OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Feb 27, 2021 at 5:40 AM
    tater taco
    tater taco no it all
    Todd
    ground zero of the zombie apocalypse
    2016 ACLB TRD OR Quicksand OV Tuned 2.0 (91)
    OVTuned, decatted dump tubes
    thank you, is the very high HP more than the "big twin turbo" option you have now?
  2. Feb 27, 2021 at 5:40 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    No, it's the same kit on higher boost. 25psi to be exact.
  3. Feb 27, 2021 at 5:43 AM
    tater taco
    Todd
    Oh Dear Lord...
    :burnrubber:
  4. Feb 27, 2021 at 5:54 AM
    Pinchaser
    Pinchaser Flipper Crazy
    Alan
    2020 Tacoma ECU 04B82 AT
    Great! OVTune, Thanks for the update, great that you share such detail. Having to warm it up is no biggie.
    One thing seems wierd to me; if i am following correct, boost sensing will now be measured at the pumps, but it makes sense to me that this is only real, if measured near the throttle body? I assume this somehow controlls the wastegate, so taps so close would certainly reduce actual boost at the engine.
    I guess the bottom line is simply defined by performance gains over stock. Looking forward to some dyno comparisons, but seems each should identify where they tapped, along with the data.
    Thank you again OVTune, really neet get such detail, feels like we are all part (tiny) of a design team! Determined to add boost!
  5. Feb 27, 2021 at 6:32 AM
    OVTune
    OVTune
    The boost taps / boost port to control wastegate opening would be right on the turbo cold side. This means as soon as the cold side has achieved the amount of pressure required, the wastegate opens.
    During our testing, when we used a boost reference from the manifold (which means the pressure travels all the way from the turbo cold side, through the piping / intercooler, through the intake manifold then to the waste) it would overboost.
    The reason is by the time pressure has reached the wastegate, the turbochargers are spinning much faster than needed for 7psi and it overboosts.
    by putting the boost reference location at the turbo, the wastegates are in fully control the very moment the turbocharger has achieved the pressure, regardless of what is at the manifold. The engine will still see the same amount of pressure without spiking.
    The reason for this change is because boost pressure reference location is *critical* to making sure there are no overboosts.
    Torspd likes this.
  6. Feb 27, 2021 at 8:49 AM
    3rd_gen_trd_taco
    3rd_gen_trd_taco Active Member
    Dan
    @OVTune if you want to send me a picture of the boost tap location on the compressor housing I can tap mine there to get some results when we do the logging on my truck.
  7. Feb 27, 2021 at 8:54 AM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Going out on a limb here but I think the taps are going here. There is a flat spot in the casting that is designed for this.
    H3llRid3r and whitedlite like this.
  8. Feb 27, 2021 at 9:02 AM
    ttruong
    ttruong Active Member
    2009 trd offroad
    3 inch lift with king 2.5 coil overs, 2.0 rear king 12 inch shocks, bamf shock mounts, all pro expo rear leaf pack, Trd supercharger
    Yes depending on application that is where the nipple for boost tap will usually go.
  9. Feb 27, 2021 at 10:57 AM
    seelyartacus
    seelyartacus Well-Known Member
    San Diego
    '16 TRD Sport 4x4, grey, tech&tow pkg
    FNWheels six shooter matte bronze, Falken WildPeak M/T 295/70/r17, All-Pro Expedition leafs, Fox Factory 2.5 w/ res (front/rear), Icon billet UCA w/ sphericals, custom sliders, 4.56 re-gear, RCI bed rack , Tepui RTT, Prinsu Designs Cabrac, CBI T3 alum front bumper, CBI T3 rear bumper with dual swing away and tire carrier, 20in light bar, Warn VR10s winch, Factor 55 fairlead, flatlink, and hitch recovery point, All-pro alum skid, Rotopax, CMC, Timbren bump stops, rear Rigid Duallys, Rigid Dually ditch lights, ARB awning with LED lights, Currie F9 rear axle housing w/ Strange Engineering 3rd memb and ARB air locker., rear diff beather relocation, ARB compressor under hood, Bussman panel, 3d printed switch panel,OVTune ECU
    alright since i promised here is my install. it's not pretty yet but function first and I'll clean it up later. it definitely was a long project with holidays, illness, a few hiccups, but after doing it once it would obviously go much quicker. no leaks to speak of at first shot. here are pics and vids. currently, too much silicone and a lot will be replaced with hard pipes. i haven't gone much over 25% throttle but it drives lightyears better than it did, even weighted down. for context, I'm heavily armored, bed cab, 35s, 4.56 gears.
    I am aware that my engine is filthy, but this truck gets the crap kicked out of it and it's not meant to be pretty.
    videos of first start up. not edited and true to form the first start....charge pipe hitting the fan. second video it purrs.
    https://vimeo.com/517579532
    https://vimeo.com/517579556
  10. Feb 27, 2021 at 11:42 AM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Love it. Nice! Start datalogging and get the tuning going!
  11. Feb 27, 2021 at 11:57 AM
    MESO
    State of Jefferson
    Awesome! Shop looks nice too:)
    GillyLink likes this.
  12. Feb 27, 2021 at 12:07 PM
    tater taco
    Todd
    is this an old pic, different turbo or haven't you sold your kit yet?
  13. Feb 27, 2021 at 12:11 PM
    seelyartacus
    San Diego
    thanks! generally our work is a bit more surgical then the brute force tactics used on the truck. with the truck, if it's in the way, chop it out. haha
    MESO[QUOTED] likes this.
  14. Feb 27, 2021 at 12:29 PM
    MESO
    State of Jefferson
    Old pic
    tater taco[QUOTED] likes this.
  15. Feb 27, 2021 at 1:47 PM
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Nice! Thanks for posting. I got scared for you when I watched that first video and was like WTH!!! Glad it was minor. Excited for you bro
  16. Feb 27, 2021 at 4:13 PM
    naked farmer
    naked farmer Well-Known Member
    Nor Cal
    ‘17 B.Red Off Road
    Is that the intercooler that comes with the kit?
  17. Feb 27, 2021 at 4:26 PM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    no
  18. Feb 27, 2021 at 5:37 PM
    seelyartacus
    San Diego
    no i fall into the custom category. no ic, no cat downpipes. modified quite a bit to account for the early engine mods.
    Torspd and ownubad like this.
  19. Mar 1, 2021 at 3:20 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Very nice! Good welds too!
  20. Mar 2, 2021 at 6:33 AM
    OVTune
    OVTune
    Posting this here because I think you're not seeing the image I sent?
    What is making sure that THIS route (in blue) is not a huge vacuum leak?
    Torspd likes this.
Thread Status:
