OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. May 20, 2020 at 2:41 PM
    #7381
    seelyartacus
    seelyartacus Well-Known Member
    San Diego
    '16 TRD Sport 4x4, grey, tech&tow pkg
    FNWheels six shooter matte bronze, Falken WildPeak M/T 295/70/r17, All-Pro Expedition leafs, Fox Factory 2.5 w/ res (front/rear), Icon billet UCA w/ sphericals, custom sliders, 4.56 re-gear, RCI bed rack , Tepui RTT, Prinsu Designs Cabrac, CBI T3 alum front bumper, CBI T3 rear bumper with dual swing away and tire carrier, 20in light bar, Warn VR10s winch, Factor 55 fairlead, flatlink, and hitch recovery point, All-pro alum skid, Rotopax, CMC, Timbren bump stops, rear Rigid Duallys, Rigid Dually ditch lights, ARB awning with LED lights, Currie F9 rear axle housing w/ Strange Engineering 3rd memb and ARB air locker., rear diff beather relocation, ARB compressor under hood, Bussman panel, 3d printed switch panel,OVTune ECU
    been following his too, just a lot of model numbers and forgot what was what. Thanks for the info
  2. May 20, 2020 at 4:25 PM
    #7382
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    These have diverters in them to make sure to split the air across both top and bottom. Non diverted styles are not wanted.
    @Turd Hawg posted pictures of this. :thumbsup:
    Speedwaytacotuesday likes this.
  3. May 20, 2020 at 4:53 PM
    #7383
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :drool:
    mZiggy likes this.
  4. May 20, 2020 at 5:30 PM
    #7384
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    When in Russia, pedal stop is limit. :D
  5. May 20, 2020 at 5:32 PM
    #7385
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    I'll delete my comment. I wasn't being considerate of your thread when I shared the link, I apologize
    Torspd and Tea-coma like this.
  6. May 20, 2020 at 5:40 PM
    #7386
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    something in that video doesnt sound good at 13 -14 second mark.
  7. May 20, 2020 at 5:53 PM
    #7387
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    thanks, deleted my comment as well.
    Ehh I am just over it with competitor stuff. I know that everyone eventually comes to us, asks our opinions, etc.
    It is really these companies responsibility (Magnuson, Harrop, URD, etc) to give you guys the confidence in their products, tuning, etc. Not me.
    I hope this doesn't sound arrogant.
    AKGSD, Sleipnir, BoneTaco and 6 others like this.
  8. May 20, 2020 at 5:57 PM
    #7388
    auskip07
    Skip
    Atlanta, Ga
    i do like the rotex platform but having trust in the company putting the package together is as important as the pieces.
  9. May 20, 2020 at 5:57 PM
    #7389
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Not at all. You're handling it well, "ask them for info on their product". Not a God damn thing wrong w that. I'm interested to see how trans temps play out with moving coolers and added torque. Exciting times.
  10. May 20, 2020 at 6:25 PM
    #7390
    OVTune
    OVTune
    Regarding turbos.
    All version kits (base, powermax) regardless of fuel upgrade or not, will come pre-configured with 6psi springs.
    They will come pre-set with the necessary pre-load for 6.5-7psi peak.
    If you plan to run base boost pressure, then do not touch them.
    If you want to run more while still using these springs, you can increase the pre-load, which we will give a tutorial how.(max 10psi with pre-load).
    Setting the pre-load and wastegates before install is CRITICAL, so make your decision once. While it's not impossible to change it in truck, it's a serious PITA
    AKGSD, Torspd, Gen3TacomaOBX and 10 others like this.
  11. May 20, 2020 at 6:35 PM
    #7391
    Tea-coma
    Tea-coma Well-Known Member
    AZ
    2017 Quicksand 4x4 TRD AT OV 91 tune
    Cold Air intake, Dual Exhaust, OV 1.05
    Just to confirm what is the gained power at 6 psi
  12. May 20, 2020 at 6:36 PM
    #7392
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Page one
    Tea-coma[QUOTED] likes this.
  13. May 20, 2020 at 6:46 PM
    #7393
    TWTaco
    TWTaco Well-Known Member
    Dave
    Well this changes things! Is 10 psi max safe boost for base kit? With fuel upgrades?
  14. May 20, 2020 at 6:52 PM
    #7394
    Bigetaco22
    Bigetaco22 Well-Known Member
    Kenny
    2016 DCSB TRD OR
    Bilstein 6112/5160s. OME leaf springs. 285/75/16. RC tonneau cover. Supernova v3 led lows, highs, and fog lights. Kicker speaker upgrade.
    I like this a lot. Much better option than running a boost controller if you don't plan on running over 10 psi. This pretty much made my mind up about doing DI.
    BlkdOuT likes this.
  15. May 20, 2020 at 8:43 PM
    #7395
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    20psi springs ordered:thumbsup:
  16. May 20, 2020 at 8:51 PM
    #7396
    TWTaco
    Dave
    :thumbsup:
  17. May 20, 2020 at 9:00 PM
    #7397
    BlkdOuT
    BlkdOuT Well-Known Member
    2017 Tacoma trd sport 4x4 MT TT
    @MESO do you have a timeline for the tacopods yet? I've been looking at other options but you're def number one on the list. And you're an hour away from me. Support local lol
    MESO likes this.
  18. May 20, 2020 at 9:02 PM
    #7398
    MESO
    State of Jefferson
    Just curious, what other options is everyone looking at for monitoring engine vitals?
  19. May 20, 2020 at 9:07 PM
    #7399
    fezzy
    fezzy Well-Known Member
    Hawai'i
    2017 BLACK TRD OFFROAD DCSB M/T
    i didnt buy the turbo yet. but im gonna buy your pods when you release them
  20. May 20, 2020 at 9:14 PM
    #7400
    TWTaco
    Dave
    Dam i think everyone is waiting for your pods! Honestly i have been waiting for your pods since first seeing them. Ever since i picked these up , its all i ever wanted
Thread Status:
