OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Jan 13, 2021 at 7:54 PM
    Speedwaytacotuesday
    Speedwaytacotuesday I love riding in my wife's Taco :p
    Calgary, Alberta
    2016 TACO LTD, 88 4runner, 4th Gen 4Runner
    TRD S/C 2.3" pulley mild ported Portmatched/cleaned intake runner Ucon EMS/cam gears/160 t-stat 840cc injectors 255 LPH walbro fuel pump Urd equal length headers Urd competition y-pipe AFE 3” Exhaust Vibrant resonator Oil Catch can Ratio-tek valvebody upgrade 3" bilstein/OME lift Dakar rear 7-leaf pack 32" KO2's load range C Stealth custom wheels Ray-10's Volk Te37X’s Tundra front 13.3” brakes Custom fab rock sliders LC-2 wideband autometer boost gauge Cravenspeed gauge pod mount Scangauge 2 SC MODS: Pulley ripp mod/belt wrap mod/ fleetrunner belt/ tensioner stop delete mod/ bypass jet delete mod
    I will be wrapping the driver’s side downpipe in two parts and leaving a few inches of the purpose-made dent exposed. The wrap is secured using stainless-steel ties, sorta like metal zip ties.
  2. Jan 13, 2021 at 8:29 PM
    Max713
    Max713 Well-Known Member
    Max
    Eugene, OR
    2017 MGM TRD OR
    Another thing to add to the list. I just got all my heat shielding, PCV rerouting, sealant, etc.
    What length steel ties are you thinking? Looks like I'll need a steel tie tool too, but those are super cheap.
  3. Jan 13, 2021 at 8:50 PM
    Turd Hawg
    Turd Hawg Well-Known Member
    2018 DC SB OR AT (Sold)
    2.5” downpipe is ~7.85” in circumference, plus the wrap. I got the 15” from ptp, it’s very easy to cut the extra. Didn’t use the tie tool, they’re just like a zip tie for the lost part. Mine haven’t* moved with just a tug.
  4. Jan 13, 2021 at 8:56 PM
    Max713
    Max
    Eugene, OR
    2017 MGM TRD OR
    Thanks for the insight
  5. Jan 14, 2021 at 5:50 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    It is possible to remove or install it through the bottom it's just not as easy unless you make room / loosen your Y pipe
  6. Jan 14, 2021 at 10:51 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    What's your tactic to reshape just enough but not too much.. fill it with sand and hit it with a BFH? heat it and beat it?
    Any gurus here that can offer some advice (or a video link) on the best approach to making these adjustments.
    Skydvrr likes this.
  7. Jan 14, 2021 at 10:56 AM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    probably find a buddy with a cheap press and apply pressure slowly and maybe with heat
    Gen3TacomaOBX[QUOTED] likes this.
  8. Jan 14, 2021 at 11:22 AM
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    on my 2nd gen turbo kit, I used a BFH to massage my crossover tube connecting to uppipe/passenger manifold since it was rubbing against the transmission pan. But the press sounds like a great idea.
  9. Jan 14, 2021 at 11:30 AM
    JamesT
    JamesT Well-Known Member
    2018 TRD Pro, MT
    Just make sure to support the pipe from the inside or you'll just compress the entire pipe section with the press. Sounds easier than it is.
  10. Jan 14, 2021 at 11:42 AM
    RedLantern
    Honolulu, Hi
    Yea that’s a good point. It could just smash flat lol. Hammering might be better
  11. Jan 14, 2021 at 12:42 PM
    Turd Hawg
    Hey OV....any warranty issues with taking it to a shop to get them to pie cut and shape the pipe for me?
  12. Jan 14, 2021 at 12:47 PM
    Gen3TacomaOBX
    S
    Without seeing the exact challenge.. I would think using a press brake or cutting/welding are both likely to change the angles of the downpipe's mating surfaces.
    JamesT likes this.
  13. Jan 14, 2021 at 12:49 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Make a jig. Bolt it in and start cutting
  14. Jan 14, 2021 at 1:15 PM
    rj_taco
    rj_taco Well-Known Member
    That’s my plan. Already bought a section of 2-1/4” 304 to do it.
    Edit: I’m in TN, if you can’t find anywhere reasonable to do this I wouldn’t mind helping out for parts/shipping cost.
  15. Jan 14, 2021 at 1:19 PM
    Turd Hawg
    Isn’t the downpipe 2.5”?
  16. Jan 14, 2021 at 1:31 PM
    OVTune
    OVTune
    I think you guys are way overthinking this. The section isn't that big and you shouldn't need a JIG or to cut it etc etc. It just seems that *a few* downpipes did not get the bend in that spot enough. That does not mean *all* downpipes have this problem.
  17. Jan 14, 2021 at 1:33 PM
    MESO
    State of Jefferson
    Are we talking about BENDING, or DENTING?
  18. Jan 14, 2021 at 1:35 PM
    OVTune
    OVTune
    Sorry not *bend* it's a dent. The pipe is squeezed at that section to clear. So it's not round, it's ovalish.
  19. Jan 14, 2021 at 1:45 PM
    rj_taco
    Based on my question to OV a while back, he said it’s 2-1/4”
  20. Jan 14, 2021 at 2:16 PM
    Turd Hawg
    2.25 or 2.5 OV?
Thread Status:
