OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Apr 27, 2021 at 5:48 PM
    Turd Hawg
    Turd Hawg Well-Known Member
    2018 DC SB OR AT (Sold)
    I hear shit too…was it there before? Who knows, but I hear shit now too.
    Lately I’m stuck on hearing shit when I go by a Jersey wall and sounds are bouncing back at me.
    When should we realistically expect that new tune? I’m excited for it, been checking my email since last Sunday.
  2. Apr 27, 2021 at 6:07 PM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Went for a drive, took a datalog but realistically I guess I shouldn't bother sending it.
    Popped the hood again and started trying to tighten as many bolts as I could around the turbo/mani, and none were loose, but I also can't reach everything.
    There's a definite exhaust leak type sound (loud, as if you had an open dump) coming from the area. Ugh. I don't fucking know.
  3. Apr 27, 2021 at 6:25 PM
    420taco
    420taco Well-Known Member
    Justin
    PA
    Pressurize the exhaust and listen/soap
    Skydvrr likes this.
  4. Apr 27, 2021 at 6:54 PM
    mZiggy
    mZiggy Honey badger
    Marc
    how tf does something like that even happen way up there after swapping the fucking y-pipe
    ugh
  5. Apr 27, 2021 at 6:55 PM
    mZiggy
    mZiggy Honey badger
    Marc
  6. Apr 27, 2021 at 7:27 PM
    rj_taco
    rj_taco Well-Known Member
    Let it heat cycle a few times and keep checking the DP to YP flange, not much surface area for a good seal. 304 stainless expands quite a bit when hot. Worst case, replace the flange connections with V bands.
    mZiggy[QUOTED] likes this.
  7. Apr 27, 2021 at 7:45 PM
    mZiggy
    mZiggy Honey badger
    Marc
    You're saying that it's possible that basically just driving it has the chance to correct it? Let the metal heat and expand and possibly fix itself? Fuck it, may as well try. Thanks.
    Think it'd be a PITA to source the v-bands if necessary?
  8. Apr 28, 2021 at 3:11 AM
    mZiggy
    mZiggy Honey badger
    Marc
    0400 in the morning, drove this bitch to the gym and it sounded like a damn turbo diesel lol
    MGMSangTaco and Shellshock like this.
  9. Apr 28, 2021 at 4:30 AM
    mZiggy
    mZiggy Honey badger
    Marc
    Question. Wild thought, maybe I'm retarded.
    Is it possible that because I went from just 6psi on the OEM y-pipe to only 7 when I reinstalled the aftermarket one, that actuator arm tension is too loose perhaps, idk, and the turbo is out-spinning/outflowing the air that should be going through the exhaust now that it's free flowing again? Like the turbo isn't pushing enough air now? Idk, I'm just spitballing ideas here.
    The sound is like the turbo spool combined with some sort of exhaust sound coming from right around the turbo area though. It's not as loud and angry as if the pipe was just dumping into open air like when someone cut out and stole the cats off our 4runner. But similar, if a tad more tame. I have back pressure. Although idk if I have enough back pressure or not. Truck still accelerates well, although maybe not quite as quick in 5th and 6th when starting at 2k rpm or so now...idk
  10. Apr 28, 2021 at 5:22 AM
    rj_taco
    Yes and no. I found mine to be leaking by 2 times, after the 3rd torque down it quit (when cool).
    No, just make sure it’s 304 stainless. The EVIL branded one on Amazon is a decent one (2-1/4”). Finding a shop to tig weld them on might be a challenge depending on where you’re at.
  11. Apr 28, 2021 at 6:37 AM
    mZiggy
    mZiggy Honey badger
    Marc
    I'm assuming I'd need to do the same up top with these if I go down that route. I could swear the sound is coming from up higher, well above the DP-YP connection.
  12. Apr 28, 2021 at 7:06 AM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    You do not want any backpressure in a turbo system. the turbo itself creates enough backpressure.
  13. Apr 28, 2021 at 7:32 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Check that the donut gasket is sealed well with the Y Pipe. I am not sure about the URD Y Pipe but with the OEM one there is a male / female pipe / flange it fits inside and when the donut gasket is crushed in place there is zero gap between the two flanges
    Torspd likes this.
  14. Apr 28, 2021 at 7:44 AM
    twoL84prey
    twoL84prey Member
    Krystian
    2018 White Tacoma 6 speed manual
    Lower light bar, led projector fog lights, tailgate letters decal
    For how long do you guys think the turbo kit will be for sale?
  15. Apr 28, 2021 at 7:46 AM
    OVTune
    OVTune
    It's not available right now, and we are working on some details with a shop to help us provide the kit quicker
  16. Apr 28, 2021 at 7:55 AM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    until there's no more demand.
    Shellshock and Torspd like this.
  17. Apr 28, 2021 at 8:06 AM
    rj_taco
    Do you have enough FPC’s to ship all remaining kits out or will you ship a few at a time?
  18. Apr 28, 2021 at 8:14 AM
    mZiggy
    mZiggy Honey badger
    Marc
    I'll do that but I'm not even sure that's the issue. I don't hear the sound coming from that point. Even if I cold start it and walk over to the passenger side and listen through the wheel well or pop the hood to listen, it's definitely sounding like it's in the vicinity of the turbo/mani area.
  19. Apr 28, 2021 at 8:23 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Can you see any soot around any exhaust flanges?
  20. Apr 28, 2021 at 8:31 AM
    Mace27
    Mace27 Well-Known Member
    18 TRD OR
    So, just a thought. But since you have seemingly taken care of all the exhaust leaks, is it possible you are now able to hear the internal bypass/blowoff on the turbo?
Thread Status:
