OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Apr 15, 2020 at 2:54 PM
    #6841
    Bigetaco22
    Bigetaco22 Well-Known Member
    Kenny
    2016 DCSB TRD OR
    Bilstein 6112/5160s. OME leaf springs. 285/75/16. RC tonneau cover. Supernova v3 led lows, highs, and fog lights. Kicker speaker upgrade.
    Inferno__Taco likes this.
  2. Apr 15, 2020 at 2:55 PM
    #6842
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    sure
    Inferno__Taco and Sleipnir like this.
  3. Apr 15, 2020 at 2:56 PM
    #6843
    Tea-coma
    Tea-coma Well-Known Member
    AZ
    2017 Quicksand 4x4 TRD AT OV 91 tune
    Cold Air intake, Dual Exhaust, OV 1.05
    1. Meso- powermax full fuel system
    2. Bigetaco22- base
    3. Jrgymie- powermax di
    4. Tea-coma
    5.
    6.
    7.
    8.
    9.
    10.
    11.
    12.
    13.
    14.
    15.
    16.
    17.
    18.
    19.
    20.
    21.
    22.
    23.
    24.
    25.
    AKGSD and Sleipnir like this.
  4. Apr 15, 2020 at 2:57 PM
    #6844
    OVTune
    OVTune
    pinochle, Skydvrr, Sleipnir and 3 others like this.
  5. Apr 15, 2020 at 3:00 PM
    #6845
    Tea-coma
    AZ
    Order complete
    420taco likes this.
  6. Apr 15, 2020 at 3:13 PM
    #6846
    Lutrev
    Lutrev Well-Known Member
    2018 MT black pro
    2.0 SFOB OV tune, ADM, MESO v4,stage 1 tail,maps and dome,etc
    How will the psi be adjusted with these kits if one upgraded? Waste gate adjustable?
  7. Apr 15, 2020 at 3:15 PM
    #6847
    Kodeman23
    Kodeman23 Member
    Seth
    San Diego
    2019 Tacoma TRD Pro
    Can you confirm the Powermax price? I thought without tune it was around $5200.
  8. Apr 15, 2020 at 3:15 PM
    #6848
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Order #6167
  9. Apr 15, 2020 at 3:17 PM
    #6849
    OVTune
    OVTune
    Boost controller.
    The base kit comes with 5psi wastegates. Realistic boost pressures seen at the manifold are around 6.5 psi (tapering in higher rpm).
    but, due to a lot of people really wanting Powermax without DI upgrade... we may just include these same 5psi wastegates with them.
    here is the thing. I really don't want to make too many options. That is what made the tunes go overboard.
    So, it's either powermax coming with base 9psi, or powermax coming with base 5psi.
    But if it is coming with base of 5psi, a boost controller is required to get more boost.
    I do not want to offer 5psi wastegates, 9psi wastegates, 15psi ,etc etc. Only 1 wastegate option.
    AKGSD, Skydvrr, auskip07 and 3 others like this.
  10. Apr 15, 2020 at 3:22 PM
    #6850
    OVTune
    OVTune
    you are correct, sorry I updated that.
    Sleipnir likes this.
  11. Apr 15, 2020 at 3:22 PM
    #6851
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    @mZiggy, I think Mat said the real list is the deposit link. I'm not sure your list is matching up with who has actually paid.
    My order is complete. base kit.
  12. Apr 15, 2020 at 3:24 PM
    #6852
    Speedwaytacotuesday
    Speedwaytacotuesday I love riding in my wife's Taco :p
    Calgary, Alberta
    2016 TACO LTD, 88 4runner, 4th Gen 4Runner
    TRD S/C 2.3" pulley mild ported Portmatched/cleaned intake runner Ucon EMS/cam gears/160 t-stat 840cc injectors 255 LPH walbro fuel pump Urd equal length headers Urd competition y-pipe AFE 3” Exhaust Vibrant resonator Oil Catch can Ratio-tek valvebody upgrade 3" bilstein/OME lift Dakar rear 7-leaf pack 32" KO2's load range C Stealth custom wheels Ray-10's Volk Te37X’s Tundra front 13.3” brakes Custom fab rock sliders LC-2 wideband autometer boost gauge Cravenspeed gauge pod mount Scangauge 2 SC MODS: Pulley ripp mod/belt wrap mod/ fleetrunner belt/ tensioner stop delete mod/ bypass jet delete mod
    For most folks forking up for a powermax I would assume they could fork up a couple hundred more for a boost controller or even less for a manual one. Also as Mat said there is approximately 4.5 psi left on the table to be had with the DI’s using a boost controller. For me it’s a no brainer and just have 5psi spring all around no matter the option. As soon as you say yes to powermax and DI’s later I will press that purchase deposit button lol. Sorry if I’m being pushy :D
  13. Apr 15, 2020 at 3:26 PM
    #6853
    OVTune
    OVTune
    If we can get a general agreement from you guys here (since you guys here are the ones putting in this first batch) then I'll make the powermax kits come with base 5psi wastegates.
    A $50 manual boost controller will work fine. No need for a expensive electronic 3/4 port EBC.
    Hell if I can finish the code for the stock gas tank evap, the stock ECU can run a boost controller.
    ihatemytruck, SC4333, MESO and 3 others like this.
  14. Apr 15, 2020 at 3:30 PM
    #6854
    Kodeman23
    Kodeman23 Member
    Seth
    San Diego
    2019 Tacoma TRD Pro
    Order complete. Powermax + DI
  15. Apr 15, 2020 at 3:31 PM
    #6855
    Gen3TacomaOBX
    S
    Sorry to be dense... but are you saying that we can buy the PowerMax and run it on 5 psi safely until we are ready to fork out the money for the DI upgrade?
    EDIT: Upon re-reviewing the last couple of pages it appears you're trying to gauge the wants of those that're definitely purchasing the powermax kit.
  16. Apr 15, 2020 at 3:37 PM
    #6856
    OVTune
    OVTune
    it was not the original intention of the powermax kit, but yes if you want to run it on very low boost you could without DI upgrades.
    But to be crystal clear here guys, the powermax kits on 5psi offers almost no power benefits vs base.
  17. Apr 15, 2020 at 3:39 PM
    #6857
    Speedwaytacotuesday
    Calgary, Alberta
    yuss!
    K going to purchase now.
    I feel like a kid
    TWTaco likes this.
  18. Apr 15, 2020 at 3:41 PM
    #6858
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    I think the guys here wanna future proof the setup. The guys that are jumping in quick have made it clear they wanna get it. I have nothing to add I'm just here for the spooly bois
    Speedwaytacotuesday likes this.
  19. Apr 15, 2020 at 3:45 PM
    #6859
    OVTune
    OVTune
    Okay.
    So the base kits will come with 5psi wastegates.
    The powermax kits will come with 5psi wastegates + springs for more boost.
    When you install your turbo kit, you can select if you want to run more than 5psi base pressure on the powermax kit.
    I think this is about as good as I can make it for boost psi options.
    BUT to run higher than 5psi you need to have the DI upgrade.
    once again all of this info will be outlined in detail. I will work on that right now for page 1.
    AKGSD, Rainoffire, Torspd and 8 others like this.
  20. Apr 15, 2020 at 3:45 PM
    #6860
    Shellshock
    Iowa
    BEAR_KNIFE_FIGHT and Sleipnir like this.
Thread Status:
