OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Jan 17, 2020 at 4:31 PM
    #5921
    OriginalMan
    OriginalMan Well-Known Member
    Oahu 808
    2017 TRD OR 4x4
    Bilstein 5100/888; 5160/AAL; SCS Ray10 Limited Gold; 285/70 Cooper STT PRO; AVS; OVTuned; Prinsu Cabrac; RCI Bedrack; TC Bed Stiffner
    Would love the kit but I have an automatic. Manual owners will have more fun.
  2. Jan 17, 2020 at 4:46 PM
    #5922
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Can't remember 100% because I sold ms3 in 2016 but I believe DI is the primary. I could be wrong.
  3. Jan 17, 2020 at 6:08 PM
    #5923
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    And? It'll be fun regardless of trans type.
  4. Jan 17, 2020 at 6:12 PM
    #5924
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    LOL. I’m thinking.... I don’t want to have the cheesecake, because I can’t have the CHOCOLATE cheesecake.
  5. Jan 17, 2020 at 8:32 PM
    #5925
    hcenteno21
    hcenteno21 Well-Known Member
    Tito
    El Paso, TX
    2020 AG Tacoma TRD Pro Supercharged
    +1 for base.. possibly powermax
  6. Jan 17, 2020 at 8:47 PM
    #5926
    TacoTim85
    TacoTim85 Well-Known Member
    Vancouver, Washington
    2007 4Runner Sport Edition 4WD (Current)
    Couple questions.
    What psi/power output to the wheels is possible with the base kit without upgrading the fuel system?
    What needs to be done to increase the boost on base kit over 6 psi? Electronic wastegate control through tunes or addition of hard parts?
    Correct me if I said anything dumb, but I think I understand the basics.
    hcenteno21 likes this.
  7. Jan 17, 2020 at 8:59 PM
    #5927
    TacoTim85
    Also, what is the reason for the boost tapering off as rpms increase on the base kit? Limited by turbo size?
  8. Jan 17, 2020 at 10:17 PM
    #5928
    JackwagenR
    JackwagenR Well-Known Member
    Jack
    2017 Silver Sky Metallic Tacoma TRD Off Road Double Cab 6' Bed V6 4x4 AT
    Stock
    Can you show pulls of the base and powermax on the street/pavement? I likely don’t need Powermax levels, but really like the idea of stock-ish bolt ons without fueling changes.
    That’s as far as I got with my Golf R
  9. Jan 18, 2020 at 1:02 AM
    #5929
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Sorry. That’s fake news
    SC4333 and Torspd like this.
  10. Jan 18, 2020 at 6:55 AM
    #5930
    RushT
    North Texas
    @OVTune,
    Any news or data on your towing experience? Recently you posted on going to tow with the TT kit. I’m guessing you were going to get qualitative experience and quantitative data on temps and gear performance.
  11. Jan 18, 2020 at 6:59 AM
    #5931
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    That, along with some more driving tests are still planned. The fuel pump set back took time out of how I planned this testing to go. So, that is all still going to be tested, but after we get a set back from our manufacturer.
    RushT[QUOTED] and ian2016 like this.
  12. Jan 18, 2020 at 7:05 AM
    #5932
    RushT
    North Texas
    Appreciate it. Tune alone is fine for my DD taco. But a bit Mo Powuh is needed for any distance towing.
    gumpjr23 likes this.
  13. Jan 18, 2020 at 8:21 AM
    #5933
    OVTune
    OVTune
    This is normal on any turbo engine. If you use only the wastegates to control boost there will be taper. To stop tapering you use a boost controller
  14. Jan 18, 2020 at 10:28 AM
    #5934
    harlequin_forest
    harlequin_forest Well-Known Member
    Oregon
    TRD OR 6MT , 2.0 SFOB
    No it isn't
  15. Jan 18, 2020 at 10:40 AM
    #5935
    Speedwaytacotuesday
    Speedwaytacotuesday I love riding in my wife's Taco :p
    Calgary, Alberta
    2016 TACO LTD, 88 4runner, 4th Gen 4Runner
    TRD S/C 2.3" pulley mild ported Portmatched/cleaned intake runner Ucon EMS/cam gears/160 t-stat 840cc injectors 255 LPH walbro fuel pump Urd equal length headers Urd competition y-pipe AFE 3” Exhaust Vibrant resonator Oil Catch can Ratio-tek valvebody upgrade 3" bilstein/OME lift Dakar rear 7-leaf pack 32" KO2's load range C Stealth custom wheels Ray-10's Volk Te37X’s Tundra front 13.3” brakes Custom fab rock sliders LC-2 wideband autometer boost gauge Cravenspeed gauge pod mount Scangauge 2 SC MODS: Pulley ripp mod/belt wrap mod/ fleetrunner belt/ tensioner stop delete mod/ bypass jet delete mod
    Doesn’t have to be a manual to enjoy extra power especially in this truck. Coming from somebody whose ever only owned Manuals other than my two tacos
  16. Jan 18, 2020 at 11:24 AM
    #5936
    OVTune
    OVTune
    our test truck is an auto......
  17. Jan 18, 2020 at 11:25 AM
    #5937
    TacoTim85
    So what is needed to increase peak boost over 6 psi on the base kit? A boost controller?
    What power numbers did you see before temps got unmanageable/ fuel ran out?
  18. Jan 18, 2020 at 11:27 AM
    #5938
    OVTune
    OVTune
    Yes a boost controller.
    I only dyno tested the base kit on 6psi. Because that is what we are advertising the kit with. I had no plans of testing the limits of the base kit, because we have a bolt on bigger turbo option.
  19. Jan 18, 2020 at 11:54 AM
    #5939
    TacoTim85
    Yeah, I get that. I thought you mentioned running it up to a higher boost, though. Bigger kit is probably overkill for some of us, or out of the price range for some.
    I'm sure some of us are considering what the base kit is capable of before making the choice to go with the larger kit. I understand you don't want to advertise or guarantee a certain number because all circumstances considered it could vary a bit. A range would be nice to know pre-purchase.
    As far as turning up the boost on either kit, will a custom tune be provided or how will that go?
    Thanks.
  20. Jan 18, 2020 at 12:02 PM
    #5940
    OVTune
    OVTune
    Yes I ran and tested 10psi peak on the street.
    Important to understand peak. That means 10psi at very low rpm but the same taper as 6. The stock fuel system will NOT handle 10psi with no boost taper.
    When you factor the price difference between the two, a lot of that is the fuel system upgrades.
    Both the base kit and the powermax use the same intercooler piping, downpipes, etc.
    The powermax kit does come with some more robust turbo lines.
    If you factor a base kit + all fuel system upgrades needed to consistently run higher boost you're not that far off of the powermax kit.
Thread Status:
