OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Oct 22, 2020 at 2:37 PM
    #9761
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Exactly. The issue can be more granular than the state level. For example only the major metro areas (certain counties) of Virginia have emissions testing.
  2. Oct 22, 2020 at 2:38 PM
    #9762
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Yep, and Virginia inspections don't care. My truck passed inspection with turbo kit on it.
  3. Oct 22, 2020 at 2:39 PM
    #9763
    Bigetaco22
    Bigetaco22 Well-Known Member
    Kenny
    2016 DCSB TRD OR
    Bilstein 6112/5160s. OME leaf springs. 285/75/16. RC tonneau cover. Supernova v3 led lows, highs, and fog lights. Kicker speaker upgrade.
    Depends on where at. Some areas don't have emissions and some do.
  4. Oct 22, 2020 at 2:42 PM
    #9764
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    can't say for sure - depends on where you live in Colorado and some undefined unknowns. Shit show. Some get a pass cause the inspector is slow and slower between the ears - others like to fail based on visual. 1st rule - do not take it to a Aire Care facility - those monkeys like to break shit and act like it is their job. Go through the roadside test. Your initial will have to be at the oh shit shop cause they will inspect it for oem emissions equipment. You probably could run the snails and or a SC but wait until after your initial passing emissions test - then use the roadside (every other year for inspections for cars resold or not new - new get a 7yr pass). Worst case you fail and may have to remove the mod. And btw - there are rumblings that the ENTIRE STATE is going to fall under the Air Quality Emissions Requirement.
  5. Oct 22, 2020 at 3:11 PM
    #9765
    Bigetaco22
    Kenny
    2016 DCSB TRD OR
    I have also heard they are close to abandoning aire care colorado also after their next contact is up.
  6. Oct 22, 2020 at 3:12 PM
    #9766
    soggyBottom
    soggyBottom Well-Known Member
    If I go, it's going to be springs so that's good to hear
  7. Oct 22, 2020 at 3:20 PM
    #9767
    OVTune
    OVTune
    That was 7 years ago tho. No idea about now.
  8. Oct 22, 2020 at 4:13 PM
    #9768
    GoldenBrew
    Golden, Colorado
    they are just a vendor that provides the service. Contracts come and go. Emission Laws are different especially when you live in a PM10 and COG area. The chances of our emission requirements going away or being relaxed are less than zero. But if all the people that moved here in the last 30 years would go back to the State they came from it might be possible.
  9. Oct 22, 2020 at 4:15 PM
    #9769
    GoldenBrew
    Golden, Colorado
    Springs is in the emission requirement area. try Pueblo or east.
  10. Oct 22, 2020 at 4:40 PM
    #9770
    OVTune
    OVTune
    I left when cannabis started its boom and manitou and the springs because overridden with homeless.
    Not originally from Colorado but still feel like that's my home state.
    Too bad it's not the same.
    GillyLink and Front sight like this.
  11. Oct 22, 2020 at 5:02 PM
    #9771
    Ackattack911
    Ackattack911 Member
    I'm in pueblo no emission requirements here. You are completely right about the homeless population increasing. Working in a hospital I've talked to many people that came to colorado for the marijuana. I guess they probably didn't know it was going to be so expensive. There are far more homeless than there used to be.
  12. Oct 22, 2020 at 5:59 PM
    #9772
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    when did that happen? i left in 2018 and it wasnt when i was there
  13. Oct 22, 2020 at 6:04 PM
    #9773
    wrmathis
    Bonaire, GA
    parts and stuff
    from the colorado.gov website
    County requirements
    • You must have an emissions inspection done on any gasoline-powered vehicle when you register, renew registration for, or sell the vehicle within the Automobile Inspection and Readjustment (AIR) program area. The program area covers all or parts of the following counties:
      • Adams (west of Kiowa Creek).
      • Arapahoe (west of Kiowa Creek).
      • Boulder.
      • Broomfield.
      • Denver.
      • Douglas.
      • Jefferson.
      • Larimer (Fort Collins, Loveland, Windsor, and surrounding mountain areas).
      • Weld (Greeley, Windsor and the I-25 corridor).
    • Vehicles registered to an address outside the program area but driven regularly into the program area (e.g., for work or school) must be inspected.
    El Paso county, where colorado springs is, aint on that list
  14. Oct 22, 2020 at 6:11 PM
    #9774
    GoldenBrew
    Golden, Colorado
    gotta a guess you are Military and not civilian ? Local law for Military is not the same as joe public. ?? If C Springs is not on the list they are lucky - we should all move there!
  15. Oct 22, 2020 at 6:13 PM
    #9775
    wrmathis
    Bonaire, GA
    parts and stuff
    yeah but the website and firends that arent military dont have to smog or inspection
  16. Oct 22, 2020 at 6:18 PM
    #9776
    wrmathis
    Bonaire, GA
    parts and stuff
    and there is no aircare stations down in colorado springs. only Diesel is required
    also from https://clerkandrecorder.elpasoco.com/motor-vehicle-department/additional-information-late-fees/
    Additional Information & Late Fees
    Emissions
    • If moving from another county within the state of Colorado, emission requirements and fees may differ. In El Paso County, emissions tests are required only for diesel vehicles.
    • However, if you commute to an area in the state that requires emissions tests at least 90 days per year for employment or school you will need an emissions test even though your vehicle is not registered in that area. Read more here https://tinyurl.com/tl2sevh.
    • Please contact our Motor Vehicle Office via email at motorvehicledept@elpasoco.com for information.
    • Online services are available, Emissions Waiver and Out-of-State Emissions Extension https://mydmv.colorado.gov. For further emissions information (including diesel requirements) click this link Colorado Motor Vehicle Emissions Program.
    GoldenBrew likes this.
  17. Oct 22, 2020 at 6:23 PM
    #9777
    GoldenBrew
    Golden, Colorado
    wish we were so lucky. Pretty sure twin snails or SC if done right are just as efficient as na. Lots of vehicles that have them and meet emission requirements - so adding after market options should not be such a pain in the ass.
  18. Oct 23, 2020 at 5:18 AM
    #9778
    soggyBottom
  19. Oct 23, 2020 at 8:13 AM
    #9779
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    I agree. If they meet emission requirements, who cares what is added on there.
  20. Oct 23, 2020 at 8:43 AM
    #9780
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Moneyyyyyyy. Uncle Sam cares haha.
    GillyLink likes this.
Thread Status:
