OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Aug 4, 2020 at 2:51 PM
    #8521
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    From what I've tested yes.
    However if you're planning to run more boost it would be in your best interest to upgrade the pump. No guarantee the stock pump will last long term with the additional flow requirement
    Especially with powermax.
    ownubad and MESO like this.
  2. Aug 4, 2020 at 2:57 PM
    #8522
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    @OVTune just out of random curiosity - are you planning to integrate some of these fuel/injector upgrades as part of your Magnuson tune to optimize their system?
    atpage likes this.
  3. Aug 4, 2020 at 2:57 PM
    #8523
    Speedwaytacotuesday
    Speedwaytacotuesday I love riding in my wife's Taco :p
    Calgary, Alberta
    2016 TACO LTD, 88 4runner, 4th Gen 4Runner
    TRD S/C 2.3" pulley mild ported Portmatched/cleaned intake runner Ucon EMS/cam gears/160 t-stat 840cc injectors 255 LPH walbro fuel pump Urd equal length headers Urd competition y-pipe AFE 3” Exhaust Vibrant resonator Oil Catch can Ratio-tek valvebody upgrade 3" bilstein/OME lift Dakar rear 7-leaf pack 32" KO2's load range C Stealth custom wheels Ray-10's Volk Te37X’s Tundra front 13.3” brakes Custom fab rock sliders LC-2 wideband autometer boost gauge Cravenspeed gauge pod mount Scangauge 2 SC MODS: Pulley ripp mod/belt wrap mod/ fleetrunner belt/ tensioner stop delete mod/ bypass jet delete mod
    So you will be no longer supplying the DI upgrade and to instead buy using the link?
  4. Aug 4, 2020 at 3:02 PM
    #8524
    OVTune
    OVTune
    So hopefully nobody gets mad..but we will no longer be offering tunes for the upcoming SCs.
    We are focused on our forced induction kit only.
    We *may* do something in the future, but nothing is planned.
    They are the same ones we tested. They are just a bit cheaper now so it's actually easier to order them directly.
  5. Aug 4, 2020 at 3:05 PM
    #8525
    sdfuller88
    sdfuller88 Well-Known Member
    Reno, NV
    @OVTune which turbo kit do you recommend for heavy vehicles/towing?
  6. Aug 4, 2020 at 3:14 PM
    #8526
    rj_taco
    rj_taco Well-Known Member
    Option B and DI’s ordered. Thanks Mat.
    When would recommend upgrading the PI’s?
  7. Aug 4, 2020 at 3:14 PM
    #8527
    OVTune
    OVTune
    Both versions perform nearly the same, until you start pushing higher boost.
    If I wanted more power, torque, response, and *dont* plan on going for 400+ HP, then the base kit is perfect.
    ownubad and Dirk Diggler like this.
  8. Aug 4, 2020 at 3:15 PM
    #8528
    Tea-coma
    Tea-coma Well-Known Member
    AZ
    2017 Quicksand 4x4 TRD AT OV 91 tune
    Cold Air intake, Dual Exhaust, OV 1.05
    What is the turn around time for option A
  9. Aug 4, 2020 at 3:18 PM
    #8529
    Turd Hawg
    Turd Hawg Well-Known Member
    2018 DC SB OR AT (Sold)
    DI and option C ordered.
    Thanks for dedicating time to the turbos over others Superchargers.
    ownubad, Dirk Diggler and Shellshock like this.
  10. Aug 4, 2020 at 3:18 PM
    #8530
    OVTune
    OVTune
    This is a great question.
    I do not recommend upgrading the PIs unless you plan on going E85.
    A few reasons.
    1. The boost levels required to make changing out the PIs necessary is unsafe for pump gas (so you need more octane)
    2. This ECU does not have very good low pulse width modulation on the PIs at idle, so if you run huge PIs at idle on pump gas the truck runs stupid rich.
    With upgraded DI + upgraded in tank pump you can do 15psi on the powermax all day no problem and even go stupid rich since there is still more fuel window available.
    When you start going into the 20s on boost, the DI system is taxed.
    But 20s on pump gas is grenade anyway.
    Short answer: unless you're trying to go for crazy quarter mile times, or just "need" 550+ ft lbs, don't worry about the PI.
    ownubad and rj_taco[QUOTED] like this.
  11. Aug 4, 2020 at 3:28 PM
    #8531
    Tea-coma
    AZ
    Option C ordered
  12. Aug 4, 2020 at 3:30 PM
    #8532
    OVTune
    OVTune
    There isn't an exact turn around. The plan was to ship it with your TT kit, so timeline depends on which downpipe, and intercool vs non version.
    I do expect to have all kits shipped by the end of the month, because the catted DPs will be here around the 20th,
    Let me add I highly recommend you guys DO NOT send me the one from your truck. Buy a used one. It's an irreversible conversion.
  13. Aug 4, 2020 at 4:21 PM
    #8533
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    The fuel pump thing is still only for people running anything above the base kit 6.5psi right? No need to order anything for those of us basics who only wanted the base kit with no add-ons?
    TurdTaco64 likes this.
  14. Aug 4, 2020 at 4:25 PM
    #8534
    OVTune
    OVTune
    Correct.
    ownubad likes this.
  15. Aug 4, 2020 at 4:25 PM
    #8535
    Max713
    Max713 Well-Known Member
    Max
    Eugene, OR
    2017 MGM TRD OR
    No, there is a step between there.
    Base kit @ 6.5psi, no fuel upgrade
    Base kit @ up to 14psi, injector upgrade
    Base kit @ over 14psi, injector and pump upgrade
    Although Matt did just clarify that a pump upgrade would not be a BAD idea at higher boost levels on the base kit.
    mZiggy[QUOTED] likes this.
  16. Aug 4, 2020 at 4:41 PM
    #8536
    rj_taco
    So safe limit for PowerMaxes on 91+ octane with DIs and upgraded FP is 15 psi, how much timing is it taking on top end? 450whp/450wtq on 15 or is that stretching it?
  17. Aug 4, 2020 at 4:48 PM
    #8537
    Turd Hawg
    Fuel pump could also be for those on the fuel pump recall list that don’t want to wait on Toyota, that’s why I’m getting one.
    ownubad and Gen3TacomaOBX like this.
  18. Aug 4, 2020 at 5:00 PM
    #8538
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Is the high boost gonna be useable from a dead stop full throttle launch...Or will the traction control close the throttle making the truck no fun to drive?
  19. Aug 4, 2020 at 5:01 PM
    #8539
    Toyotafanforlife1991
    Toyotafanforlife1991 Live FREE and drive a TOYOTA!!!
    Brandon
    Dickson, Tennessee
    2016 QS Tacoma DCSB OR M/T, 1970 Toyota Land Cruiser FJ40 351W M/T, 1982 Toyota Hilux SR5 M/T, 1983 Toyota Hilux SR5 M/T (undergoing frame off restoration)
    Just out of curiosity what changed with tuning the Magnusson S/C, Just can't devote the time right now? Are you running one of their setups at all still? I only ask because I'm curious and I haven't seen anything with the Mag S/C since the pic you posted. Not trying to derail the tread or anything. Just had really high hopes for you to offer a tune for their setup. Any info is super appreciated bud! Thank you.
    ownubad, atpage and sorevilo like this.
  20. Aug 4, 2020 at 5:19 PM
    #8540
    KnckleChldrn
    KnckleChldrn Well-Known Member
    Jamie
    Mass
    2017 Tacoma TRD Sport DCSB MT
    Suspension OME 886 Coils OME Nitro Charger Sport shocks OME Nitro Charger Sport struts Deaver Expedition leaf pack Mickey Thompson wheels 265/70/17 KO2 Total Chaos upper control arms Performance K&N air intake Exterior Southern Style Offroad slim line bumper Smittybilt x20 winch Interior Kicker tweeters, front and rear speakers Anytime front and rear camera Hondo Garage stereo knobs Hondo Garage un-Holley mount MESO black out door handles MESO steering wheel MGM overlay MESO puddle pods MESO ultimate red map lights MESO ultimate red dome MESO gasshole MESO ultimate turn signals MESO BD5 3rd brake light MESO stage 3 side markers Retrofit Morimoto 2.0 headlights RGB halo RGB demons RGB DRL Cali Raised raptor LED tail lights SpartanXCustoms scoop light Baja Designs Squadron Sports fogs (amber) Baja Designs Squadron Pro ditch (amber) Baja Designs S8 20" Matt Gecko bed lights Matt Gecko hood lights Switchpro 9100 OEM bed mat 300 Industries grill Bakflip Fibermax cover
    Option c, di’s, vf tuner and cable purchased...ouch! Haha but will be well worth it!
    Dirk Diggler likes this.
Thread Status:
