OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Apr 15, 2021 at 5:42 AM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    You can use your vF flasher software to read codes. And clear them.
    05Taco4x4 likes this.
  2. Apr 15, 2021 at 6:05 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Why not an Ultragauge?
  3. Apr 15, 2021 at 6:17 AM
    Turd Hawg
    Turd Hawg Well-Known Member
    2018 DC SB OR AT (Sold)
    My read dtc is grayed out, I can only clear them.
  4. Apr 15, 2021 at 7:15 AM
    pinochle
    pinochle GC8 Fanatic
    NNJ
    2018 TRDOR DCSB 4x4 6MT
    NFab Nerf Steps, Bakflip MX4, Profile 5500K HIDs, Kicker Tweeters, Toyota Bed Mat, XPEL Ultimate Paint Protection, Borla S-Type Catback Exhaust, ME-SO Customs Gasshole, ME-SO Customs Total Tails Stage 1, ME-SO Customs Ultimate LED Turn Signals V4, HELLA Supertones, OVTuned 2.0, 2LO Mod, 16x8 0mm Enkei RPT1 Wheels in Titanium Gold, Diode Dynamics SS3 Pro Foglights, K&N Cabin Air Filter, HPS Intake Hose, Amsoil Gear Lubes in 6MT, front and rear differentials, XPEL Prime XR Plus Tint, TRD Engine Air Filter, Pioneer Head Unit, 275/75R16 Falken Wildpeak A/T3W Tires, RallyArmor UR Flaps
    Evap, small leak.
    Dumb question, is your gas cap on straight and tight? Is there a nick on the gas cap seal?
  5. Apr 15, 2021 at 10:06 AM
    Turd Hawg
    Not a dumb question, thanks for the thought. Gas cap looks ok. So I just towed an empty trailer up, and hauled it back at 4k pounds back for about 60 miles. No codes.
    I think my issue was self inflicted. I assumed since there was no clamp on the hose on the front of the intake, that I didn't need to clamp the T for my boost gauge. A smidge of dialectric grease on the barbs and some hose clamps got rid of that 'very small' evap leak, at least so far. Sure felt nice driving without the dash lit up.
  6. Apr 15, 2021 at 11:05 AM
    Mike O
    Mike O Well-Known Member
    2016 TRD OR MGM Access Premium LB
    Mobtown Sliders, SSO Slimline bumper, Baja Amber lightbar & fogs, Sumo bump stops
    So......how did you find the towing experience with 4k as compared w/o the FI?
  7. Apr 15, 2021 at 1:59 PM
    Turd Hawg
    Way better towing performance. OV is right, it holds gears and powers through vs downshifting and screaming. Being able to accelerate up a hill in 6th, pulling 3 or 4 psi, with 4K pounds behind me feels pretty good. I’ll still run s5 in the future as I always have when towing, but 6th can do it now.
    It’s a different truck, without messing with trac this or lsd that, full throttle first gear spins my 33s around 3500 rpm. I do have 5.29s though, so your mileage may vary.
    Speaking of mileage, I averaged 11 in 60ish miles, 1500 lbs one way, 4K the other.
  8. Apr 15, 2021 at 7:32 PM
    Mike O
    Thank you...
  9. Apr 16, 2021 at 9:03 AM
    Turd Hawg
    Popped codes again today...60 miles towing and nothing, a trip to 7-11....codes.
    Got TechStream working as well so I can read codes again. On Techstream when reading codes there are 'Enhanced' and 'Generic'.
    With CEL and trac off on the dash...
    Enhanced...
    P010064 'Mass or Volume Air Flow Sensor "A" Signal Plausibility Failure
    P012500 'Insufficient Coolant Temperature for Closed Loop Fuel Control'
    Generic...
    P0101 'Mass or Volume Air Flow Sensor "A" Circuit Range/Performance
    P0125 'Insufficient Coolant Temperature for Closed Loop Fuel Control'
    P0420 'Catalyst System Efficiency below Threshold Bank 1'
    P0430 'Catalyst System Efficiency below Threshold Bank 2'
    P0456 "Evaporative Emission Leak Detected (very small leak)'
    After clearing codes using VFT, and no CEL on dash
    Enhanced...
    None
    Generic...
    Looks like, according to Techstream, my very small leak is ok....and when I say ok I mean it's not throwing a CEL, I'm cool with that for sure, as I am with all the 'Generic' codes that aren't lighting up my dash.
    Hope this info helps you OV. Again, I'll wait until the new tune hits and go from there.
  10. Apr 16, 2021 at 11:12 AM
    seelyartacus
    seelyartacus Well-Known Member
    San Diego
    '16 TRD Sport 4x4, grey, tech&tow pkg
    FNWheels six shooter matte bronze, Falken WildPeak M/T 295/70/r17, All-Pro Expedition leafs, Fox Factory 2.5 w/ res (front/rear), Icon billet UCA w/ sphericals, custom sliders, 4.56 re-gear, RCI bed rack , Tepui RTT, Prinsu Designs Cabrac, CBI T3 alum front bumper, CBI T3 rear bumper with dual swing away and tire carrier, 20in light bar, Warn VR10s winch, Factor 55 fairlead, flatlink, and hitch recovery point, All-pro alum skid, Rotopax, CMC, Timbren bump stops, rear Rigid Duallys, Rigid Dually ditch lights, ARB awning with LED lights, Currie F9 rear axle housing w/ Strange Engineering 3rd memb and ARB air locker., rear diff beather relocation, ARB compressor under hood, Bussman panel, 3d printed switch panel,OVTune ECU
    I threw those same last 4 generic codes before tidying things up and then getting a new tune from Mat.
  11. Apr 17, 2021 at 7:57 AM
    TheTacoChrist
    TheTacoChrist Well-Known Member
    Dick
    2018 TRD PRO Taco
    Lettuce removed Ghost pepper sauce added Subbed: Tortured baby cow for tofu.
    @OVTune I transferred my reservation to @Pinchaser and he is paid in full. I sent a couple messages through zendesk, but wanted to give an official heads up here too.
    I know you’ve got a lot of wheels in motion right now, but wanted to make sure I used every possible method to notify you to ship the kit to him.
    I’m reluctantly joining the Ford family this summer. I’ll miss you guys. Best forum ever. I’ll still visit. Promise.
    ihatemytruck and o313 like this.
  12. Apr 17, 2021 at 8:20 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Already responded to your email that I got notification of this
    TheTacoChrist[QUOTED] and o313 like this.
  13. Apr 17, 2021 at 12:43 PM
    TheTacoChrist
    Dick
    2018 TRD PRO Taco
  14. Apr 17, 2021 at 1:25 PM
    KnckleChldrn
    KnckleChldrn Well-Known Member
    Jamie
    Mass
    2017 Tacoma TRD Sport DCSB MT
    Suspension OME 886 Coils OME Nitro Charger Sport shocks OME Nitro Charger Sport struts Deaver Expedition leaf pack Mickey Thompson wheels 265/70/17 KO2 Total Chaos upper control arms Performance K&N air intake Exterior Southern Style Offroad slim line bumper Smittybilt x20 winch Interior Kicker tweeters, front and rear speakers Anytime front and rear camera Hondo Garage stereo knobs Hondo Garage un-Holley mount MESO black out door handles MESO steering wheel MGM overlay MESO puddle pods MESO ultimate red map lights MESO ultimate red dome MESO gasshole MESO ultimate turn signals MESO BD5 3rd brake light MESO stage 3 side markers Retrofit Morimoto 2.0 headlights RGB halo RGB demons RGB DRL Cali Raised raptor LED tail lights SpartanXCustoms scoop light Baja Designs Squadron Sports fogs (amber) Baja Designs Squadron Pro ditch (amber) Baja Designs S8 20" Matt Gecko bed lights Matt Gecko hood lights Switchpro 9100 OEM bed mat 300 Industries grill Bakflip Fibermax cover
    @OVTune im sent a couple pm’s regarding that tatrix cable that was going to be in 3 weeks ago and would be shipped to me. Any update?
  15. Apr 17, 2021 at 2:11 PM
    Jrgymie
    Jrgymie Tuf MuddR
    Jeff
    Glastonbury, CT
    18 DCSB CEMENT TRD SPORT 4x4
    @OVTune
    I really need an updated tune since I continue to have hesitation/sputtering with repetitive exhaust backfires/ lots of black soot (but not the infamous white smoke) out the tailpipe. This only happens whenever I throttle hard (more than 40%), especially punching the accelerator suddenly at low RPM's like when trying to pass another car at cruising speed. No issues at start up, during idle, cruising or when I'm light on the throttle during acceleration.
    If I try to accelerate easing on the throttle less than 25% the turbos spool and power/acceleration is smooth and progressive. Psi stays around 7-8 but sometimes peaks to 9-10 psi for a second or two with prolonged acceleration. I never run the truck hard until oil temp is above 150 F
    Since I'm only on tune version #2, I'm hopeful this will be remedied with updated tunes. Emailed you the data logs (ticket 22272) a couple times several weeks ago.
  16. Apr 17, 2021 at 2:58 PM
    Turd Hawg
    So strange how different these truck are. I have no issues with acceleration, but have cold start and idle issues in the first 20 seconds, as well as a shitty ride until the motor is at operating temp.
    I get a dark cloud of smoke first gear full throttle if I don’t do it for a while, if I do it twice in a row there’s no smoke on the second full throttle pull. Almost like there’s buildup that needs burned off or something once in a while. I have black soot too on the tailpipe and a spot in the driveway where I warm it up.
  17. Apr 17, 2021 at 3:38 PM
    OVTune
    OVTune
    I am sending out the new tune files to all you guys tomorrow, working on them tonight. Im also shipping the FPCs with the fuel pressure wiring Monday. Had to wait forever on the damn loom part.
    ownubad, BoneTaco, Torspd and 2 others like this.
  18. Apr 19, 2021 at 6:44 AM
    mZiggy
    mZiggy Honey badger
    Marc
    So as usual shipping companies continue to cock things up.
    Mat did UPS next day air on my replacement wastegate. Was supposed to arrive on Friday, it arrived in El Paso that day but is only now on the truck for delivery.
    My boost controller was supposed to arrive on Saturday, instead it went to Kansas and is now in Illinois. Shipped from Bloomington, CA via FedEx. Ugh.
    Honestly I just want to stop overboosting so much that if the WG gets delivered before I'm out of work today, I may skip the boost controller and just see if the shop can swap the WG today, continue to go off of spring pressure. Maybe throw the controller in there at a later date. We shall see...
    ownubad likes this.
  19. Apr 19, 2021 at 7:41 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Shipping has been very strange this year. All over the place, out of the way.
    mZiggy likes this.
  20. Apr 19, 2021 at 5:12 PM
    Turd Hawg
    I didn’t get that new tune, can I get on the list please?
    seelyartacus and Max713 like this.
Thread Status:
