OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Jul 17, 2020 at 4:28 PM
    #8341
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    food for thought.
    unplug the rear wheel speed sensors.
    unplug the ABS fuses.
    unplug skid control.
    and the back brakes don't work anymore. Pedal to the ground and they still spin freely.
    Edit*** disclaimer, this is what I am seeing on the dyno.
    MESO, AKGSD, SC4333 and 2 others like this.
  2. Jul 17, 2020 at 4:29 PM
    #8342
    lapoltba
    lapoltba Full Bridge Rectifier
    CT - 06076
    '17 Sport, ACLB, V6,MT, 04B14 OV-Tuned
    That is mildly terrifying..... WTF happens when one fails for some reason, you just don't get rear brakes? Does the same happen to the fronts? Inquiring minds need to know! LOL
    ihatemytruck and Shellshock like this.
  3. Jul 17, 2020 at 4:33 PM
    #8343
    OVTune
    OVTune
    fronts seem to work fine.
    maybe it's a TRD pro thing? Crawl control, and back brakes are all electronic?.....
    was a surprise.
    AKGSD and ihatemytruck like this.
  4. Jul 17, 2020 at 4:40 PM
    #8344
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Would be the same for the TRD OR then too. And I imagine AT vs MT doesn't work either since we get ATRAC. Crawl is just ATRAC with terrain management on cruise control.
  5. Jul 17, 2020 at 4:41 PM
    #8345
    lapoltba
    CT - 06076
    I know it's low on the priority list, but it would be awesome if somewhere you found a way to switch modes and actually disable ABS completely. I doubt it is possible in the ECM and you would likely need access to the Skid Control ECU. That is really the one reason I haven't looked any further into the locker anytime that everyone seems to want. I don't really want to do it without being able to disable ABS, Trac and VSC.
    MegaHurts777 likes this.
  6. Jul 18, 2020 at 7:32 AM
    #8346
    WalkinTaco
    WalkinTaco Well-Known Member
    2018 TRD OR M/T
    Th braking system in this truck is weird. Just had to bleed the whole system. You can't bleed the rear brakes with the truck off. Figured that out after 20 minutes of pumping... you actually just hold the brake down with the ignition on and an electric pump pumps fluid out. Master also has to be bled in tech stream too (first). Fronts lines can be bled normally so the fronts should work. and mine is an MT OR so it is the same.
    what is the issue with abs/trac/vsc being on with the locker? is the concern that it would brake 1 wheel and you would be fighting against the brakes stressing the driveline?
    I like traction control and all the nannies for normal driving but I really wish you could turn it all off and it actually be off when you want it off (and use the locker in 2wd). Sometimes the nanies do things that wouldn't expect and that can be more dangerous. I get why they do it as they don't want to be fielding warranties claims for people being idiots all the time but that whole situation is what is wrong with new vehicles imo. The sue culture and people blaming companies for things that should be common sense is why we have warning on pop bottles that say "warning contents under pressure cap may blow off and cause serious injury" like really? what happened that they felt the need to add that...
    BlkdOuT likes this.
  7. Jul 18, 2020 at 9:42 AM
    #8347
    slow.taco
    slow.taco Well-Known Member
    Art
    18 Tacoma TRD Sport
    Made payments on it
    But you own a 2012 2nd gen Tacoma buddy.
    You don’t need this kit.
    ownubad and Torspd like this.
  8. Jul 18, 2020 at 10:19 AM
    #8348
    Turd Hawg
    Turd Hawg Well-Known Member
    2018 DC SB OR AT (Sold)
    Yes, please bring this back up after several days...
    Got my dragy, 8.73 was my best 0-60. Full tank of 93 on 2.0. DC SB 2018 285/70’s on 5.29.
    MESO and TWTaco like this.
  9. Jul 18, 2020 at 11:27 AM
    #8349
    BoneTaco
    BoneTaco Well-Known Member
    Sacramento, CA
    17 DCLB OR
    Any of you guys in the first 25 live near Sacramento at all. I saw MESO was NorCal somewhere. Would love to see your setup once they make it out.
    GillyLink likes this.
  10. Jul 19, 2020 at 9:46 AM
    #8350
    BlkdOuT
    BlkdOuT Well-Known Member
    2017 Tacoma trd sport 4x4 MT TT
    Im about 1.5-2 hours away
    BoneTaco[QUOTED] likes this.
  11. Jul 19, 2020 at 9:09 PM
    #8351
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Rear brakes aren't solely electronic. But there is a solenoid to isolate the rear brakes from the master cylinder while leaving them available for control by the hydraulic pump/VSC/EBD/TRAC systems. My guess is unplugging the skid control ECU ends up in the rear brakes cut from the master cylinder. I'll see what I can dig up.
    low60eight likes this.
  12. Jul 19, 2020 at 9:23 PM
    #8352
    ShimStack
    Ben
    NC
    There's really nothing wrong with ABS, TRAC, and VSC active with the rear locker. A couple unique scenarios may behave oddly but most functions would still act as intended. It's basically not a concern with how I'm trying to do my locker anytime mod.
    Long press VSC at a stop. It turns off everything as far as we've been able to tell.
  13. Jul 19, 2020 at 9:56 PM
    #8353
    ShimStack
    Ben
    NC
    Ok, so while the hydraulic diagram does show that manual pressure to the rear brakes from the master cylinder is possible, all other descriptions of operation point to the rear brakes being normally isolated from the master cylinder and pressurized by the brake booster pump and accumulator.
  14. Jul 20, 2020 at 4:04 PM
    #8354
    OVTune
    OVTune
    downpipes are scheduled to be here this week
    CNC intake adapters done.
    We should be able to start shipping out base/powermax without-intercooler orders very soon!
  15. Jul 20, 2020 at 5:41 PM
    #8355
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    I need a reply to my zen desk request please. I’m being a cheapo in the email. No rush, just before shipping my order is all I ask.
    thanks Matt,
  16. Jul 20, 2020 at 6:53 PM
    #8356
    Speedwaytacotuesday
    Speedwaytacotuesday I love riding in my wife's Taco :p
    Calgary, Alberta
    2016 TACO LTD, 88 4runner, 4th Gen 4Runner
    TRD S/C 2.3" pulley mild ported Portmatched/cleaned intake runner Ucon EMS/cam gears/160 t-stat 840cc injectors 255 LPH walbro fuel pump Urd equal length headers Urd competition y-pipe AFE 3” Exhaust Vibrant resonator Oil Catch can Ratio-tek valvebody upgrade 3" bilstein/OME lift Dakar rear 7-leaf pack 32" KO2's load range C Stealth custom wheels Ray-10's Volk Te37X’s Tundra front 13.3” brakes Custom fab rock sliders LC-2 wideband autometer boost gauge Cravenspeed gauge pod mount Scangauge 2 SC MODS: Pulley ripp mod/belt wrap mod/ fleetrunner belt/ tensioner stop delete mod/ bypass jet delete mod
    I’m in the same boat myself and ask the same as well.
    Brostjoe likes this.
  17. Jul 21, 2020 at 8:32 AM
    #8357
    OVTune
    OVTune
    Emailing today (base/powermax w/out intercool)
    S/C kits / components also will be shipping same time.
    check spam folders please!
  18. Jul 21, 2020 at 8:48 AM
    #8358
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Just to be clear.. are you emailing and asking whether the buyers of the initial batch of 25 twin turbo kits want catted or cattless? Or something else?
    Thanks
  19. Jul 21, 2020 at 9:10 AM
    #8359
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    Who is going to be the first truck with twin exhausts through the hood? :bananadead:
    KnckleChldrn likes this.
  20. Jul 21, 2020 at 9:10 AM
    #8360
    OVTune
    OVTune
    Sorry this took a little longer to make them expected but all 25 are done.
    This is the piece that goes to stock inbox for the twins.
Thread Status:
