OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Aug 3, 2020 at 10:52 AM
    #8501
    JamesT
    JamesT Well-Known Member
    2018 TRD Pro, MT
    Convert to speed density and run post intercooler
  2. Aug 3, 2020 at 11:43 AM
    #8502
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Can't run SD.. Mat has tried
    On a happy note...:bananadance:
    wahoobie, ownubad, SC4333 and 12 others like this.
  3. Aug 3, 2020 at 11:47 AM
    #8503
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    I'm not surprised you're one of the first. It's good on Matt's end as heavy of a presence you probably have on social media.
    Keep us up to date!!!! :D
    TWTaco and mZiggy like this.
  4. Aug 3, 2020 at 11:51 AM
    #8504
    JamesT
    2018 TRD Pro, MT
    What was the reason? I thought all cars convert MAF into SD anyway? Granted I haven't seen the inside of a Tacoma's ECU, if it uses Volumetric Efficiency tables then you would think it should. This truck's ridiculousness never stops surprising me.
    Since you are running dual intakes, how did you work it?
  5. Aug 3, 2020 at 11:51 AM
    #8505
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    You kinda know what you're getting with Meso. Dude isn't dumb, he'll be able to do the install and provide solid feedback, no drama, best case scenario for the first tester
    Dirk Diggler and TWTaco like this.
  6. Aug 3, 2020 at 12:15 PM
    #8506
    TWTaco
    TWTaco Well-Known Member
    Dave
    I figure Meso will have it installed and dialed in in about 4hrs! Then terrorizing the neighbors doing hot laps around the block!!!!! :mudding::rofl::rofl::rofl:
  7. Aug 3, 2020 at 12:46 PM
    #8507
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Agreed this would make the most sense. I mean the man is thorough, clear, and concise. Doesn't hurt that he has a heavy vehicle and is mod happy. If anyone is going to install and give great feedback I feel like it'll be a slam dunk having Stu take a run at it
    inksin and TWTaco like this.
  8. Aug 3, 2020 at 12:51 PM
    #8508
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Agreed
    MESO and Dirk Diggler[QUOTED] like this.
  9. Aug 3, 2020 at 9:01 PM
    #8509
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Sure you can. Stand-alone. But then you're on your own. ;)
    Sleipnir likes this.
  10. Aug 3, 2020 at 9:54 PM
    #8510
    MESO
    State of Jefferson
    True. But that’s a whole new can of worms outside my pay grade. I was referring to integrating speed density into the stock ECU.. (which Mat told me he has not been able to do). A piggyback might work, but again I’m leaving it up to Mat to work his magic on the tune. He’s building the kit, and supporting the software so I’ll do whatever he suggests.
  11. Aug 4, 2020 at 10:20 AM
    #8511
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    this has been done quite a few times on 1st gens. gobs of torque right from idle but with the addition of that high rpm hp.
  12. Aug 4, 2020 at 12:55 PM
    #8512
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    our website link for the turbo kit is going to be updated shortly, will include some new information.
    for folks who want upgraded DI, we will be sending you links on how to purchase.
    we will be taking orders for our upgraded fuel pump + Fuel controller tonight as well.
    I have had plenty of time to test with our system and it is working exceptionally.
    *** on the fuel pump controllers ***
    There will be 3 options.
    Option A - send us a fuel pump controller (OEM), it will be modified with our PCB, and returned.
    Option B - depin / rewire the stock connectors to our connectors and box.
    Option C - Purchase a replacement OEM with our electronics (which we will provide you a used fuel pump controller that is modified) (while supplies last).
    Unfortunately the manufacturer that makes the connectors for toyota are in China, and about impossible to get ahold of reliably, and there is no quick solution to getting the males made. This is because the male connectors are an actual part of the whole controller, so they are special design.
    You can send us a used unit off ebay, I see them float around for about 70-90 bucks. There are dozens available. (*** must be out of a tacoma).
    ownubad, RedLantern, rj_taco and 3 others like this.
  13. Aug 4, 2020 at 1:41 PM
    #8513
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    This thing that’s bolted under cab of the truck?
  14. Aug 4, 2020 at 1:45 PM
    #8514
    OVTune
    OVTune
    yes
    RedLantern[QUOTED] likes this.
  15. Aug 4, 2020 at 1:55 PM
    #8515
    RedLantern
    Honolulu, Hi
    Thanks. Just bought one. Will be waiting for link.
  16. Aug 4, 2020 at 2:12 PM
    #8516
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Is that the one w the 2 - 10 mm nuts that go through the frame?
  17. Aug 4, 2020 at 2:13 PM
    #8517
    OVTune
    OVTune
    12mm but yes
  18. Aug 4, 2020 at 2:15 PM
    #8518
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Weird. I just pulled mine on Sunday, could a swore they were 10's.
  19. Aug 4, 2020 at 2:42 PM
    #8519
    OVTune
    OVTune
  20. Aug 4, 2020 at 2:45 PM
    #8520
    Bigetaco22
    Bigetaco22 Well-Known Member
    Kenny
    2016 DCSB TRD OR
    Bilstein 6112/5160s. OME leaf springs. 285/75/16. RC tonneau cover. Supernova v3 led lows, highs, and fog lights. Kicker speaker upgrade.
    So just to be clear, DI is all we need up to 14 psi?
    Anything beyond that needs pump and controller.
    Tea-coma likes this.
Thread Status:
