OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. May 26, 2020 at 3:15 PM
    #7601
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Game ON!!!
  2. May 26, 2020 at 3:30 PM
    #7602
    Jrgymie
    Jrgymie Tuf MuddR
    Jeff
    Glastonbury, CT
    18 DCSB CEMENT TRD SPORT 4x4
    Looking for some input regarding boost controllers. Looking into the SCG-1: Solenoid Boost Controller by Innovate Motorsports.
    As I understand electronic boost controllers, not only does it afford some level of protection to help regulate boost, but also reduces turbo lag, regulates boost threshold, allows for increased boost above the waste gate spring rate.
    Wondering if it is something we should consider installing with the TT kit? Thanks for any input.
    @OVTune, any formal rec's regarding boost controllers?
  3. May 26, 2020 at 4:23 PM
    #7603
    soggyBottom
    soggyBottom Well-Known Member
    I think you can also decrease turbo lag by welding the waste gate shut.
    Torspd likes this.
  4. May 26, 2020 at 4:37 PM
    #7604
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Yea these are pre-machined pics. They will be properly cleaned up, aluminum oxide sanded, etc.
    LOL DO NOT DO THIS!!
    Skydvrr likes this.
  5. May 26, 2020 at 4:40 PM
    #7605
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
  6. May 26, 2020 at 4:53 PM
    #7606
    OVTune
    OVTune
    Boost controllers can only raise boost past wastegate base pressure.
    And I am telling you guys... there is no such thing as "lag" on these damn turbos. If you have the base turbos you see full boost practically off idle.
    I do not recommend a boost controlled unless you specifically want to run more boost. Boost controllers can only regulate boost past wastegate pressure.
    AKGSD, wahoobie, Quadabaum and 3 others like this.
  7. May 26, 2020 at 5:01 PM
    #7607
    TWTaco
    TWTaco Well-Known Member
    Dave
    Mat how hard is it on the base kit to add the DI later to get to 10+ psi? If i am not happy with the 6.5psi. Just a little worried with cost right now to add the DI right now been out of work now going on 5 weeks! Hopefully i get back and i dont have to worry about!
  8. May 26, 2020 at 5:03 PM
    #7608
    OVTune
    OVTune
    It's actually not that difficult to do. It's just a little annoying because you have to work right in the middle of the engine bay.
    I'd say it can be done in under 4 hours (with hand tools). Power tools would knock it out fast.
    Quadabaum likes this.
  9. May 26, 2020 at 5:03 PM
    #7609
    TWTaco
    Dave
    Okay great no worries then! Thank you!
  10. May 26, 2020 at 5:15 PM
    #7610
    Army504
    Army504 Well-Known Member
    Kauai
    2017 offroad
    best thing i hear on here ALL THE BOOST :anonymous:
  11. May 26, 2020 at 6:20 PM
    #7611
    Bigetaco22
    Bigetaco22 Well-Known Member
    Kenny
    2016 DCSB TRD OR
    Bilstein 6112/5160s. OME leaf springs. 285/75/16. RC tonneau cover. Supernova v3 led lows, highs, and fog lights. Kicker speaker upgrade.
    To answer your question, the current design will not work with the driver's left vent. I am kicking around the idea of making it universal for either of those vents so 1 design will fit in either location. It will just have 2 different sets of locking tabs.
    The cool thing about that is if you wanted afr you could have afr in 1 vent and boost in the other.
    But that's enough on this thread I am going to start a new one.
  12. May 26, 2020 at 6:33 PM
    #7612
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I wonder if they 3D print their molds for the casting. Sure looks like it.
  13. May 26, 2020 at 6:34 PM
    #7613
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    Maybe not the molds, but I wouldn't be surprised if the patterns and/or cores were.
    SC4333 likes this.
  14. May 26, 2020 at 6:38 PM
    #7614
    JamesT
    JamesT Well-Known Member
    2018 TRD Pro, MT
    Catted please.
  15. May 26, 2020 at 6:51 PM
    #7615
    rj_taco
    rj_taco Well-Known Member
    What's the reason to keep the PowerMax's with the DI upgrades @ 10 PSI vs the upper limit of 14? Will the same program handle all boost pressures?
    As far as cat vs non, any major loses with the cat version? I'm in TN, so either is fine.
  16. May 26, 2020 at 6:55 PM
    #7616
    Kodeman23
    Kodeman23 Member
    Seth
    San Diego
    2019 Tacoma TRD Pro
    M
    Forgive me for my ignorance, but I’m still struggling with the finer details here. I’m going with base + DI and want a boost controller to adjust the psi between 6.5-15. Is that the right way of thinking about how boost controllers work?
    jerzsubbie likes this.
  17. May 26, 2020 at 6:57 PM
    #7617
    Bigetaco22
    Kenny
    2016 DCSB TRD OR
    If you leave the wastegates the way Mat will have them set then yes. You will be able to run 6.5 psi as a base and increase that as you please with the controller.
    Kodeman23[QUOTED] likes this.
  18. May 26, 2020 at 6:59 PM
    #7618
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I'm not up on investment casting lingo, but u get it :thumbsup:
    lapoltba[QUOTED] likes this.
  19. May 26, 2020 at 7:09 PM
    #7619
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Crazy the resolution you can get though.
  20. May 26, 2020 at 7:13 PM
    #7620
    lapoltba
    CT - 06076
    Definitely. For large castings, even the roughest plastic extruder, 3d printed patterns for sand casting would be fine with some post-processing of the pattern. A lot of small investment castings are done with liquid resin 3d prints directly. The resins are developed to burn cleanly in a burnout cycle so you can pour directly into the molds. I have a friend that is using a Form Labs printer to do custom jewelry that way. At the very least, the molds to make the positives for the lost wax casting process can be 3d printed directly.
    Technology makes stuff like these manifolds orders of magnitude cheaper than just 10-15 years ago.
Thread Status:
