OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Jan 31, 2020 at 6:19 AM
    #6101
    XUT
    XUT Well-Known Member
    Question: Say you're running 5lbs of boost capped. Assuming you don't drive like a total asshole, how much impact would it have on the natural wear of the engine? I figured these trucks didn't come with turbos because: A. They're expensive B. They take life off of the motor making warranty claims (which equates to money).
    Sorry, this horse may have been beat to death in the 300 page thread, but I am just curious.
    ian2016 likes this.
  2. Jan 31, 2020 at 7:49 AM
    #6102
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Boost of 5#s doesn't kill an engine, poor tuning does. OV knows how to tune. Engine life won't be a problem with proper maintenance.
  3. Jan 31, 2020 at 7:51 AM
    #6103
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Ov has said and others agree tuning is crucial as well as regular maintenance for all components involved
  4. Jan 31, 2020 at 7:54 AM
    #6104
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    He also said that this 3.5 "loves the boost". 5# is not the issue. Proper tuning and maintenance is. Mat has the tune covered, it's on you to do the maintenance.
  5. Jan 31, 2020 at 8:15 AM
    #6105
    dirtydeeds
    dirtydeeds Well-Known Member
    Our barometric pressure is already about 14psi. In the scheme of things 5 more isn’t really that much. Especially on an engine that was clearly designed for boost, but for some reason was never fitted with turbos.
  6. Jan 31, 2020 at 8:21 AM
    #6106
    Max713
    Max713 Well-Known Member
    Max
    Eugene, OR
    2017 MGM TRD OR
    PSI is just a number... these turbos at 5psi are forcing far more air into the motor than the atmospheric pressure ever could, many times over.
    jerzsubbie and Skydvrr like this.
  7. Jan 31, 2020 at 12:54 PM
    #6107
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Math?
    I'm missing the supporting argument for that. I could just be ignorant on the process.
  8. Jan 31, 2020 at 1:08 PM
    #6108
    Max713
    Max
    Eugene, OR
    2017 MGM TRD OR
    No math needed... 5psi out of a straw or 5psi out of a 6 foot culvert, which on flows more?
    The point is that the "5psi" or "14psi" number is irrelevant without the other known factors. Atmospheric pressure and boost pressure are measured in totally different ways, and anyone that thinks that every vehicle is forced induction with 14psi of boost because of atmospheric pressure is off their rocker.
  9. Jan 31, 2020 at 1:22 PM
    #6109
    RushT
    North Texas
    Okay, so there's a teachable moment here. I'm the student... stating my assumptions.
    Current pressure on an open intake valve is 14PSI. Boost pressure on a FI intake valve would be 19PSI (5PSI boosted). The straw hasn't changed, so do we not assume that this is 35.7% increase in available fuel catalyst?
    xxTacocaTxx likes this.
  10. Jan 31, 2020 at 1:30 PM
    #6110
    Max713
    Max
    Eugene, OR
    2017 MGM TRD OR
    No. PSI is just a number. 5psi from a tiny ecoboost turbo, and 5psi from a D8 cat turbo are not the same. You cannot quantify the increase in available fuel catalyst simply by PSI.
    @OVTune help please. I don't have the knowledge or vocabulary to explain this like you do.
    RushT[QUOTED] likes this.
  11. Jan 31, 2020 at 1:43 PM
    #6111
    Shellshock
    Iowa
    I’m not sure what we are arguing about...
    Obviously 5 psi at different volumes is different amounts of air.
  12. Jan 31, 2020 at 1:43 PM
    #6112
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    Either way it’s more go faster..... faster :)
    Inferno! and Shellshock[QUOTED] like this.
  13. Jan 31, 2020 at 1:46 PM
    #6113
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Essentially you are pressurizing the intake manifold to 5 psig which is 5 psi greater than atmospheric which is 0 psig. The only difference between 5 psi on our little V6 and a Powerstroke V8 is the volume of air that gets pressurized. At least that’s according to the quick research I’ve done
    YOTA 4X4, ihatemytruck and Shellshock like this.
  14. Jan 31, 2020 at 1:53 PM
    #6114
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    The golden rule of turbos: Boost itself is irrelevant...airflow is everything.
    SC4333 and Max713 like this.
  15. Jan 31, 2020 at 2:07 PM
    #6115
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I thought manifold pressure was basically in a vacuum. Engine sucks more than the atmosphere can provide, NA. Turbo is actually pressurizing the intake.
    ETA: not more than the atmosphere can provide, but u get the idea. Turbo is "overfilling" and cramiing more air in, as opposed to the Pistons having to suck the air in
  16. Jan 31, 2020 at 2:14 PM
    #6116
    Anchovy
    TRD Ferguson
    On a NA engine, the intake manifold is in a vacuum but when you use forced induction you are pressurizing the intake so you can physically shove more air, more oxygen into the cylinders to make more power and torque
  17. Jan 31, 2020 at 2:26 PM
    #6117
    dirtydeeds
    I’m seriously not going to sit there and argue about 5 psi LOL. Most guys got my point. And yes, I am off my rocker;)
    The engine won’t wear faster with only 5lbs of boost. Most engines can handle that little boost with archaic old school ‘techniques’ rather than a tune. Having Mathew’s tune with 5psi is still as reliable as if Toyota had included a turbo option in the first place;)
    Brostjoe likes this.
  18. Jan 31, 2020 at 8:36 PM
    #6118
    RushT
    North Texas
    Ok, I see where you’re going here. You’re suggesting that the cross sectional area of the turbo outlet is ‘far greater’ than the normal manifold input cross section, thus the straw and culvert comparison.
    I’m following an argument that a ‘tiny turbo’ with a minuscule cross section won’t have a proportional impact no matter the boost pressure. Your argument holds water if the outlet of the turbo is much greater than the normal manifold intake. If the two are approximate, I’m not sold yet on the ‘far more’ conclusion.
  19. Feb 1, 2020 at 3:09 AM
    #6119
    Venator_2033
    Venator_2033 Well-Known Member
    4" inch lift Dakar leafpacks/Bilstein 5100 B110/Fox 2.0 coil-overs/Catless Dual Exhaust w/H-pipe/OVtuned1.05/RCI Sliders/HID kits Hi/Low/AFE Intake with scoop and 76mm throttle body/Total chaos Fab UCA's
    These threads might help you better understand what max713 is saying.
    https://www.rx7club.com/single-turbo-rx-7s-23/boost-pressure-vs-airflow-question-637225/
    And
    https://www.rx7club.com/3rd-gen-archives-73/why-bigger-turbos-make-more-hp-same-psi-645551/
    They're an interesting read.
  20. Feb 1, 2020 at 8:57 AM
    #6120
    TWTaco
    TWTaco Well-Known Member
    Dave
    Does the store wide discount work for the Turbo kits?
Thread Status:
