OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Apr 15, 2020 at 3:51 PM
    #6861
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    if you guys have further questions please let me know
    5psi Base kit price with investment cast manifolds $4249.00
    5psi PowerMax Kit with investment cast manifolds $5209.00
    Tune included if you have our Flash kit or vF Tuner.
    PowerMax kit /Base Kit comes with upgraded wastegate springs for optional boost increase
    DI Upgrade option $1849.00 - includes plug and play upgraded DI injectors
    - Required for Powermax kits running more than 5-6psi
    - Required for Base kits running more than 6psi
    Maximum pressure with DI upgrade only:
    Base kits: 14-15psi
    Powermax kits: 15psi
    Full fuel upgrade option: $2788.00
    Includes: upgraded plug and play DI Injectors
    upgraded in-tank Fuel Pump with PWM Controller
    upgraded port injectors (750cc)
    Maximum pressure with Full Fuel upgrade Option:
    Base kits: 14-15psi (turbo limited, not fuel limited)
    Powermax kits: 24-26psi
  2. Apr 15, 2020 at 3:55 PM
    #6862
    Speedwaytacotuesday
    Speedwaytacotuesday I love riding in my wife's Taco :p
    Calgary, Alberta
    2016 TACO LTD, 88 4runner, 4th Gen 4Runner
    TRD S/C 2.3" pulley mild ported Portmatched/cleaned intake runner Ucon EMS/cam gears/160 t-stat 840cc injectors 255 LPH walbro fuel pump Urd equal length headers Urd competition y-pipe AFE 3” Exhaust Vibrant resonator Oil Catch can Ratio-tek valvebody upgrade 3" bilstein/OME lift Dakar rear 7-leaf pack 32" KO2's load range C Stealth custom wheels Ray-10's Volk Te37X’s Tundra front 13.3” brakes Custom fab rock sliders LC-2 wideband autometer boost gauge Cravenspeed gauge pod mount Scangauge 2 SC MODS: Pulley ripp mod/belt wrap mod/ fleetrunner belt/ tensioner stop delete mod/ bypass jet delete mod
    Order complete - powermax
    Order# 6170
    420taco likes this.
  3. Apr 15, 2020 at 3:56 PM
    #6863
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Mat,
    That configuration might get you a few more people on board with the Powermax rather than straight base. If the Powermax @5psi is essentially the same as the base but perhaps doesn't tail off at higher rpm... then some might be willing to spend the extra $1k for insurance that they can upgrade later without breaking the bank.
    CO_Taco125 and Dirk Diggler like this.
  4. Apr 15, 2020 at 4:06 PM
    #6864
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    What if you don’t have a flash kit or vF tuner? I’m looking to get powermax kit with DI so $399 more? I didn’t see an option for Tacoma on the vF tuner drop down menu on your website just Lexus and others
    420taco likes this.
  5. Apr 15, 2020 at 4:06 PM
    #6865
    Lutrev
    Lutrev Well-Known Member
    2018 MT black pro
    2.0 SFOB OV tune, ADM, MESO v4,stage 1 tail,maps and dome,etc
    May as well add base plus DI and upgraded spring as an option as well.
  6. Apr 15, 2020 at 4:13 PM
    #6866
    OVTune
    OVTune
    You will need to order vF Tuner once it releases for the Tacoma.
    adding the springs to the base kit is no problem.
    base + DI is already an option.
    15 spots remaining.
    alrighty I gotta head out for a bit. I'll check in later for any questions.
    BEAR_KNIFE_FIGHT likes this.
  7. Apr 15, 2020 at 4:14 PM
    #6867
    TWTaco
    TWTaco Well-Known Member
    Dave
    Order complete base kit. :bananadance:#6169
  8. Apr 15, 2020 at 4:15 PM
    #6868
    jurassicmark1
    jurassicmark1 Well-Known Member
    Chula Vista
    2016 TRD Sport 4X4 6MT, KINGS, OVTuned
    King Suspension F&R Total Chaos UCA’s ICON RXT Leaf Springs 4Runner TRD Pro Wheels BFG KO2’s 265/70 R17 OV Tune 2.0 SFOB
    Deposit in. Powermax Order #6171
  9. Apr 15, 2020 at 4:16 PM
    #6869
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Ovtune dropping this the day people get hit with a stimulus check...well played mat...well played
    Jackpatt9, Alesimo, pinochle and 10 others like this.
  10. Apr 15, 2020 at 4:20 PM
    #6870
    Sleipnir
    Sleipnir Still havent found that stupid snipe
    I'm a horse
    Asgard
    Furd Rangero Ecoboost
    @LostHusker :boink:
  11. Apr 15, 2020 at 4:21 PM
    #6871
    OVTune
    OVTune
    I didn't get no stimulus??
  12. Apr 15, 2020 at 4:21 PM
    #6872
    Ronzio
    Pennsylvania
    17 DCSB TRDOR
    Thanks deposit in Powermax order#6173
  13. Apr 15, 2020 at 4:26 PM
    #6873
    Speedwaytacotuesday
    Calgary, Alberta
    Me neither?
    Dirk Diggler likes this.
  14. Apr 15, 2020 at 4:27 PM
    #6874
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    :canada: Stay on your side of the imaginary line
  15. Apr 15, 2020 at 4:36 PM
    #6875
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    In for powermax....Order #6174
    Torspd likes this.
  16. Apr 15, 2020 at 4:39 PM
    #6876
    Speedwaytacotuesday
    Calgary, Alberta
    Haha for now yes. Once this lockdown is over I’ll be dragging the travel trailer over the line.
  17. Apr 15, 2020 at 5:10 PM
    #6877
    Turd Hawg
    Turd Hawg Well-Known Member
    2018 DC SB OR AT (Sold)
    arriving Friday
    Can we safely assume that finished turbo tunes will be available prior to the turbos being shipped?
    Are a good set of instructions still planned and will be made available prior to shipping?
    Want to be sure that this rollout isn’t simply ‘getting the first shipment out’ and preparing for full launch on the second batch.
    thanks
    mZiggy, Jrgymie[QUOTED] and gumpjr23 like this.
  18. Apr 15, 2020 at 5:10 PM
    #6878
    Jrgymie
    Jrgymie Tuf MuddR
    Jeff
    Glastonbury, CT
    18 DCSB CEMENT TRD SPORT 4x4
    order # 6175
  19. Apr 15, 2020 at 5:10 PM
    #6879
    gumpjr23
    gumpjr23 Well-Known Member
    2016 Double cab Off Road
    What I would do to see an on road test video of these in action..
    Jackpatt9 likes this.
  20. Apr 15, 2020 at 5:15 PM
    #6880
    RushT
    North Texas
    Welcome to progressive taxation.:ballchain:
Thread Status:
