OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Oct 5, 2020 at 11:39 AM
    #9561
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Is that a Moto?
    tonered[QUOTED] likes this.
  2. Oct 5, 2020 at 11:40 AM
    #9562
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yeah. The Ural that I had and got rid of just before the Taco. It was what set the wheeling hook for me.
    su.b.rat likes this.
  3. Oct 5, 2020 at 11:58 AM
    #9563
    JamesT
    JamesT Well-Known Member
    2018 TRD Pro, MT
    Look at it this way.
    - When the truck is in vacuum (no throttle) the intake manifold is pulling blow by gases out of the crankcase, and along with it: oil, water, acid, contaminated air. At this time the passenger side breather is pulling fresh air from the intake pipe (pre throttle body) into the crank case.
    - When the truck is in boost, the intake pipe (pre throttle body) is now pulling blow by gases out of the crankcase. The reason for the 1 way valve on the pcv side is to prevent the now boosted (positive pressure) intake manifold from "leaking" boost out into the crankcase.
    So when you are at idle, you have contaminants going directly into your intake manifold. When you are at boost you have contaminants going directly into your intake pipe. Normally this isn't that bad when you are N/A. When you add turbos you increase blow by gases.
    A catch can on the manifold (driver) side is HIGHLY recommended, as this is the main outlet for your blow by gases.
    A catch can on the intake pipe side is recommended as a safety assurance, especially if it's piped in before the turbo, because the turbo will pull those contaminants and oil into the turbo vanes. This will eventually muck up your turbo. This side "shouldn't" see as much blow by so a smaller catch can will work here.
    You can run two catch cans (1 on each side), or you can run one if it's dual valved (3 ports). The picture OV posted above is the setup you would use for a dual valve. This pipes both sides through 1 catch can so it's pulling contaminants during each cycle (vacuum/boost). It's just a consolidation or a way to tidy up your bay. Neither is really better than the other. Both setups work.
    It's imperative that you have that 1 way check valve on the PCV side though. If you run a dual valve can, you need two check valves.
    It's a good, better, best scenario. No catch can won't kill the engine, only muck things up over time and hurt performance a tiny bit.
  4. Oct 5, 2020 at 12:05 PM
    #9564
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    You know that honu (turtle) are considered good luck in Hawaiian culture so it's probably pretty good to have them riding with you on 2 wheels. :thumbsup:
  5. Oct 5, 2020 at 12:08 PM
    #9565
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yessir. A very good friend of mine is from the Islands. He donated the water bottle.
    The only problem is that the printed stuff came off over time when cleaning it after dumping out the collected junk.
    Dammit Evie and inksin[QUOTED] like this.
  6. Oct 5, 2020 at 2:19 PM
    #9566
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Under the hood finally done. (actually just need to add a check valve on the drivers catch can, and program the PWM fan).
    It's crammed, Every inch is taken up.
    x[​IMG]
    Mat wasn't kidding the oil pan gasket is on there good. 4 flat heads later..
    TSAVO, BassAckwards, Torspd and 18 others like this.
  7. Oct 5, 2020 at 3:08 PM
    #9567
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    The install looks so clean. No red pipes and chrome clamps.
  8. Oct 5, 2020 at 3:12 PM
    #9568
    MESO
    State of Jefferson
    So I can pass it off as stock:anonymous:
  9. Oct 5, 2020 at 3:22 PM
    #9569
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    If the intercooler was black or plastic covering then yes to a passerby.
  10. Oct 5, 2020 at 3:37 PM
    #9570
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    "its a toyota ecoboost v6".
    GillyLink, Sleipnir and MESO[QUOTED] like this.
  11. Oct 5, 2020 at 3:53 PM
    #9571
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Hey wait a minute! Your oil pan was already tapped? :confused:
  12. Oct 5, 2020 at 4:48 PM
    #9572
    whitedlite
    USA!
    3RD Gen TRD 4WD
    I really hope OVTune or MESO make a recommended mods and such with reasoning when everyone’s setup is done. I’ve got a lot of reading later when this stuff comes in
  13. Oct 5, 2020 at 5:02 PM
    #9573
    MESO
    State of Jefferson
    No, that's the last component I need. Everything underhood(or topside I should say) is ready to rock.
    Skydvrr[QUOTED] likes this.
  14. Oct 5, 2020 at 5:58 PM
    #9574
    Tea-coma
    Tea-coma Well-Known Member
    AZ
    2017 Quicksand 4x4 TRD AT OV 91 tune
    Cold Air intake, Dual Exhaust, OV 1.05
    Time for street videos
    Skydvrr likes this.
  15. Oct 5, 2020 at 6:18 PM
    #9575
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    looks excellent, and without the stock airbox there is so much room for piping.
  16. Oct 5, 2020 at 6:20 PM
    #9576
    OVTune
    OVTune
    Since you guys were walking about oil catch cans and such I think we will CNC our own for our TT system.
  17. Oct 5, 2020 at 6:27 PM
    #9577
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    I don’t mind that at all! Just add it to my order lol
  18. Oct 5, 2020 at 6:47 PM
    #9578
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    This would be perfect. I could then just sell my universal cans locally.
  19. Oct 5, 2020 at 7:23 PM
    #9579
    OVTune
    OVTune
    I like the idea of having something that can be mounted on top of the fuse box, or another easy to get to place.
    That catch can pictured before is very nice, but taking the front grille pieces off to drain kind of sucks.
    obviously this isn't what it will look exactly like because I made this model in 5 mins lol, and I can't promise I will even go through with developing it, but the general idea,
    2x top ports go from each turbo post maf
    those two supply fresh air via the left port to the passenger side valve cover (fresh air vent), that is divided from the vacuum side, inside the catch can
    The right side has 2 ports (you can only see 1 in this image) that collects the vapor filled gunk from inside the engine, and exits through another port into the intake manifold.
    This allows you to:
    retain fresh air breathing through the engine that is post MAF measured
    allows for collection of vapors before it enters the intake manifold
    does not allow for any possibility of the fresh air breathers causing a vacuum leak.
    requires only 1 check valve.
    (model is for example..whipped it up in 5 mins. it won't look this ugly)
    The stock setup uses a post Maf (measure air) breather on the passenger side, that feeds through the engine, collecting vapors, and exiting into the intake manifold, creating a closed system.
    It's critically important the catch can does not create a leak in the system by introducing unmetered air.
    Also very important that the catch can does not bypass the actual metered fresh air circulating through the engine before being collected.
    BassAckwards, tonered, Torspd and 8 others like this.
  20. Oct 7, 2020 at 5:29 AM
    #9580
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Mighty nice welds sir. :thumbsup:
    MESO[QUOTED] likes this.
Thread Status:
