OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. May 25, 2020 at 1:07 PM
    #7561
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Read the thread. Explains it all
  2. May 25, 2020 at 1:08 PM
    #7562
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Correct. But you will be required to run 91 or 93 with the turbos
    TacomaSport86 likes this.
  3. May 25, 2020 at 1:21 PM
    #7563
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Yep. See Mat's post on the topic below.
    TacomaSport86 and Skydvrr like this.
  4. May 25, 2020 at 1:24 PM
    #7564
    Rick111
    Rick111 Well-Known Member
    Rick
    2019 DCSB TRD OR 6M
    ARE Z series cap w/Bedrug
    Ok. I was just asking. Thank you.
  5. May 25, 2020 at 9:16 PM
    #7565
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    https://www.autometer.com/2-boost-vac-30-in-hg-15-psi-fse-sport-comp.html
    Yep, buy American. Autometer has a huge selection.
    Above would be a great option for the guys going with a base kit. You can get the same gauge in 30 psi if pushing more boost. That gauge also comes with a MAP sensor so you don't have to mess with running hard lines into the cab.
  6. May 25, 2020 at 10:29 PM
    #7566
    Bigetaco22
    Bigetaco22 Well-Known Member
    Kenny
    2016 DCSB TRD OR
    Bilstein 6112/5160s. OME leaf springs. 285/75/16. RC tonneau cover. Supernova v3 led lows, highs, and fog lights. Kicker speaker upgrade.
    That's a nice gauge. I am done with r&d here is all of the trial and error for the weekend. A couple different designs. I am still going to include a couple holes for wiring if you want to use those but it actually looks like after installation the gauge is going to sit partially in the duct so the best bet for running wiring/ vacuum line might be drilling a hole in the duct. In my case I should be able to run wiring to the pressure sensor that comes with my gauge and I shouldn't have to drill. Either way here is the final installed. I don't want to clog up @OVTune thread anymore with boost gauge talk so the next post about this mount I will make will be a separate thread as soon as I start the final in black abs. Likely next Tuesday evening.
  7. May 25, 2020 at 11:10 PM
    #7567
    TWTaco
    TWTaco Well-Known Member
    Dave
    Can it go in the very left vent?
    Can it go in the either right or left vent?
  8. May 25, 2020 at 11:17 PM
    #7568
    Bigetaco22
    Kenny
    2016 DCSB TRD OR
    In the center trim yes. As far as the far left vent on the drivers side I will have to verify the tabs being used because if I Remember correctly some of the vents use different locking tabs that are at a different depth on the vent ring. It wouldn't be hard to make one for any vent however now that I have everything dialed in with the print programming.
  9. May 26, 2020 at 7:42 AM
    #7569
    TWTaco
    Dave
    Yes the driver side left vent. I think it would look a better in that vent a little more concealed. IMO
  10. May 26, 2020 at 8:01 AM
    #7570
    Bigetaco22
    Kenny
    2016 DCSB TRD OR
    I'll take a look at it tonight. It may very well be the same thing but I remember something different about the 2 outside vents from when I was doing the black out vent rings a month or so ago. I guess for me I like the inside vent because my eyes are naturally drawn that way with the screen being right there.
    Also I alway use the left vent as my face vent so I like having the adjustability in that vent. In any case it is either going to snap right in or i have to adjust the locking tabs which is no big deal.
  11. May 26, 2020 at 8:06 AM
    #7571
    TWTaco
    Dave
    Its just a comfort thing for me.
  12. May 26, 2020 at 8:53 AM
    #7572
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Manifolds are in heat treat ^_^
    we will have pictures coming very soon.
    As soon as they arrive we will begin our install guide. written + video.
    End of this week I will take orders for people wanting fuel upgrades. and that's it! we start getting these out.
  13. May 26, 2020 at 9:00 AM
    #7573
    Bigetaco22
    Kenny
    2016 DCSB TRD OR
    Middle of next month for shipping?
  14. May 26, 2020 at 9:01 AM
    #7574
    TWTaco
    Dave
    Any word yet if 1st batch will have catted pipes?
  15. May 26, 2020 at 9:02 AM
    #7575
    OVTune
    OVTune
    at the moment I am going to refrain from giving any date, going with our estimate of June 2020
  16. May 26, 2020 at 9:03 AM
    #7576
    OVTune
    OVTune
    we can get catted dumps on first batch, but there will be a longer wait.
    and depending on how many people want catted we may just make catted dumps the only option. Because if I do mix (cat, not cat) it's longer. But all of 1 batch, not as long.
  17. May 26, 2020 at 9:05 AM
    #7577
    TWTaco
    Dave
    Estimate wait time?
  18. May 26, 2020 at 9:05 AM
    #7578
    OVTune
    OVTune
    I'm working on finding that out atm
    Tea-coma and Gen3TacomaOBX like this.
  19. May 26, 2020 at 9:06 AM
    #7579
    Bigetaco22
    Kenny
    2016 DCSB TRD OR
    Fair enough
  20. May 26, 2020 at 9:07 AM
    #7580
    Bigetaco22
    Kenny
    2016 DCSB TRD OR
    Also would there be a difference in price?
    I would rather have catted for sure
Thread Status:
