OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Apr 7, 2020 at 9:47 AM
    #6501
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    This guy saw it too!
  2. Apr 7, 2020 at 9:52 AM
    #6502
    Mecca
    Mecca Member
    Anthony
    ‘17 TRD 4x4 OR
    Is there still going to be the discounted price for us that have the tune already?
  3. Apr 7, 2020 at 9:56 AM
    #6503
    BoneTaco
    BoneTaco Well-Known Member
    Sacramento, CA
    17 DCLB OR
    Excited to see what kind of mileage you will get once you get it on the road
  4. Apr 7, 2020 at 10:28 AM
    #6504
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    AFR in the air vent? Nice!
  5. Apr 7, 2020 at 1:10 PM
    #6505
    Shellshock
    Iowa
    No one is gonna want to let off the skinny pedal so probably not great lol
  6. Apr 7, 2020 at 1:47 PM
    #6506
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
  7. Apr 7, 2020 at 6:06 PM
    #6507
    jdmfreak1992
    jdmfreak1992 Well-Known Member
    Taylor
    2017 Tacoma TRD Off-Road
    Stock for now
    If your customers have a problem with the turbos being too loud you don't need them as customers. That's commie hipster speak and they should be banished. Everyone loves choo choo noises.
  8. Apr 7, 2020 at 7:30 PM
    #6508
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Alrighty guys I plan to wrap this up by friday, and then send the manifolds off for casting.
    I need to finish up some new wastegate brackets on the CNC.. then we will be looking into getting some turbo kits out into the wild.
    Also..there will just be 1 intercooler option. No need to over complicate things.
  9. Apr 7, 2020 at 7:33 PM
    #6509
    BoneTaco
    Sacramento, CA
    17 DCLB OR
    Ohhhh shiiiiiiiit
  10. Apr 7, 2020 at 7:37 PM
    #6510
    Bigetaco22
    Bigetaco22 Well-Known Member
    Kenny
    2016 DCSB TRD OR
    Bilstein 6112/5160s. OME leaf springs. 285/75/16. RC tonneau cover. Supernova v3 led lows, highs, and fog lights. Kicker speaker upgrade.
    You have no idea how happy this makes me. I was so close to calling it quits with this truck. I have had the money set aside for this project for quite awhile.
    slow.taco and o313 like this.
  11. Apr 7, 2020 at 8:00 PM
    #6511
    OVTune
    OVTune
    first page has been updated.
    Kit and fuel system has been split.
    Powermax kit requires at a minimum, DI upgrade.
    Base kit does not, but base kit + DI Upgrade = higher boost thresholds possible.
    Powermax kit + DI upgrade alone is good up to 14psi
    Powermax kit + D4-S + Intank is good up to = 22psi (ethanol, methanol required).
  12. Apr 7, 2020 at 8:02 PM
    #6512
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    Excellent to hear! I hope the demand outstrips your supply... though that has its own headaches.
  13. Apr 7, 2020 at 8:23 PM
    #6513
    Bigetaco22
    Kenny
    2016 DCSB TRD OR
    So just to clarify, the base kit is just as it was before but includes a new in tank pump now?
    Found my answer a few pages back
  14. Apr 7, 2020 at 8:43 PM
    #6514
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Well do tell!
  15. Apr 7, 2020 at 8:44 PM
    #6515
    Bigetaco22
    Kenny
    2016 DCSB TRD OR
    Says the base and the base powermax come with drop in fuel pump upgrade.
  16. Apr 8, 2020 at 5:11 AM
    #6516
    OVTune
    OVTune
    Yes. Base and powermax both have drop in fuel pump upgrade.
    D4-S+ In Tank upgrade is a bigger fuel pump, upgraded DI injectors, upgraded Port injectors, and fuel pump controller
    AKGSD, Tea-coma and Sleipnir like this.
  17. Apr 8, 2020 at 5:39 AM
    #6517
    Venator_2033
    Venator_2033 Well-Known Member
    4" inch lift Dakar leafpacks/Bilstein 5100 B110/Fox 2.0 coil-overs/Catless Dual Exhaust w/H-pipe/OVtuned1.05/RCI Sliders/HID kits Hi/Low/AFE Intake with scoop and 76mm throttle body/Total chaos Fab UCA's
    Is the boost controller still needed on the base kit for 10 psi tuning, or just the upgraded DI injectors? Also if it's both how would we go about adding the boost controller to our order if/when we decide to upgrade the DI injectors?
  18. Apr 8, 2020 at 8:43 AM
    #6518
    OVTune
    OVTune
    I don't plan to sell boost controllers.
    You can add your own
  19. Apr 8, 2020 at 9:06 AM
    #6519
    AnotherUser256
    AnotherUser256 Well-Known Member
    Magnuson TVS1900 Supercharger with 87mm pulley, Catted OVTune dumptubes, Doug Thorley 2.5in y-pipe, custom mufflers, 76mm Tundra throttle body, 5.29 Yukon gears, JamesT custom fuel rails, Yotawerx 87mm tune, Eibach Pro Truck Stage 2 suspension. And some other stuff.
    What is involved with Calibration? (The option on the OVTune order page)
  20. Apr 8, 2020 at 9:07 AM
    #6520
    Speedwaytacotuesday
    Speedwaytacotuesday I love riding in my wife's Taco :p
    Calgary, Alberta
    2016 TACO LTD, 88 4runner, 4th Gen 4Runner
    TRD S/C 2.3" pulley mild ported Portmatched/cleaned intake runner Ucon EMS/cam gears/160 t-stat 840cc injectors 255 LPH walbro fuel pump Urd equal length headers Urd competition y-pipe AFE 3” Exhaust Vibrant resonator Oil Catch can Ratio-tek valvebody upgrade 3" bilstein/OME lift Dakar rear 7-leaf pack 32" KO2's load range C Stealth custom wheels Ray-10's Volk Te37X’s Tundra front 13.3” brakes Custom fab rock sliders LC-2 wideband autometer boost gauge Cravenspeed gauge pod mount Scangauge 2 SC MODS: Pulley ripp mod/belt wrap mod/ fleetrunner belt/ tensioner stop delete mod/ bypass jet delete mod
    I know you highlighted “powermax kit requires at minimum, DI upgrade” but I have to ask anyways.
    Is it possible to purchase the TT kit with the powermax turbos and set the boost via boost controller to a safe lower boost within the capability of the stock fuel system and upgrade the fuel system at a later date?
Thread Status:
