a truck that supposedly got 278 hp from factory and with the turbo kit bumping it up to 325. Just didn’t seem like much but his added hp ratings were at the wheel which our truck gets something around 200 at the wheel stock. That said it’s a worthy investment just for the base kit alone for the cost difference. Essentially it adds over 100 hp at the wheel where it matters and that’s plenty sufficient for me. I can’t imagine a midsized truck with that much hp at the wheel being able to even slightly keep traction with so little weight in the back.
    Another thing about crazy amounts of hp at the wheel on our trucks made me think that the big turbo kit was that spending wouldn’t stop at just the turbo purchase and install as more modifications to the truck would be needed to handle that much power. I could be wrong but the base kit will be plenty sufficient for me personally.
  18. Jan 17, 2020 at 9:41 AM
    #5898
    TWTaco
    Dave
    Thanks good to know will be adding it to base kit as of now may change to power kit dont want to regret not getting the big boys! Count me in.
    Speedwaytacotuesday likes this.
  19. Jan 17, 2020 at 9:45 AM
    #5899
    Fozzymandius
    Fozzymandius Well-Known Member
    2018 Black TRD DCSB
    Currently Stock
    And based on where he claims max torque (~2500rpm i believe) there will be an even larger difference than what max figures would have you believe. The turbo tacoma will certainly be able to burn rubber as the stock motor struggles with like 150lbft at 3k and much less below that (though his stock dyno numbers show much less below that, I'm not sure he was able to get great numbers at lower rpm due to the shift logic.)
  20. Jan 17, 2020 at 9:52 AM
    #5900
    OVTune
    OVTune
    The base kit was tested on ~6 psi.
    It's capable of around12-14psi before temperatures go out of boundary.(peak!. 14psi @ rev limit will be a flame thrower. Expect closer to 7-9psi @ limit)
    It will not make what the powermax does, but there is still plenty of power left in the base kit.
    That being said, it is a BASE kit and is not ideal if you're looking to make the bigger numbers.
    It does not come with the required fuel system upgrades.
    Also our fuel pump controller does NOT function with the stock fuel pump. You have to upgrade to our pump.
Thread Status:
