OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Jun 29, 2020 at 10:35 AM
    #8101
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    i was sooooo happy when i looked my VIN up.
    mZiggy likes this.
  2. Jun 29, 2020 at 12:09 PM
    #8102
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    I'm still working out the details on how we will go about this.
    because I guess the only option for some is either wait for dealer repair or purchase our replacement, even if they don't need the replacement for fuel demand.
    Kodeman23[QUOTED] likes this.
  3. Jun 29, 2020 at 12:19 PM
    #8103
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Maybe this has been discussed? For those waiting on a dealer repair, are drop in fuel pumps out of the option with your fuel controller?
  4. Jun 30, 2020 at 5:04 AM
    #8104
    Jrgymie
    Jrgymie Tuf MuddR
    Jeff
    Glastonbury, CT
    18 DCSB CEMENT TRD SPORT 4x4
    I have a MT. I bought a URD stage 3 clutch a while back anticipating that the stock clutch would eventually need replacing with the added torque. Probably will install it within the first 6 months after the TT kit gets installed.
    Curious to see how the OEM clutch holds up. I'm sure it will be fine unless you do a lot of towing or wheelin'.
    MOC221_[QUOTED], mZiggy and Torspd like this.
  5. Jun 30, 2020 at 8:00 AM
    #8105
    rj_taco
    rj_taco Well-Known Member
    So will we be able to run a boost controller without having to change the tune? As an example, 14 psi tune with a boost controller to dial it back/up when needed.
  6. Jun 30, 2020 at 8:22 AM
    #8106
    OVTune
    OVTune
    I have to test first to ensure the springs don't just get blown open from exhaust pressure when trying to run that much.
  7. Jun 30, 2020 at 9:12 AM
    #8107
    Tea-coma
    Tea-coma Well-Known Member
    AZ
    2017 Quicksand 4x4 TRD AT OV 91 tune
    Cold Air intake, Dual Exhaust, OV 1.05
    What are ideal ranges for a boost control for our setup
  8. Jun 30, 2020 at 9:20 AM
    #8108
    Tea-coma
    AZ
    Disregard..found the answer
  9. Jun 30, 2020 at 10:56 AM
    #8109
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
  10. Jun 30, 2020 at 11:00 AM
    #8110
    Bigetaco22
    Bigetaco22 Well-Known Member
    Kenny
    2016 DCSB TRD OR
    Bilstein 6112/5160s. OME leaf springs. 285/75/16. RC tonneau cover. Supernova v3 led lows, highs, and fog lights. Kicker speaker upgrade.
  11. Jun 30, 2020 at 1:06 PM
    #8111
    OVTune
    OVTune
    Garretts!!
    500lbs of powermax.
    AKGSD, Chipi3s, SC4333 and 31 others like this.
  12. Jun 30, 2020 at 1:09 PM
    #8112
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    That's an expensive crate!
    Sociopenguin likes this.
  13. Jun 30, 2020 at 1:21 PM
    #8113
    Bigetaco22
    Kenny
    2016 DCSB TRD OR
    I'll have 2 please!
    H3llRid3r likes this.
  14. Jun 30, 2020 at 5:30 PM
    #8114
    OVTune
    OVTune
    So, this video sucks.
    Ignore my check engine lights, I have my rear O2s completely removed for tuning purposes.
    This is with 4psi springs (because I was testing them).
    This is just cruising around, and getting up to highway speed. didn't floor it, just your average 10-15% pedal.
    you can see the peak 4psi is generated quickly under low throttle, and can hold 1-2psi at cruising speed, which is actually very nice, because it cruises at a very low throttle angle with the torque converter fully locked. (you can see it locking in the second half, s5). I'm playing with the gas pedal a little bit to see how boost fluctuates (you can see).
    once again, this video isn't very good. Sorry I am working on getting better videos.
    https://www.youtube.com/watch?v=SQvQOsRm2HQ&feature=youtu.be
  15. Jul 1, 2020 at 8:07 AM
    #8115
    Kodeman23
    Kodeman23 Member
    Seth
    San Diego
    2019 Tacoma TRD Pro
    For those of us with the recall, I just called the dealer and scheduled the recall work. I must’ve been dreaming previously because I thought there wasn’t a fix out yet. Appears that’s not the case.
    Shellshock likes this.
  16. Jul 1, 2020 at 8:15 AM
    #8116
    crigg93
    crigg93 Well-Known Member
    Chuck
    Rochester, NY
    2018 M/T MGM TRD Sport
    Ovtuned, Rokblokz, Toyo A/T II's on F5s, URD U-Spec, Afe Intake, Fox shocks, Dirtking UCAs, KC Flex ambers.
    You must have gotten lucky. ToyotaCare website says the remedy isn't available yet and my dealer told me that it most likely wouldn't be till end of this year/ early next.
  17. Jul 1, 2020 at 9:00 AM
    #8117
    Shellshock
    Iowa
    I’ve been checking and it still doesn’t show a fix for me either. From what others have said, most are targeting September at the earliest
    GillyLink likes this.
  18. Jul 1, 2020 at 9:07 AM
    #8118
    Kodeman23
    Kodeman23 Member
    Seth
    San Diego
    2019 Tacoma TRD Pro
    My dealer said the website is out of date. You may just want to book something and let the dealership tell you otherwise since they’ve got the inside knowledge.
  19. Jul 1, 2020 at 12:48 PM
    #8119
    OVTune
    OVTune
    Working hard prepping these kits.
    Regarding the intake specifically, it's designed for use with stock intake box.
    Will not work with anything except stock intake box.
    We had to machine a special intake component just for that. Previously was done with a welded piece. But doesn't look as nice.
    So you'll get a nice billet machined intake adapter for the twins. (3.25 taper to 2.5 for each turbo).
    All machined from 6061 billet Aluminum.
    Also the wastegate brackets and stuff but those aren't really as cool.
    Anyways have most of it sitting here, waiting on the downpipes.
  20. Jul 1, 2020 at 1:04 PM
    #8120
    disk_55FL
    disk_55FL Well-Known Member
    disk
    Buckeye
    '17 TRD Sport MT
    Classy AF !
Thread Status:
