OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Feb 5, 2020 at 8:32 AM
    #6181
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    2GR-FKS bottom end is forged and I don't see the need for pistons yet.
  2. Feb 5, 2020 at 4:01 PM
    #6182
    OVTune
    OVTune
    Components are on the way.
    Should wrap up out fueling issues and be on track to finish this up.
  3. Feb 5, 2020 at 4:04 PM
    #6183
    Bigetaco22
    Bigetaco22 Well-Known Member
    Kenny
    2016 DCSB TRD OR
    Bilstein 6112/5160s. OME leaf springs. 285/75/16. RC tonneau cover. Supernova v3 led lows, highs, and fog lights. Kicker speaker upgrade.
    Happy birthday!
    New fuel rails? New hpfp?
  4. Feb 5, 2020 at 4:21 PM
    #6184
    OVTune
    OVTune
    will show after testing.
    But fingers crossed, it might just solve all our fuel issues, and make fuel upgrades 100x simpler.
  5. Feb 5, 2020 at 4:36 PM
    #6185
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    What I was going to say was that @OVTune has infinitely more knowledge than me on that engine. I have not ever looked up what the OEM rods nor pistons look like. Nor what they are made of. Unlike the 1GR with its powder cast rods, and flimsy ringlands on hyper eutectic pistons.
    I have not yet dyno'd mine. I was unhappy with the specific grinds that I have from Kelford camshafts. As no matter what tuning was done, the low end torque was just not there. Independent of the turbo. Although plenty of mid and high power. I just recently swapped out the intake cams and now I need to swap out the exhaust cams. Then do more testing.
    *Edit* I am not unhappy with the quality of the Camshafts. Of the OEM regain the low end, then I will discuss with Kelford a better profile to have these ground to.
    My engine is built for more than the 9180 can put out. The transmission is the weak link. For now. ;)
  6. Feb 5, 2020 at 4:46 PM
    #6186
    OVTune
    OVTune
    I have a spare 2GR-FKS engine I managed to snag for a few hundred bucks, so I can get info and measurements on any part.
    The stock bottom end is stupid beefy. Con-rods are forged steel, crank is forged steel, fully counterweight, with excellent heat treatment.
    No sintered iron or crack cap components.
  7. Feb 5, 2020 at 4:56 PM
    #6187
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Any availability on APR head studs? How well do you feel the head gaskets and OEM bolts(assuming TTY) will hold up, to "x" power? Too many unknowns for me to be more specific.
    That is a major plus! Just means the fueling system, and transmission components will be the next areas to address. Once those limits are found. Since you're already addressing the fueling, then the transmission is left.
    skyking3 likes this.
  8. Feb 5, 2020 at 5:05 PM
    #6188
    OVTune
    OVTune
    so the fuel system upgrade I'm going to be testing may be our saving grace that eliminates... all other required components.
    Which means if this works, no in tank upgrade needed, no port injector upgrade needed. that's a "if" at the moment. When the parts arrive we will know for sure.
    Unfortunately though, it will mean some price change on the PowerMax kit. (not a lot).
    In regards to how much power this engine can hold.. No idea right now.
    But I have put 500 + ft lbs to the rear axle @ 2500 RPM. Not just once, but multiple times, and during fuel logging I have held it at that on my dyno at full boost for 20-30 second periods.
    This engine is just...so well made it's ridiculous.
    ANY other N/A engine you put 18psi down it's throat and hold it on the dyno at 500+ ft lbs for 30 seconds you're picking it up connecting rods off the floor.
    I've put my engine through hell and back and then some.
    18psi, in general, on an unbuilt N/A engine is just unheard of. My engine should have blown up twice by now with what I've put it through.
    what I find just as surprising is with the torque converter fully locked there is no slip even at 500 ft lbs.
  9. Feb 5, 2020 at 5:10 PM
    #6189
    OVTune
    OVTune
    If you look online, you will see raptors run around 20psi on these powermax turbos (very few, since they are so new). That's a overbuilt 3.5L made specifically for boost.
    Using these same turbos I'm 2psi short of what these raptors are out there doing.
    on an engine never made for boost.
    I love this engine. But I do question wtf Toyota was thinking with the fuel system.
    I also question why Toyota is 10+ years behind the curve on engine calibrations logic when it comes to controlling fuel... but uses rocket science 4 dimensional pandoras box for controlling ignition.
  10. Feb 5, 2020 at 5:25 PM
    #6190
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Nice to know the 3.5 is over built and can take an ass beating.
  11. Feb 5, 2020 at 5:54 PM
    #6191
    Kclamer
    Kclamer Well-Known Member
    Konstantin
    2018 Toyota Tacoma TRD Off-Road 4x4
    2.5" lift, 4.88 gears
    Mat its all because each system is developed by different engineers. Some are 70 years old and still do things the way it was done 30 years ago, some are fresh out school and think what they learned in their programming class is a great idea though through their lack of experience it turns out like shit. I work with design engineers and know how it goes as I do project management for them.
    xxTacocaTxx and WalkinTaco like this.
  12. Feb 5, 2020 at 5:57 PM
    #6192
    Kclamer
    Konstantin
    Do you think the fuel upgrade would benefit a NA engine by providing fueling stability? I may be interested in buying that piece you are developing.
  13. Feb 5, 2020 at 6:21 PM
    #6193
    WalkinTaco
    WalkinTaco Well-Known Member
    2018 TRD OR M/T
    now the question is, can the manual trans stand up to the same beating (with an up rated clutch obviously)...
  14. Feb 5, 2020 at 6:44 PM
    #6194
    Speedwaytacotuesday
    Speedwaytacotuesday I love riding in my wife's Taco :p
    Calgary, Alberta
    2016 TACO LTD, 88 4runner, 4th Gen 4Runner
    TRD S/C 2.3" pulley mild ported Portmatched/cleaned intake runner Ucon EMS/cam gears/160 t-stat 840cc injectors 255 LPH walbro fuel pump Urd equal length headers Urd competition y-pipe AFE 3” Exhaust Vibrant resonator Oil Catch can Ratio-tek valvebody upgrade 3" bilstein/OME lift Dakar rear 7-leaf pack 32" KO2's load range C Stealth custom wheels Ray-10's Volk Te37X’s Tundra front 13.3” brakes Custom fab rock sliders LC-2 wideband autometer boost gauge Cravenspeed gauge pod mount Scangauge 2 SC MODS: Pulley ripp mod/belt wrap mod/ fleetrunner belt/ tensioner stop delete mod/ bypass jet delete mod
    Just to be clear, because the above components in the powermax kit are no longer needed does that mean the kit will be slightly cheaper or slightly more?
  15. Feb 5, 2020 at 6:53 PM
    #6195
    OVTune
    OVTune
    TBD
    It is perplexing me that different parts of the engine were designed by different engineering teams who didn't discuss with one another.
    But you're right, when I talked to the engineers at the plant that does this engine, they said everything is compartmentalized and they not only do not discuss with other component teams, but they aren't even allowed to.
    So the team that made the engine has no communication with the team that made the transmission, or team that makes anything else.
    The machinists don't even know what they machine, they just have specs and machine it. ( as I understand it).
    I'm not an auto manufacturer but it sounds like a engineering and logistical nightmare.
    Can you imagine the guys making fuel rails not even know that it's a fuel rail? Lol
    I don't see any benefit. NA is not using enough fuel to cause big pressure drops.
  16. Feb 6, 2020 at 4:09 AM
    #6196
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That's extremely impressive! With just a GT35xxR, on a stock 1GR, it won't hold 10 psi for long.
    Sleipnir likes this.
  17. Feb 6, 2020 at 8:08 AM
    #6197
    roth_nj
    roth_nj Well-Known Member
    2017 DCLB trd off-road bbp
    while not exactly apples to apples, i can't help but think of the reputation for the 2JZ when you talk about stuff like this.
    i know basically nothing about the internals of those engines, and i say its not apples to apples because they came both NA and turbo'd... but the reputation is that they are bullet proof and can handle tons of boost.... so its not unprecedented for toyota to over build an engine
    GillyLink and Shellshock like this.
  18. Feb 6, 2020 at 8:16 AM
    #6198
    roth_nj
    on that note, i was just doing some quick browsing on the GR family. how do the 2GR-FE/R and 2GR-FKS compare to eachother? because there are some supercharged FE's
  19. Feb 6, 2020 at 8:23 AM
    #6199
    OVTune
    OVTune
    All 2GRs are pretty strong, but the 2GR-FE is the weakest of the 3 (2GR-FE, 2GR-FSE, 2GR-FKS). Even being the weakest it can hold 400+HP all day long. I've tuned the S/C Lotus with these engines, handles it no problem. And it's an off the shelf 2GR-FE, not a built bottom end by lotus.
    Inferno__Taco and bladsville like this.
  20. Feb 6, 2020 at 8:34 AM
    #6200
    bladsville
    bladsville Well-Known Member
    DFW
    2017 TRD Off-Road 4X4 MT
    The JZ advantage over the GR is that the JZ uses an iron closed-deck block whereas the 2GR-FKS uses an aluminum open-deck block. For people who dont know what that means, the cylinders in the GR motor are essentially "floating" inside an aluminum block and have a path for coolant to surround the cylinder. That is a bit weaker than the JZ block where the cylinders are pretty much punched in a solid iron piece. This allows the block to hold a lot more power without a weak point.
    However, I don't see the block being an issue at the power levels that this kit is going to make as long as tuning is done properly, which seems like OV-Tune is more than on top of.
Thread Status:
