OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. May 22, 2020 at 4:16 PM
    #7461
    Bigetaco22
    Bigetaco22 Well-Known Member
    Kenny
    2016 DCSB TRD OR
    Bilstein 6112/5160s. OME leaf springs. 285/75/16. RC tonneau cover. Supernova v3 led lows, highs, and fog lights. Kicker speaker upgrade.
    Here it is!
  2. May 22, 2020 at 4:17 PM
    #7462
    TWTaco
    TWTaco Well-Known Member
    Dave
    Never seen anything on 2 different fuel pumps.
  3. May 22, 2020 at 4:17 PM
    #7463
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    fuel upgrades are required to run more than 7psi safely.
    So I hope this is clear, because it has changed a bit, mainly due to advances in tuning. (using less Port)
    The base kit on up to 6.5~7 psi requires no fuel upgrades at all. (complete stock fuel system)
    the powermax kit up to 5~6 psi requires no fuel upgrades at all.
    To run either kit on higher boost (up to about 14psi) requires only direct injector upgrade.
    Power max kit more than 14psi requires direct injectors + in tank fuel pump upgrade.
    Power max kit on more boost than 14psi and or ethanol requires in tank upgrade + port injectors + direct injectors.
    the base kits are NOT recommend to run more than 14psi so we did not test fuel limits on more than 14psi on those.
    AKGSD, jerzsubbie, Quadabaum and 4 others like this.
  4. May 22, 2020 at 4:18 PM
    #7464
    TWTaco
    Dave
    Thanks Mat
  5. May 22, 2020 at 4:19 PM
    #7465
    TWTaco
    Dave
    I TOLD YOU SO!:rofl::rofl::rofl::rofl:
  6. May 22, 2020 at 4:19 PM
    #7466
    OVTune
    OVTune
    Originally, if you recall we were trying to tune utilizing more port fuel to compensate for boost.
    This was before we got the upgraded direct injectors.
    When you use additional port fuel, the stock in tank fuel pump cannot handle it.
    This reflects our new packages for the fuel system.
    package 1 : direct injector upgrade only
    package 2: direct injector + port injector + upgraded fuel pump
    Disclaimer : this assumes your pump isn't one of toyotas faulty ones that randomly drop pressure. This CAN kill your engine if it's a faulty one.
    AKGSD, Quadabaum, Skydvrr and 5 others like this.
  7. May 22, 2020 at 4:25 PM
    #7467
    Bigetaco22
    Kenny
    2016 DCSB TRD OR
    Less work for me I guess. I like it!
  8. May 22, 2020 at 4:27 PM
    #7468
    OVTune
    OVTune
    gonna post this one more time
    AKGSD, pinochle, Skydvrr and 5 others like this.
  9. May 22, 2020 at 4:31 PM
    #7469
    Speedwaytacotuesday
    Speedwaytacotuesday I love riding in my wife's Taco :p
    Calgary, Alberta
    2016 TACO LTD, 88 4runner, 4th Gen 4Runner
    TRD S/C 2.3" pulley mild ported Portmatched/cleaned intake runner Ucon EMS/cam gears/160 t-stat 840cc injectors 255 LPH walbro fuel pump Urd equal length headers Urd competition y-pipe AFE 3” Exhaust Vibrant resonator Oil Catch can Ratio-tek valvebody upgrade 3" bilstein/OME lift Dakar rear 7-leaf pack 32" KO2's load range C Stealth custom wheels Ray-10's Volk Te37X’s Tundra front 13.3” brakes Custom fab rock sliders LC-2 wideband autometer boost gauge Cravenspeed gauge pod mount Scangauge 2 SC MODS: Pulley ripp mod/belt wrap mod/ fleetrunner belt/ tensioner stop delete mod/ bypass jet delete mod
    What is the max boost for DI and in intake fuel pump upgrade WITHOUT port injectors?
  10. May 22, 2020 at 4:36 PM
    #7470
    OVTune
    OVTune
    Same. Amount. There is a limit to how much the direct injectors can spray based in injection window. We already run then near peak pressure so pre HPFP pressure isn't as much of a factor.
    When port injectors require high usage is when the low pressure becomes critical
  11. May 22, 2020 at 4:38 PM
    #7471
    Speedwaytacotuesday
    Calgary, Alberta
    Also I’ve been meaning to ask but kept forgetting. Did you experience any tranny slippage while running the powermax kit at its higher boost setting? With the Aisin Tranny in the second gen Tacoma it wouldn’t take long after 350whp or so before the Tranny starts slipping which is why many including myself modified or upgraded the valve body for a crispier faster shift to mitigate the issue. Hoping the 3rd Gen ones are better and do not need to be touched.
  12. May 22, 2020 at 4:41 PM
    #7472
    OVTune
    OVTune
    I did not experience any slippage all the way to 550 ft lbs on the dyno. This is with torque converter fully locked. With torque converter unlocked there is the normal torque converter slop/slippage.
    On the road it's hard to tell between tire spin, on dirt with all 4 spinning it doesn't seem so.
    On the dyno, testing unlocked, the torque converter slippage is up to 700 rpm difference when under 2500 rpm, and doesn't start to align with axle speed until close to 4000 rpm
    AKGSD, Sleipnir, BoneTaco and 2 others like this.
  13. May 22, 2020 at 4:43 PM
    #7473
    Speedwaytacotuesday
    Calgary, Alberta
  14. May 22, 2020 at 4:44 PM
    #7474
    TWTaco
    Dave
  15. May 22, 2020 at 4:47 PM
    #7475
    TWTaco
    Dave
    https://www.toyota.com/recall
  16. May 22, 2020 at 4:55 PM
    #7476
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Thank you. Could an AFR gauge help identify the problem before it becomes a serious issue?
  17. May 22, 2020 at 5:03 PM
    #7477
    Speedwaytacotuesday
    Calgary, Alberta
    theoretically yes, but if it drops off pressure steep and fast enough you may not catch it in time. That said a wideband is still super helpful in aiding with little hints of this issue or any others before it blows your motor. Many out there like my innovate LC-2 comes with its own software so you can datalog.
  18. May 22, 2020 at 5:15 PM
    #7478
    Tea-coma
    Tea-coma Well-Known Member
    AZ
    2017 Quicksand 4x4 TRD AT OV 91 tune
    Cold Air intake, Dual Exhaust, OV 1.05
    I probably missed this...when will the injectors be available for purchase
  19. May 22, 2020 at 5:19 PM
    #7479
    Turd Hawg
    Turd Hawg Well-Known Member
    2018 DC SB OR AT (Sold)
    I’m on the recall list. If I’m reading this correctly, my powermax low boost doesn’t come with a new fuel pump any more. You’re saying that with boost, versus without, my engine could be damaged if my current fuel pump loses pressure?
    Are you going to sell your fuel pumps separately? It doesn’t look like Toyota has a plan to start replacing them any time soon, when I purchased this I was under the impression it came with a new pump. How much is your pump?
    Gen3TacomaOBX likes this.
  20. May 22, 2020 at 5:22 PM
    #7480
    Tea-coma
    AZ
Thread Status:
