OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Aug 21, 2020 at 3:40 PM
    #8861
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    TurboS
    You had one job! :D:p
  2. Aug 21, 2020 at 4:16 PM
    #8862
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :rofl::rofl:
    ihatemytruck likes this.
  3. Aug 21, 2020 at 4:18 PM
    #8863
    Turd Hawg
    Turd Hawg Well-Known Member
    2018 DC SB OR AT (Sold)
    looks good, I’m going this way...
  4. Aug 21, 2020 at 6:56 PM
    #8864
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    I do like that muffler bypass actuator, I missed that in the first post.
  5. Aug 21, 2020 at 8:16 PM
    #8865
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Thanks!
    DP all wrapped and converted to VBAND
    Holy piping Batman o_O
    DP is tight. Will do more heat shielding but the wrap will definitely help
    I/C piping just mockup. Will powdercoat when done and switch to all black couplers. 1.75” turbo out to 2.5” runners- merge to 3” Y to FMIC
  6. Aug 21, 2020 at 8:40 PM
    #8866
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    How is the fitment on those PTP outside blankets? It looks like a good fit.
    Sleipnir likes this.
  7. Aug 21, 2020 at 8:43 PM
    #8867
    MESO
    State of Jefferson
    Great! Little tight against the valve cover but nothing major.
  8. Aug 21, 2020 at 9:16 PM
    #8868
    rj_taco
    rj_taco Well-Known Member
    Looking great! Dual MAF’s???
  9. Aug 21, 2020 at 9:54 PM
    #8869
    JamesT
    JamesT Well-Known Member
    2018 TRD Pro, MT
    My guess would be that he is going to put only one between the throttle body and intercooler since i don't see them on the intake pipes. Thats a long and straight enough run for it to work post turbo. It's called blow through MAF. This is what I am considering doing.
    It just has to be on a straight and long enough pipe for the air to smooth out. I think the math is 3x as long as the diameter of your pipe. It's a little more tricky to do but it's common (especially with people who run atmospheric bov's) and does work if set up properly.
  10. Aug 22, 2020 at 6:20 AM
    #8870
    soggyBottom
    soggyBottom Well-Known Member
    Did you use 321 for that? I've generally never liked the idea of exhaust wraps because of water/dirt retention. I have no evidence of this actually being a problem. Do you live in a wet climate? Have you had any issue with something like this?
    tonered likes this.
  11. Aug 22, 2020 at 6:44 AM
    #8871
    rj_taco
    Well I hope that works, was wanting to go that route as well. Hopefully MESO or Mat will jump in to confirm.
  12. Aug 22, 2020 at 7:04 AM
    #8872
    Sleipnir
    Sleipnir Still havent found that stupid snipe
    I'm a horse
    Asgard
    Furd Rangero Ecoboost
    So when do you do the supercharger with the twins? Just asking for a friend :popcorn:
    Torspd and brtnstrns like this.
  13. Aug 22, 2020 at 8:17 AM
    #8873
    OVTune
    OVTune
    To test MPG and 6th gear driving, I did 100 mile trip this morning.
    All highway.
    Entire trip was in 4High with gear lock, and torque converter locked. To produce the worse results possible.
    I did not leave 6th gear once. Including going up hills that would require 4th gear on a normal truck.
    MPH testedfrom 65-80mph.
    I can, with ease, increase speed up hill in 6th, from RPM as low as 1500.
    I modified the tune slightly so that you can smoothly accelerate in 5th or 6th from RPM as low as 1400.
    MPG test report: 20.9 mpg.
    I also have a full datalog I will post today that shows our fuel pump controllers pressure stability, increase rate, etc that was captured during the trip.
    Just wanted to give you guys and update that it is running phenomenally in all test conditions, even absolute terrible conditions: uphill, 6th gear, 1500 rpm, full throttle. No problem.
    Unfortunately we have been having terrible weather and flash floods so serious off-road testing is limited.
    When there is a good enough day we will test at Patriot mountain and post some videos and results.
    I will also post a brief explanation of how our fuel pump control code and algorithm works so that it actually thinks ahead, to ensure that there is never a pressure dip under any circumstances. It works so well that we may make this a standard item for trucks regardless of boost or not.
  14. Aug 22, 2020 at 8:42 AM
    #8874
    atpage
    atpage Well-Known Member
    Western NY
    Do you have stock gears?
  15. Aug 22, 2020 at 9:55 AM
    #8875
    Kodeman23
    Kodeman23 Member
    Seth
    San Diego
    2019 Tacoma TRD Pro
    How does that MPG compare to stock for your truck?
    soggyBottom likes this.
  16. Aug 22, 2020 at 10:02 AM
    #8876
    o313
    o313 Well-Known Member
    N
    2018 DCLB AT SC
    Ahhhh, in 4H using only 6th gear? is this a scenario you plan on driving much? /s
  17. Aug 22, 2020 at 10:25 AM
    #8877
    Kodeman23
    Kodeman23 Member
    Seth
    San Diego
    2019 Tacoma TRD Pro
    No shit it’s not, but if he’s getting 18 driving in 2WD on the highway then that says a lot about the tune and setup.
    auskip07 likes this.
  18. Aug 22, 2020 at 10:52 AM
    #8878
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    Any improvement in fuel mileage along with added horsepower and torque is a plus. I don’t know enough about modern engines and tuning to debate a single thing. Sadly though there are just too many variables to speak of what can happen to each individual truck due to physical components, elevation, temperature, and driver plus more I may not be thinking of.
    All in all I enjoy seeing the product come along. One day I hope to see an available product that can ultimately be ordered, installed, tuned, and driven within a 2 week time frame most of which down time comes from the product being installed vs wait time from developer. Best of luck to everyone involved on front end and back end of this venture as well as people who are in process of getting parts and installation. Hope everything goes without a single hiccup and this turns out to be huge!
    Kodeman23[QUOTED] likes this.
  19. Aug 22, 2020 at 11:21 AM
    #8879
    OVTune
    OVTune
    So onto the fuel pressure control.
    here is our log snip
    Target base pressure is 48psi with a +/- 3psi tolerance. (steady state)
    Pressure change is dynamic, and can change 5, 10, 20, 30 psi depending on demand.
    Using our algorithm the fuel pump controller will ramp pressure from 48 all they way to 80psi.
    this is done on the fly based on calculated rate of change in fuel pump requirement with a 2ms response time.
    Our fuel pump control algorithm maps, smooths and stabilizes the raw output signal from the ECU.
    The signal is sampled 4 times.
    This signal is then fed through a secondary smoothing and duty cycle algorithm.
    The current duty cycle is then compared to the incoming signal to calculate a rate of change in expected duty cycle. This is to ensure that there is zero delay in increasing fuel demand when it is ran through our duty cycle algorithm
    Depending upon the rate of change our code will calculate a trim factor to apply to the duty cycle.
    There are 6 different mapped out trim factors that apply depending upon the calculated duty change rate.
    This trim factor is then applied to the current and upcoming duty cycle, so that when you stab the throttle and the engine requests more fuel, the fuel pump controller has already calculated the increase rate by the time the ECU starts demanding the extra fuel.
    The result is a steady cruising pressure with near instantaneous pressure increase with throttle and increased fuel requirement.
    The pressure will also be trimmed off after a high load event (say burst, 70+psi) happens down to 30psi (decel).
    and it is working fantastically.
    You can also update the firmware right from home as well if it ever needs updated
  20. Aug 22, 2020 at 2:30 PM
    #8880
    soggyBottom
    When you said you would be posting a log I assumed you would be posting a .log file or perhaps a CSV.
    Sorry to be so needy but do you have a larger screenshot?
Thread Status:
