OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Dec 20, 2020 at 7:41 PM
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    Hell yes. Turbski powa
    420taco and mZiggy like this.
  2. Dec 20, 2020 at 7:50 PM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Ugh. Want my snails done already! lol
    Looking forward to them along with the DT Y-pipe to open up that exhaust a little bit more.
  3. Dec 20, 2020 at 7:55 PM
    Bigetaco22
    Bigetaco22 Well-Known Member
    Kenny
    2016 DCSB TRD OR
    Bilstein 6112/5160s. OME leaf springs. 285/75/16. RC tonneau cover. Supernova v3 led lows, highs, and fog lights. Kicker speaker upgrade.
    Apparently my 3 inch catback made a world of difference.
    BoneTaco, TWTaco and mZiggy[QUOTED] like this.
  4. Dec 20, 2020 at 7:57 PM
    mZiggy
    mZiggy Honey badger
    Marc
    I'm sure it did.
    I'm keeping my TRD exhaust, the cat back. Went with catted downpipes on base turbos, and then the DT Y-pipe is catless w/ resonators. And I believe it's a little larger diameter than stock, can't remember. I'd have to double check
    Edit: 2.25" diameter. So nothing outrageous, but they'll open up flow. And with the resonators, it shouldn't sound like shit lol
    Bigetaco22[QUOTED] likes this.
  5. Dec 20, 2020 at 8:15 PM
    Speedwaytacotuesday
    Speedwaytacotuesday I love riding in my wife's Taco :p
    Calgary, Alberta
    2016 TACO LTD, 88 4runner, 4th Gen 4Runner
    TRD S/C 2.3" pulley mild ported Portmatched/cleaned intake runner Ucon EMS/cam gears/160 t-stat 840cc injectors 255 LPH walbro fuel pump Urd equal length headers Urd competition y-pipe AFE 3” Exhaust Vibrant resonator Oil Catch can Ratio-tek valvebody upgrade 3" bilstein/OME lift Dakar rear 7-leaf pack 32" KO2's load range C Stealth custom wheels Ray-10's Volk Te37X’s Tundra front 13.3” brakes Custom fab rock sliders LC-2 wideband autometer boost gauge Cravenspeed gauge pod mount Scangauge 2 SC MODS: Pulley ripp mod/belt wrap mod/ fleetrunner belt/ tensioner stop delete mod/ bypass jet delete mod
    Very happy to hear your truck is running good:thumbsup:
    I was going to hang on to my URD ypipe to install at a later date after putting some long miles on the turbos and then gauge if I can handle a loud truck again, but I think I’ll install it now so Mat can just dial it in the first time. @Bigetaco22 what turbos did you go with?
    fueling upgrades?
    Brostjoe likes this.
  6. Dec 20, 2020 at 8:20 PM
    Bigetaco22
    Kenny
    2016 DCSB TRD OR
    I am on base turbos. They do fade out above 4500 rpm but I'm ok with that because I literally never drive in that rpm range. I have DI upgrade just because I thought I may want to run more but realistically this is more than enough for my driving style. I may install my boost controller eventually but probably never use it.
  7. Dec 20, 2020 at 8:21 PM
    Speedwaytacotuesday
    Calgary, Alberta
    Overboosting due to the improved flow of the DT Y-pipe and larger diameter exhaust, fitted with the provided 7lb wastegate spring, and without fueling upgrades, @OVTune wouldn’t that put this setup at or beyond the threshold of fueling?
    mZiggy[QUOTED] likes this.
  8. Dec 20, 2020 at 8:26 PM
    mZiggy
    mZiggy Honey badger
    Marc
    I double checked for the record, the y-pipe is 2.25" diameter.
    I did tell @OVTune that I was having it installed along with the turbos and he sent me a map revision to compensate for when I first flash the truck. I'm optimistic that it'll be g2g after logging and I'm assuming a couple revisions
  9. Dec 20, 2020 at 8:27 PM
    Speedwaytacotuesday
    Calgary, Alberta
    Good to know, makes me think I should be more than happy with 10psi then, I’ll drop the 14lbs out of my head for now.
  10. Dec 20, 2020 at 8:28 PM
    Bigetaco22
    Kenny
    2016 DCSB TRD OR
    I am having overboost issues with my 3 inch and cold air. Seeing 10 psi spikes.
  11. Dec 20, 2020 at 8:29 PM
    mZiggy
    mZiggy Honey badger
    Marc
    Part of the reason why I went with base turbos as well
  12. Dec 20, 2020 at 8:29 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    We will know when we start doing some logs, but with those exhaust mods it's possible, but I think he will be ok.
    his Y pipe is 2.25 inch according to him, not far off from stock and he's still keeping the stock exhaust after that..so I don't foresee it being a big flow difference.
    However @Bigetaco22 has a 3 inch exhaust, which is way bigger than stock, and increasing his boost 2+psi over threshold.
    initial boost spikes are not very worrisome to me. say you "see" it hit 9-10 for a half second and taper down, that doesn't have me concerned.
    But if you see consistent 9-10+ to the limiter, that's when the low / in tank pump can be a real concern. Fueling over time, it simply can't handle it and you start seeing pressure loss.
    My truck is quite consistent with staying near 7psi. But that's on stock everything, stock super constrictive spaghetti noodle diameter exhaust.
  13. Dec 20, 2020 at 8:35 PM
    OVTune
    OVTune
    zero reason to get a boost controller. You can only use it to increase boost.
    For reference, @Bigetaco22 truck is hitting almost 300 g/sec on the MAF and he is in Colorado, where air density is less and air pressure is usually 2.5 to 2.8psi less than sea level. Usually sitting around 11.9psia.
    For the record his truck in Colorado is out-flowing my truck with powermax @7psi. and it's absolutely his exhaust doing it.
    This is why extra tuning is really necessary when you have mods like exhaust.
    ownubad, mZiggy, RedLantern and 4 others like this.
  14. Dec 20, 2020 at 9:03 PM
    rj_taco
    rj_taco Well-Known Member
    Do you think my exhaust will be a problem? Dual 2-1/2” with a dump valve halfway. Catted DP’s. Powermax, fuel pump and DI upgrade. Might be safer to run a 7 psi spring and use a boost controller?
  15. Dec 20, 2020 at 9:16 PM
    Speedwaytacotuesday
    Calgary, Alberta
    I thought I was high up being just above 4000ft, but when you consider Colorado, some parts could be nearly double that.
    @Bigetaco22, how has the snails affected your exhaust volume?
    I’m entertaining a full exhaust w/ double stacked vibrant ultra quiet resonators again. I knew I just can’t help myself and was just a matter of time.
  16. Dec 20, 2020 at 9:20 PM
    OVTune
    OVTune
    Shouldn't be a problem because you have in tank pump upgrade.
    I would advise anyone who wants to run more boost to always keep low psi springs in the waste gates. The 7psi ones. That way you can always reduce boost as needed.
    rj_taco[QUOTED] likes this.
  17. Dec 20, 2020 at 9:26 PM
    Bigetaco22
    Kenny
    2016 DCSB TRD OR
    So in my case I am running stock y-pipe with a 3 inch Mbrp cat back. I have noticed that this exhaust actually gets quieter at high rpms which is actually the case with the extra flow. It has a much smoother sound in boost and the turbo noises will definitely keep your ears off the exhaust. I also still have a vibration that my ears have been focused on along with engine noise looking for knock and such. Turbo noise will definitely keep your ears away from the exhaust though.
  18. Dec 21, 2020 at 6:10 AM
    Turd Hawg
    Turd Hawg Well-Known Member
    2018 DC SB OR AT (Sold)
    Can you log boost, or is that only seen on a gauge? If the latter, is there a non-invasive one I can pull off without patching holes or whatever after I'm retuned? I have no idea how they hook in....
  19. Dec 21, 2020 at 6:13 AM
    Bigetaco22
    Kenny
    2016 DCSB TRD OR
    You can probably get away with getting a cheap one from autozone that runs vacuum to the back of the gauge and using some double-sided tape for tuning purposes.
  20. Dec 21, 2020 at 6:20 AM
    mZiggy
    mZiggy Honey badger
    Marc
    For what it's worth, when telling Mat about my y-pipe I'd also informed him that I elected to not run a boost gauge and he said it was fine.
Thread Status:
