OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Apr 13, 2020 at 6:23 PM
    #6701
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    I haven't had the spare time to pull my grill and peek around in there. If the weather cooperates tomorrow, I can look
    KanPanic likes this.
  2. Apr 13, 2020 at 6:33 PM
    #6702
    Lutrev
    Lutrev Well-Known Member
    2018 MT black pro
    2.0 SFOB OV tune, ADM, MESO v4,stage 1 tail,maps and dome,etc
    What I get out of it is the stock di are good to 6 pounds and anything above needs the DI replaced. I would love to see a stage 2 base kit with 8ish pounds or whatever works as a second option on the base kit. Right now I am unclear of what is available for the base with DI option as far as what boost you would get or tune?
    jerzsubbie likes this.
  3. Apr 13, 2020 at 6:45 PM
    #6703
    mZiggy
    mZiggy Honey badger
    Marc
    Maybe I'm wrong but I thought I read it was 10psi for base + DI
  4. Apr 13, 2020 at 6:57 PM
    #6704
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    when you consider pricing, and value, to power, consider the price of other FI options on the market.
    What do we know?
    $6500, or higher.
    Includes tune? Unknown
    Includes fuel mods? Unknown
    Likely magnuson will use what harrop plans to use. HPTuners. So you could factor in another 300 for the cable + cost of how many credits it will be (either $200-300 worth) then the cost of the tune itself.
    All in all, SC, tune, taxes, shipping, likely $8k +
    And I can pretty much guarantee none of them are upgrading the DI system because of who is going to spend 6500+ 1900 + whatever else tuning cost to gain ....100ish Hp?
    AKGSD, 05Taco4x4, Torspd and 10 others like this.
  5. Apr 13, 2020 at 7:05 PM
    #6705
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Has it been made clear what the HP specs Mat is posting are referenced to? Are they whp, or crank? The percent gains don’t make sense referenced to 278HP... unless those are max gains and not gains at peak. 325 at the wheel would be like 355’ish at the crank.
  6. Apr 13, 2020 at 7:08 PM
    #6706
    Bigetaco22
    Bigetaco22 Well-Known Member
    Kenny
    2016 DCSB TRD OR
    Bilstein 6112/5160s. OME leaf springs. 285/75/16. RC tonneau cover. Supernova v3 led lows, highs, and fog lights. Kicker speaker upgrade.
    These numbers are at the hub.
  7. Apr 13, 2020 at 7:12 PM
    #6707
    RushT
    North Texas
    Ah, that would be spectacular then. If parasitic loss is 10%, then 325 —> 361 at the crank. And 361/278 looks like great math to me.
  8. Apr 13, 2020 at 7:12 PM
    #6708
    BoneTaco
    BoneTaco Well-Known Member
    Sacramento, CA
    17 DCLB OR
    Id guess wheel since they are dyno numbers.
    xxTacocaTxx likes this.
  9. Apr 13, 2020 at 7:24 PM
    #6709
    mZiggy
    mZiggy Honey badger
    Marc
    Mat had said a long time ago in one of the Facebook groups that these transmissions have terrible loss. I think he said 15-20% was a solid assumption.
  10. Apr 13, 2020 at 7:25 PM
    #6710
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    plus you cut the work in "half". Instead of installing both at the same time. It's one, then the other later if u decide. And "easier" on the wallet.
    mZiggy[QUOTED] likes this.
  11. Apr 13, 2020 at 7:31 PM
    #6711
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Yep. The independent dyno test posted 246hp & 232 ft/lbs tq. at the wheels on a DynoJet (first post, mega thread). Stock calibration.
    Torspd likes this.
  12. Apr 13, 2020 at 7:44 PM
    #6712
    Kclamer
    Kclamer Well-Known Member
    Konstantin
    2018 Toyota Tacoma TRD Off-Road 4x4
    2.5" lift, 4.88 gears
    Mat that is why I am waiting for you to tune a Harrop setup even if it takes as long as -soon- takes :)
  13. Apr 13, 2020 at 8:12 PM
    #6713
    jerzsubbie
    jerzsubbie Well-Known Member
    Davidson, NC
    ‘13 GX460
    His % are jacked up because of how it’s worded. “125% increase” would be more than double the power, but he really means “25% increase” or “125% of the stock power”. Plus stock numbers aren’t in the post and these trucks behave whacky on the dyno.
    atpage, xxTacocaTxx, Skydvrr and 3 others like this.
  14. Apr 13, 2020 at 8:23 PM
    #6714
    jerzsubbie
    Davidson, NC
    ‘13 GX460
    Not arguing with these points, your absolutely correct, OVT is offering a much better power & feature set for the $$$. My point was simply that I was excited to get close to 400hp/tq for <$5k. However, as development progressed and you learned more about what these trucks need to run reliably in that power range and above, the price climbed to now $7k, more than 40% higher.
    stun gun and gumpjr23 like this.
  15. Apr 13, 2020 at 8:27 PM
    #6715
    Bigetaco22
    Kenny
    2016 DCSB TRD OR
    I'm pretty sure what he is trying to get across is that peak torque at 2300 rpm is 125% better than stock dyno numbers at 2300 rpm. These trucks make almost no torque below 3000 rpm.
    jerzsubbie[QUOTED] likes this.
  16. Apr 13, 2020 at 8:35 PM
    #6716
    OVTune
    OVTune
    The numbers are measured at the hub/wheel. Front page percent are percent of stock power.
    assuming 278HP is actually what this engine makes at the crank, transmission losses are around 14 - 16 percent.
    If it's closer to Camry numbers, 300, which I think so, its 20 percent.
    So meet in the middle, 17 percent,
    Take base kit numbers of 325 wheel, is equivalent to 380 BHP.
    The price of the base kit actually hasn't changed much, only does when including optional fuel mods.
    AKGSD, Torspd, jerzsubbie and 6 others like this.
  17. Apr 13, 2020 at 8:55 PM
    #6717
    gumpjr23
    gumpjr23 Well-Known Member
    2016 Double cab Off Road
    Do you plan on taking preorders starting with the original list @OVTune ? Or how do you plan on allowing for the first set of orders? Thanks!
  18. Apr 13, 2020 at 9:30 PM
    #6718
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Open up orders. Whoever pays, gets a kit.
  19. Apr 13, 2020 at 9:35 PM
    #6719
    Shellshock
    Iowa
    Or he could hide one with clues and it’ll be an Easter egg hunt
    or since we are all supposed to stay home he can hide the order link and whoever finds it first gets one.
    Gjr003, ihatemytruck, inksin and 3 others like this.
  20. Apr 13, 2020 at 9:39 PM
    #6720
    o313
    o313 Well-Known Member
    N
    2018 DCLB AT SC
    I can't wait to get some real world feedback on these awesome looking kits!
    Who is planning on doing their own install or not?
Thread Status:
