OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Apr 28, 2020 at 8:00 AM
    #7161
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    Just saw VFTuner coming out May 1st, I'll go ahead and pay that as well even if I cannot use it till turbos!
    Speedwaytacotuesday likes this.
  2. Apr 28, 2020 at 10:31 AM
    #7162
    Sleipnir
    Sleipnir Still havent found that stupid snipe
    I'm a horse
    Asgard
    Furd Rangero Ecoboost
    @OVTune You guys thought about putting SPD turbo adapters on those PowerMax or Base Kits?
  3. Apr 28, 2020 at 11:17 AM
    #7163
    Jrgymie
    Jrgymie Tuf MuddR
    Jeff
    Glastonbury, CT
    18 DCSB CEMENT TRD SPORT 4x4
    Mat, I will be one of the first batch TT kits.
    Do you think running two 2.5" GESI race cats in parallel directly after your manifolds with a custom 2.5" Y pipe will be sufficient?
    I won't have any cats with the new manifolds and don't want CEL's (running secondary cat delete with URD Y pipe).
  4. Apr 29, 2020 at 10:02 AM
    #7164
    rj_taco
    rj_taco Well-Known Member
    I'd say since there are a lot of different exhaust options, it will be hard for Mat to accommodate those requests to tweak the program to avoid the CEL's. That's where VFTuner comes in the picture, you should be able to make slight changes to avoid the CEL's. As long as Mat let's us know the conditions that trigger them (it's probably more complicated than this, think non steady state vs steady state etc) Maybe I'm thinking wrong about this, but that's what I think might be the case.
    You would also be able to purchase credits and request his help for your particular setup. We need to remember that he has to be careful on what he discloses here on anything related to emissions.
    bmxvr6 likes this.
  5. Apr 29, 2020 at 11:19 AM
    #7165
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Just look up code setting criteria for whatever CEL it is. It'll let you know where to look. Then live Data and tweak w vFtuner as necessary
  6. Apr 29, 2020 at 4:34 PM
    #7166
    Jrgymie
    Jrgymie Tuf MuddR
    Jeff
    Glastonbury, CT
    When you run NO catalytic converters you are sure to get a CEL. I've been without CEL's running a secondary cat delete and once I install OVT's TT kit which will delete the primary cats, I won't be running ANY cats and for sure will fire CEL's.
    I plan on adding an aftermarket high flow cat into each downpipe which should remedy my problem. However, since Mat stated that the current OEM exhaust is a bottle neck, I wanted to have a custom exhaust made with bigger downpipes. Currently, our Taco's run 2.25" downpipes (Y pipe) which is too narrow for boosted applications. There are aftermarket downpipes for the 3.5 ecoboost which use 3" downpipes and claim a 25-30 HP bump compared to OEM exhaust.
    Ideally, we should be running similar 3" downpipes for the TT kit; especially if Mat has confirmed that it is a bottleneck. However, I don't know if 3" downpipes will fit easily under our trucks. I was planning on 2.5" downpipes/race cats which will be better than OEM set up but wanted some recommendations whether we really should be going 3".
  7. Apr 29, 2020 at 4:41 PM
    #7167
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    On the current kits 3 inch downpipe would be a great addition if you're really looking to squeeze as much power per psi as possible.
    The standard kits though are planning to be a more bolt on, OEMesque affair, with 2.25 inch downpipes. Similar to what you would see on a stock twin turbo car.
    And we are looking into having a catted downpipe option.
    It still makes plenty of power on 2.25"
  8. Apr 29, 2020 at 4:42 PM
    #7168
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    I mean, the numbers that Mat posted with the 2.25" pipes are really nice anyway, so further upgrades are just a bonus, rather than a necessity. Except for the horsepower hunters I suppose.
    Either way, people will probably make good use of vF to tweak their tunes to account for larger exhausts. Personally, I'll be happy with the base kit and stock TRD exhaust.
    TWTaco and Inferno__Taco like this.
  9. Apr 29, 2020 at 4:44 PM
    #7169
    mZiggy
    mZiggy Honey badger
    Marc
    Will the catted downpipes be an option in time for your current timeline to ship the first kits or no? Since I'm sure someone will ask.
    And since I don't mind minimizing opportunities to pop CELs lol :notsure:
    pinochle likes this.
  10. Apr 29, 2020 at 4:50 PM
    #7170
    OVTune
    OVTune
    I think once you feel the powermax turbos at 10psi as is in this little truck you won't even bother with trying to squeeze more out.
    It is a very nice balance of giving it all the power it needs without going overboard.
    Think about it, a 1000HP GTR is nuts! But a 500hp HP GTR with a wide torque band is much more fun.
    AKGSD, Tea-coma and Inferno__Taco like this.
  11. Apr 29, 2020 at 4:53 PM
    #7171
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    There is always someone that will want more, just so they can say they have the most. We all know that.....
    That being said, this truck with the power numbers you posted (even on the base kit), is going to be a completely different vehicle.
    mZiggy and Shellshock like this.
  12. Apr 29, 2020 at 4:55 PM
    #7172
    OVTune
    OVTune
    It probably sounds "lame" from the extreme off roarders but a bit of boost and dirt roads are all day fun.
    If I could make any recommendation of a mod to go with it is bigger tires.
    You'd probably be burning up the stock small street tires quickly, but my tires for example hold it down pretty good.
    AKGSD, Jackpatt9 and pinochle like this.
  13. Apr 29, 2020 at 4:59 PM
    #7173
    lapoltba
    CT - 06076
    Already doing a lot of that on 2.0. 1st and 2nd gear are nutty.
    Shellshock likes this.
  14. Apr 29, 2020 at 5:00 PM
    #7174
    whitedlite
    USA!
    3RD Gen TRD 4WD
    it's a male hammer swinging contest out here in the streets lol.
    I'm ~5.5 or whatever the number is powermax kit for now.
    I just want to know can I outrun my friends V8 pickups lol.
    Plus, maybe I'll be the only boosted 3rd in alabama for a while.
    Dirk Diggler likes this.
  15. Apr 29, 2020 at 5:00 PM
    #7175
    Mike O
    Mike O Well-Known Member
    2016 TRD OR MGM Access Premium LB
    Mobtown Sliders, SSO Slimline bumper, Baja Amber lightbar & fogs, Sumo bump stops
    It doesn't sound lame at all :D....as long as there is really good control in 4-lo (tip in, etc.).
  16. Apr 29, 2020 at 5:02 PM
    #7176
    su.b.rat
    su.b.rat broken truck
    funny you say that. the one reason I've considered TTs is so i can go to 33's and keep my performance. if the driveability is as good as NA then that will be mighty tempting.
  17. Apr 29, 2020 at 5:28 PM
    #7177
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I hate this thread. I want TT but my wallet doesn't :(. Stoked for all the videos everyone will be posting
  18. Apr 29, 2020 at 5:53 PM
    #7178
    Turd Hawg
    Turd Hawg Well-Known Member
    2018 DC SB OR AT (Sold)
    yes! Like hearing this
    TWTaco and lapoltba like this.
  19. Apr 29, 2020 at 8:43 PM
    #7179
    rj_taco
    Exactly what I am after as well! Glad I went with the PowerMax's + DI.
    Mat, will you be contacting us on when to pay the balance or how will that work?
    Torspd likes this.
  20. Apr 29, 2020 at 9:13 PM
    #7180
    Speedwaytacotuesday
    Speedwaytacotuesday I love riding in my wife's Taco :p
    Calgary, Alberta
    2016 TACO LTD, 88 4runner, 4th Gen 4Runner
    TRD S/C 2.3" pulley mild ported Portmatched/cleaned intake runner Ucon EMS/cam gears/160 t-stat 840cc injectors 255 LPH walbro fuel pump Urd equal length headers Urd competition y-pipe AFE 3” Exhaust Vibrant resonator Oil Catch can Ratio-tek valvebody upgrade 3" bilstein/OME lift Dakar rear 7-leaf pack 32" KO2's load range C Stealth custom wheels Ray-10's Volk Te37X’s Tundra front 13.3” brakes Custom fab rock sliders LC-2 wideband autometer boost gauge Cravenspeed gauge pod mount Scangauge 2 SC MODS: Pulley ripp mod/belt wrap mod/ fleetrunner belt/ tensioner stop delete mod/ bypass jet delete mod
    On my 2011 S/C Taco I have equal length headers, URD Ypipe and a 3” AFE exhaust which eliminates all 4 cats. I’m one of those guys that try to squeeze out every bit of power and let me tell you it’s ridiculously loud and unenjoyable on road trips. This time around I’m going for a bit more practically than full race truck. I recommend anyone that hates a rumbling exhaust and enjoys his/her comfy quiet ride to keep the exhaust stock as possible. I’ve since added a vibrant ultraquiet resonator to tame it down a little and I’d say it took down the drone marginal at best but not much else. Also a side note before I went with the UCON EMS I used to run a split second fuel controller which required me to run a O2 simulator in order to avoid a CEL. It works by sending false voltages to the ecu from the the downstream sensors and is fully plug and play. If the VFtuner for some reason is unable to void the cel light then this is a good option for those going catless.
Thread Status:
