OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Jan 19, 2021 at 1:48 PM
    Max713
    Max713 Well-Known Member
    Max
    Eugene, OR
    2017 MGM TRD OR
    This sounds promising!
  2. Jan 19, 2021 at 2:37 PM
    KnckleChldrn
    KnckleChldrn Well-Known Member
    Jamie
    Mass
    2017 Tacoma TRD Sport DCSB MT
    Suspension OME 886 Coils OME Nitro Charger Sport shocks OME Nitro Charger Sport struts Deaver Expedition leaf pack Mickey Thompson wheels 265/70/17 KO2 Total Chaos upper control arms Performance K&N air intake Exterior Southern Style Offroad slim line bumper Smittybilt x20 winch Interior Kicker tweeters, front and rear speakers Anytime front and rear camera Hondo Garage stereo knobs Hondo Garage un-Holley mount MESO black out door handles MESO steering wheel MGM overlay MESO puddle pods MESO ultimate red map lights MESO ultimate red dome MESO gasshole MESO ultimate turn signals MESO BD5 3rd brake light MESO stage 3 side markers Retrofit Morimoto 2.0 headlights RGB halo RGB demons RGB DRL Cali Raised raptor LED tail lights SpartanXCustoms scoop light Baja Designs Squadron Sports fogs (amber) Baja Designs Squadron Pro ditch (amber) Baja Designs S8 20" Matt Gecko bed lights Matt Gecko hood lights Switchpro 9100 OEM bed mat 300 Industries grill Bakflip Fibermax cover
    Let me know how it goes. If well maybe I’ll bring mine over there as well if I chicken out of doing it myself.
  3. Jan 20, 2021 at 1:38 AM
    naked farmer
    naked farmer Well-Known Member
    Nor Cal
    ‘17 B.Red Off Road
    Please share
  4. Jan 20, 2021 at 8:09 AM
    mangosmoothie
    mangosmoothie Well-Known Member
    Casey
    Northern AZ
    '22 Pro
    My summary so far is clock the turbo and get a hammer on the dp if needed.
    Torspd and Shellshock like this.
  5. Jan 20, 2021 at 8:21 AM
    Max713
    Max
    Eugene, OR
    2017 MGM TRD OR
    -Clocking turbos to clear shock towers
    -Trimming fuse box to clear driver side turbo
    -Intake pipe clearance around oil fill spout (drivers side turbo)
    -PCV tube reroute (into catch can, or reroute into intake tube)
    -Increase size of dent in drivers side downpipe to clear steering shaft
    -Oil sensor tap possibly the wrong fitting, common spot for leakage
  6. Jan 20, 2021 at 9:01 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Pretty sure that oil sensor tap is BSPT on the Toyota side. Just a hunch, as I am not sure the specifics which you lead to.
  7. Jan 20, 2021 at 9:26 AM
    therealprotaco
    therealprotaco Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock Tundra TRD PRO DC
    Any word on the progress? No dog in this fight, just following along.
    BlkTaco47 and Skydvrr like this.
  8. Jan 20, 2021 at 9:37 AM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Playing along for now. They really are close and explained to me one of the bigger issues they're working around which was the y-pipe connecting the two turbos couldn't reach around the battery properly, requiring the reshaping and welding.
    So they're actually close to being done so I'm giving it the week for now, will see what happens I guess
  9. Jan 20, 2021 at 9:39 AM
    therealprotaco
    Gilbert, AZ
    Is there anything unique about your battery setup?
  10. Jan 20, 2021 at 9:45 AM
    mZiggy
    mZiggy Honey badger
    Marc
    Only that it's an Odyssey 34R-790 AGM. It fits perfectly fine in the OEM battery tray, although I do think it's larger than the OEM battery. Maybe it's just big enough that the pipe piece can't clear it properly as a result, idk. Honestly wasn't an issue I'd considered or foreseen.
  11. Jan 20, 2021 at 9:53 AM
    therealprotaco
    Gilbert, AZ
    I guess that makes sense if its slightly larger. Honestly I'd rather have a shop that wants to cut and weld than bash it with a hammer (which is really a non-issue based on Engine Masters header bashing tests). At least they sound like they really want this thing to be perfect when its returned to you.
    BlkTaco47 likes this.
  12. Jan 20, 2021 at 10:49 AM
    seelyartacus
    seelyartacus Well-Known Member
    San Diego
    '16 TRD Sport 4x4, grey, tech&tow pkg
    FNWheels six shooter matte bronze, Falken WildPeak M/T 295/70/r17, All-Pro Expedition leafs, Fox Factory 2.5 w/ res (front/rear), Icon billet UCA w/ sphericals, custom sliders, 4.56 re-gear, RCI bed rack , Tepui RTT, Prinsu Designs Cabrac, CBI T3 alum front bumper, CBI T3 rear bumper with dual swing away and tire carrier, 20in light bar, Warn VR10s winch, Factor 55 fairlead, flatlink, and hitch recovery point, All-pro alum skid, Rotopax, CMC, Timbren bump stops, rear Rigid Duallys, Rigid Dually ditch lights, ARB awning with LED lights, Currie F9 rear axle housing w/ Strange Engineering 3rd memb and ARB air locker., rear diff beather relocation, ARB compressor under hood, Bussman panel, 3d printed switch panel,OVTune ECU
    -Clocking turbos to clear shock towers (there is success with clocking, I ended fabricating new mounts for the actuator, nothing too difficult and cutting back the fender)
    -Trimming fuse box to clear driver side turbo (I stood both the air box and fuse box on 1" standoffs. No trimming necessary after that)
    -Intake pipe clearance around oil fill spout (drivers side turbo) (I snapped the filler neck off and it is indeed threaded to receive the stock oil cap afterwards)
    -PCV tube reroute (into catch can, or reroute into intake tube) (Haven't tackled this yet, but I do have a catch can to deal with)
    -Increase size of dent in drivers side downpipe to clear steering shaft (I had to increase the dent. It was really easy, ifff you have a press)
    -Oil sensor tap possibly the wrong fitting, common spot for leakage (can't comment here, because I haven't finished)
    I'll comment above in (). I did a lot of custom work and I'm not yet done, but there are considerations those installing should think about. I have solid engine mounts - may have changed position of the engine leading to a lot the "custom" work. I have dual batteries on the driver's side which def added to custom work. I have C3 bumper with winch = custom work on IC and routing air. you get my point.
    SC4333 likes this.
  13. Jan 20, 2021 at 2:28 PM
    Jrgymie
    Jrgymie Tuf MuddR
    Jeff
    Glastonbury, CT
    18 DCSB CEMENT TRD SPORT 4x4
    Since we were one of the first kits delivered, there were some missing parts (nothing expensive but identified once the kit was getting assembled). Some of the later kits may be complete.
    - FIPG maker for oil pan sealer;
    - Various FMIC pipes and varying silicone elbows (mostly b/c Meso, Hawg and myself used a different FMIC so all intercooler piping wasn't included which we were told);
    - more heat shielding per Meso's rec's: Adhesive heat reflective sleeves makes wrapping wires easier, Adhesive thermal barrier for various areas, turbo blankets and exhaust wrap;
    - Air box 1/2" rubber shims and longer bolts which elevates air filter box which lessens amount of trimming to fit passenger turbo; - another member mentioned 1" shims to lift the driverside fuse box which helps reduce the amount of cutting to fuse box;
    - HPS 2" offset coupler and clamps on driver turbo outlets to clear oil filler extension (another solution was identified by Meso who noted that the oil filler neck can be twisted off since its glued on. The OEM oil cap then screws directly on the engine block after oil filler extension is removed);
    - the 3/8" coolant hose that runs from the drivers to passenger side turbo was about a foot short in at least one kit;
    - Heavier duty hose clamps to replace clamps used on fuel pump and doubled with hose clamps on preassembled 6" hose to J-bend for added redundancy against leaks;
    - Meso, myself and Hawg purchased 3/4" HPS high temp silicone hose for the turbo oil return line into oil pan which replaced supplied heater hose. Probably overkill but didn't want to deal with potential leaks down the road.
    - 4mm (5/32”) vacuum hose and clamps for the boost taps;
    - small piece of evap hose, 2 couplers and hose clamps since OEM evap hose became too short after shoving it up against the firewall to make room for turbo and DP;
    - Spark plugs: ngk lfr7aix #2309 iridium 0.028 gap >> if 10+psi you need to gap them to below 0.028, but not below 0.025 (please double check with OV regarding recommended gap especially if running increased boost);
    - there was reported leaking issues with the supplied oil pressure sensor fitting that the turbo oil supply lines attach to. The fitting has NPT instead of BSPT. I believe that the OEM oil sensor is BSPT so I bought another fitting (1/8" male BSPT, 1/8" female BSPT, and 1/8" female NPT) which can be found on eBay for $8. I know Meso and Bigetaco ended up using the supplied fitting to make it work so either fitting will probably work with some teflon tape. I bought the extra one to have options since it was $8.
    - as others have said, should purchase oil catch can system with TT kit. Lots of posts on TW about different systems
    Many have noted difficulty fitting the turbos and/or wastegate actuator arm. Clocking the turbos and slightly shifting the exhaust manifold before tightening can provide extra wiggle room. Varying degree of trimming to the shock tower or wheel well was reported but don't know how much or if it could be prevented with some trouble shooting with OV.
    Torque specs:
    exhaust manifold to engine - 27ft/lbs
    Downpipe to turbos - 33ft/lbs
    Downpipe to Y pipe - 33ft/lbs
  14. Jan 20, 2021 at 2:32 PM
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    Might of been easier to remake or modify the battery mount, but who knows. Hope they don't keep dicking you around.
    Shellshock likes this.
  15. Jan 20, 2021 at 3:37 PM
    Jrgymie
    Jrgymie Tuf MuddR
    Jeff
    Glastonbury, CT
    It's been there 2 days and the owner called me to discuss the install. He brought up a lot of the same issues already reviewed on the thread. Nothing that they couldn't handle but wanted to know how to proceed. Because I have a different FMIC requiring custom piping I gave them the liberty to fabricate a system according to their recommendations, limiting the amount of silicone couplers and maximizing custom aluminum piping.
    Currently no other projects in the shop so both guys working on the TT kit for the next couple days. Going to stop by tomorrow at the request of the owner so everybody is on the same page and no surprises. Probably going to have them install a shackled ladder bar that's been sitting on my garage floor for a year now. Guessing the extra torque is going to cause some axle wrap.
  16. Jan 20, 2021 at 3:43 PM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    Thank you for this, I screenshot this and put it in an OVTUNE folder I have on my desktop!
  17. Jan 20, 2021 at 4:09 PM
    OpelGT
    OpelGT hOPELess Power
    Texas
    2018 TRD OR Tacoma MT, Magnuson Supercharged
    Yes you will have pretty good axle wrap. My supercharged taco hops like hell (or falls on its face) unless you launch it perfectly.
  18. Jan 20, 2021 at 5:23 PM
    KnckleChldrn
    Jamie
    Mass
    Sounds promising. Let me know what they get for an install. Good luck!
  19. Jan 20, 2021 at 7:38 PM
    skyking3
    skyking3 Well-Known Member
    Tom
    2016 Silver Tacoma SR5 DCSB
    TRD cai, TRD cat back, JFR y pipe,Wilwood BBK,LEDs, Limited Homelink mirror,debadged,WeatherTechs,Dynamat Extreme sound deadening,sabm second snorkle to fender, Huper Optik ceramic tint, TRD Sema wheels, aerodynamic under body pan, OEM Audio Plus 500Q reference system, Depo faux pro headlights, real pro fog lights, OV tune, OEM aluminum filter housing, Mobtown IFS skid,TRD oil cap,TRD radiator cap, Osram Night Breaker 150 halogen headlamps, Fumoto valve,dashboard blackout,OEM tailgate power lock, MESO steering wheel logo, MESO two color dome light, TRD Pro coilovers, Artec LCA skids, Volk TE37 XT forged wheels, Roadmaster Active Suspension Garmin Minicam, Garmin minicam II
    Have you considered the Roadmaster Active Suspension system? It will not only reduce axle wrap and wheel hop but also body roll and greatly improve towing. The price is reasonable and the installation is simple. Check out the link below.
    https://activesuspension.com/products/kits/2005-2016-tacoma-pickup/
    It will actually work for any Tacoma to 2021. I am not sure about the Pro.
  20. Jan 20, 2021 at 7:39 PM
    seelyartacus
    San Diego
    spot on to what i have done and same issue with some small missing parts, but expected as we were a couple of the first. Haven't created my IC plumbing solution yet but optimistic there. did the same on oil return as well.
    oil pressure tee. i haven't tackled yet but i did just find this on Amazon Amazon.com: EPMAN 1/8'' BSPT Oil Pressure Sensor Tee to 1/8'' NPT Adapter Turbo Supply Feed Line Gauge: Automotive
    3rd_gen_trd_taco and Torspd like this.
Thread Status:
