OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Aug 25, 2020 at 5:17 PM
    #8961
    Tea-coma
    Tea-coma Well-Known Member
    AZ
    2017 Quicksand 4x4 TRD AT OV 91 tune
    Cold Air intake, Dual Exhaust, OV 1.05
  2. Aug 25, 2020 at 5:30 PM
    #8962
    Speedwaytacotuesday
    Speedwaytacotuesday I love riding in my wife's Taco :p
    Calgary, Alberta
    2016 TACO LTD, 88 4runner, 4th Gen 4Runner
    TRD S/C 2.3" pulley mild ported Portmatched/cleaned intake runner Ucon EMS/cam gears/160 t-stat 840cc injectors 255 LPH walbro fuel pump Urd equal length headers Urd competition y-pipe AFE 3” Exhaust Vibrant resonator Oil Catch can Ratio-tek valvebody upgrade 3" bilstein/OME lift Dakar rear 7-leaf pack 32" KO2's load range C Stealth custom wheels Ray-10's Volk Te37X’s Tundra front 13.3” brakes Custom fab rock sliders LC-2 wideband autometer boost gauge Cravenspeed gauge pod mount Scangauge 2 SC MODS: Pulley ripp mod/belt wrap mod/ fleetrunner belt/ tensioner stop delete mod/ bypass jet delete mod
    Went with a cheap reliable Turbosmart MBC for now but will prob go with this Greddy profec boost controller down the road if more features is desired. Trying to keep interior stock/clean looking, the less obvious gauges the better.
    RedLantern and Tea-coma[QUOTED] like this.
  3. Aug 25, 2020 at 8:12 PM
    #8963
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    I have the turbo smart dual stage boost controller ordered. I don’t care for changing the boost pressure much, all I want is LOW and HIGH.
    ~7-8psi for low mode(around town, grocery shopping, malls) and ~14-15psi for high mode(when I pull up next to ridgelines or raptors). Each mode is manually dialed in at the controller, then activated in the cab. It will be wired to my Pro Stealth knob so I can hit it on the fly:D
  4. Aug 26, 2020 at 5:24 AM
    #8964
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I've got the older Profec B2. It was a great unit. Which makes me feel this one will be as well.
    Speedwaytacotuesday likes this.
  5. Aug 26, 2020 at 6:41 AM
    #8965
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Oh dang thats gonna be sweet!
    GillyLink and MESO[QUOTED] like this.
  6. Aug 26, 2020 at 8:22 AM
    #8966
    Speedwaytacotuesday
    Calgary, Alberta
    Agreed, I’ve had the older profec spec b on a couple of my turbo vehicles back in the day and they were great.
    Torspd[QUOTED] likes this.
  7. Aug 26, 2020 at 9:45 AM
    #8967
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    I read this an thought same thing at first. Then I got to thinking about the trucks warranty which is much longer (lifetime power train) than the OVTune warranty. Installing turbos will completely void that anyway so honestly warranty would not be my concern unless something happened right off the bat after install. Typically if things are going to fail they’ll fail earlier than later.
    Anyway, as for towing I’d definitely want what warranty that came with the product to be valid for what the truck was originally designed for as stock.
  8. Aug 26, 2020 at 9:55 AM
    #8968
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    You MF! That's so rad
    MESO[QUOTED] likes this.
  9. Aug 26, 2020 at 9:58 AM
    #8969
    Bigetaco22
    Bigetaco22 Well-Known Member
    Kenny
    2016 DCSB TRD OR
    Bilstein 6112/5160s. OME leaf springs. 285/75/16. RC tonneau cover. Supernova v3 led lows, highs, and fog lights. Kicker speaker upgrade.
    @OVTune What is the new oil capacity with the new pan?
    SC4333 likes this.
  10. Aug 27, 2020 at 7:51 AM
    #8970
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    TT owners once they've got their kits installed:
  11. Aug 27, 2020 at 8:01 AM
    #8971
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Oops! I hope he's not dropping flares for escort after busting the DC SFRA. :plane:.....:fenforcer:
    maytime likes this.
  12. Aug 27, 2020 at 9:28 AM
    #8972
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    7 quarts
    mZiggy likes this.
  13. Aug 27, 2020 at 9:34 AM
    #8973
    mZiggy
    mZiggy Honey badger
    Marc
    Got anymore of them catted dp updates from your peoples?
  14. Aug 27, 2020 at 10:30 AM
    #8974
    TheToyotaGarage
    TheToyotaGarage Well-Known Member
    Monroe
    Pacific NorthWest
    2017 TRD Toyota Tacoma
    King 2.5 Resi / ADJ/ EXT - king 2.0 Rear Bump Stops - Kibbetech Gold Billet UCA's - 285/75/17 10ply Nitto Ridge Grapplers - Stealth Custom Series 17x9 -38 Stealth Blue Ray10's, Icon RXT Rear Leaf Springs
    I've asked a few times with no response. :burnrubber:
  15. Aug 27, 2020 at 10:32 AM
    #8975
    OVTune
    OVTune
    I just talked about it like a page ago.
    As soon as we have a firm date, you guys are the first to know...
  16. Aug 27, 2020 at 1:23 PM
    #8976
    TheToyotaGarage
    Monroe
    Pacific NorthWest
    Thanks man!
    Sleipnir likes this.
  17. Aug 29, 2020 at 9:38 PM
    #8977
    NorthShoreTacos
    NorthShoreTacos Well-Known Member
    Hawaii
    How can I be put on a list? I emailed with no response
  18. Aug 29, 2020 at 9:54 PM
    #8978
    Shellshock
    Iowa
    next round of orders is expected in october sometime. there is no list.
    Skydvrr likes this.
  19. Aug 29, 2020 at 10:09 PM
    #8979
    NorthShoreTacos
    Hawaii
    Awesome, I'll wait patiently
  20. Aug 30, 2020 at 3:42 AM
    #8980
    mZiggy
    mZiggy Honey badger
    Marc
    No list. Mat will simply announce that another round of pre-orders is open and if you get a spot, you get a spot.
Thread Status:
