OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Mar 11, 2021 at 4:18 AM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
  2. Mar 11, 2021 at 5:35 AM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    You guys need to speak to Mods on getting a post possibly pushed to the 2nd post to where all parts and build advice is accumulated and can be edited by someone active on the turbos.
  3. Mar 11, 2021 at 6:25 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
  4. Mar 11, 2021 at 4:41 PM
    Turd Hawg
    Turd Hawg Well-Known Member
    2018 DC SB OR AT (Sold)
    Tube coming off the front of the intake, in between the intake and that solenoid or whatever it is.
    H3llRid3r and Gen3TacomaOBX like this.
  5. Mar 13, 2021 at 2:32 PM
    Turd Hawg
    When are the new pump controllers shipping to older TT pump controller owners?
    mZiggy likes this.
  6. Mar 13, 2021 at 4:44 PM
    BlkdOuT
    BlkdOuT Well-Known Member
    2017 Tacoma trd sport 4x4 MT TT
    Im still sitting here jealous of your old pump controller
  7. Mar 13, 2021 at 4:44 PM
    mZiggy
    mZiggy Honey badger
    Marc
    So there's a dude in Colorado who installed a procharger on his 3GT, has 33's, and dyno'd 341rwhp/303 torque running 7.5psi. I believe he went with a bit smaller pulley due to elevation.
    Also, I told him about how the stock pump struggles with high load demand over a long period of time, just a word of warning for him for if/when he's high up in the rpm band, and he said this:
    "So this kit was provided with a JMS fuel booster, wires inline and ups the voltage to like 15-16. Apparently this is done a lot in other application with no troubles at all, and so far stands true"
    @OVTune thoughts?
    Is this something that could be worth having for people like myself with the base kit who are running out of fueling on the top end and get those misfires when the stock pump has had enough?
    As it stands, it's really hard to recommend this kit without the fuel pump upgrade, because frankly it sucks knowing that above a certain rpm, there's this vague stretch of rpm between there and redline where you can misfire and go into a limp mode. Yes, I understand that the ecu shuts down those cylinders to prevent damage, and all that needs to be done is cycle power and you're g2g again, but knowing that doesn't make it any less of a concern really. And I'm aware that the base turbos have pretty much tapered off before reaching that rpm threshold, so the driver wouldn't have much reason to not have upshifted by then, but still, for peace of mind..... :notsure:
  8. Mar 13, 2021 at 5:06 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    since he is in colorado it's likely a 20% correction factor. Take it to sea level he will probably run out of fuel.
    I would not use a fuel pump boost on our pumps. They do not work like normal pumps work. Not only that but upping the voltage the ECU is just going to try to trim the duty on the pump it will be fighting itself. I wouldn't be surprised if the pump burns out.
    for trucks in your case where they are getting more than base boost due to mods, I have a method to keep it safe which I'll be putting into your tune. It's the only way, which is cutting down maximum throttle up top. (so that maybe above 5000 rpm when you floor it you only get 50% throttle). You won't get the full horsepower up top, but you'll still get *more than enough* and be within the limits of the fuel system.
    seelyartacus, ownubad, Torspd and 2 others like this.
  9. Mar 13, 2021 at 5:23 PM
    mZiggy
    mZiggy Honey badger
    Marc
    Thank you Mat.
    ownubad likes this.
  10. Mar 14, 2021 at 5:48 PM
    ownubad
    ownubad Well-Known Member
    Cory
    2017 Silver Sky OR
    Drop in AFE Pro Dry Filter Inchannel Vent Visors Bedlinered Rear bumper and plastic flares
    I knew that voltage shit was a little too good to be true lol. Shit haha good on yah for asking. I was sure curious about that response too!
  11. Mar 14, 2021 at 5:55 PM
    mZiggy
    mZiggy Honey badger
    Marc
    Yeah when he mentioned it I was like wow, that sounds incredible, this is perfect and exactly what the rest of us need lol
    ownubad[QUOTED] likes this.
  12. Mar 14, 2021 at 6:03 PM
    OVTune
    OVTune
    Read how our fuel pump works you'll understand voltage boosters aren't really going to help like they would on a standard pump.
    Our pumps flow is not controlled by voltage it is controlled by PWM of 3 different voltages
    ownubad, tonered and Torspd like this.
  13. Mar 15, 2021 at 1:38 PM
    o313
    o313 Well-Known Member
    N
    2018 DCLB AT SC
    Ive been following the TT and SC threads for awhile but I haven't seen much on the fuel pump controllers you have made, can you give us any details on When/If they'll be available and what the cost is looking like?
  14. Mar 17, 2021 at 10:15 AM
    seelyartacus
    seelyartacus Well-Known Member
    San Diego
    '16 TRD Sport 4x4, grey, tech&tow pkg
    FNWheels six shooter matte bronze, Falken WildPeak M/T 295/70/r17, All-Pro Expedition leafs, Fox Factory 2.5 w/ res (front/rear), Icon billet UCA w/ sphericals, custom sliders, 4.56 re-gear, RCI bed rack , Tepui RTT, Prinsu Designs Cabrac, CBI T3 alum front bumper, CBI T3 rear bumper with dual swing away and tire carrier, 20in light bar, Warn VR10s winch, Factor 55 fairlead, flatlink, and hitch recovery point, All-pro alum skid, Rotopax, CMC, Timbren bump stops, rear Rigid Duallys, Rigid Dually ditch lights, ARB awning with LED lights, Currie F9 rear axle housing w/ Strange Engineering 3rd memb and ARB air locker., rear diff beather relocation, ARB compressor under hood, Bussman panel, 3d printed switch panel,OVTune ECU
    quick update. Truck is driving great. After fixing vacuum leaks and second tune file, I'm not throwing any codes. Boost gauge will go in this week to understand exactly what it's doing and I'll flash an additional tune file and log full throttle pulls. it's fun as hell to drive! After all that is dialed, I'll start replacing some of the silicone couplers with hard line.
    H3llRid3r, offroadnTaco, MESO and 2 others like this.
  15. Mar 17, 2021 at 10:49 AM
    TheTacoChrist
    TheTacoChrist Well-Known Member
    Dick
    2018 TRD PRO Taco
    Lettuce removed Ghost pepper sauce added Subbed: Tortured baby cow for tofu.
    Any new updates on shipping more kits, @OVTune ?
    it’s getting hot in Texas again. Garage is looking less friendly to my hydration of choice.
    H3llRid3r, tater taco and BlkdOuT like this.
  16. Mar 17, 2021 at 12:02 PM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    I know you are building your own fuel pump module but have you looked at the offerings from Torqbyte? We have used/installed a few on higher horsepower VW/Audi's with very good success.
  17. Mar 18, 2021 at 7:42 PM
    OVTune
    OVTune
    Update
    Fuel Pump/ controller:
    New fuel pump is in our truck, tested. It is working exceptionally well. Our firmware had to be modified quite a bit, and we are wrapping up finishing touches. Which is nice as our truck is back on the road so we can finish any necessary fine tuning tests for a few of you guys.
    All of our fuel pump controllers are disassembled, with our new boards installed, nearly ready to be firmware loaded and shipped out.
    Tuning: Base tunes right from the start are 90% ready to go. A few back and forth logs will be required. We are still working on adjustments for very cold start/driving. (cold start is a little choppy, as with cold engine driving).
    Kits /Shipping: Behind schedule (obviously). This weekend I plan to detail out the changes that we have made, with some pictures (as it is setup on our truck now). I posted here a while back that I was moving my location where I do some of the work, and that has been a contributing factor. I thank you guys for being patient with me. It has definitely been quite a process getting to this point. Expectations right now for resuming of shipping I'm working towards pushing more kits out beginning of April. This is *way* behind our initial release plans, I understand that. If you are unhappy with this, please talk to me, we will get something worked out.
    There is also 2 pieces for the intake we decided we would cast. It's not ready yet, though. These pieces fit much better, and are designed from a 3D scan of the engine bay, including a piece that bends to avoid the oil filler neck.
    You will still get the original design pieces, so that there aren't further delays. When those cast pieces come, we will send you those to swap it *if you want.*. It also will make it easier to add sections for PCV, oil catch can ports, etc.
  18. Mar 19, 2021 at 2:43 AM
    808army
    808army Well-Known Member
    hawaii
    17 offroad
    With that being said what question on guys have you supercharger setups are we going get finish kit as few us missing thing here and there?
  19. Mar 19, 2021 at 7:57 AM
    Jimmyturbo
    Jimmyturbo Well-Known Member
    Jimmy
    2017 Tacoma trd off road
    Icon stage 8 long travel suspension
    That is all great news!!
    GillyLink likes this.
  20. Mar 19, 2021 at 9:07 AM
    naked farmer
    naked farmer Well-Known Member
    Nor Cal
    ‘17 B.Red Off Road
    Mo’ videos plz
Thread Status:
