OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. Apr 28, 2021 at 9:45 AM
    seelyartacus
    seelyartacus Well-Known Member
    San Diego
    '16 TRD Sport 4x4, grey, tech&tow pkg
    FNWheels six shooter matte bronze, Falken WildPeak M/T 295/70/r17, All-Pro Expedition leafs, Fox Factory 2.5 w/ res (front/rear), Icon billet UCA w/ sphericals, custom sliders, 4.56 re-gear, RCI bed rack , Tepui RTT, Prinsu Designs Cabrac, CBI T3 alum front bumper, CBI T3 rear bumper with dual swing away and tire carrier, 20in light bar, Warn VR10s winch, Factor 55 fairlead, flatlink, and hitch recovery point, All-pro alum skid, Rotopax, CMC, Timbren bump stops, rear Rigid Duallys, Rigid Dually ditch lights, ARB awning with LED lights, Currie F9 rear axle housing w/ Strange Engineering 3rd memb and ARB air locker., rear diff beather relocation, ARB compressor under hood, Bussman panel, 3d printed switch panel,OVTune ECU
    this might sound silly and apologize in advance. when i was reinstalling the y-pipe to down pipe, i was pretty exhausted and overlooked that the old gasket was still stuck in there and was trying to install the new gasket on top of it and it created the gap that you might be seeing.
  2. Apr 28, 2021 at 9:49 AM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    No offense taken. I am sure this isn't the case however, I made sure to fit in the gasket.
    I'd actually wondered if the gasket had slipped out of the groove or wasn't the proper size, tried one of the larger ones I had lying around and it was definitely too large, refitted the proper size...properly. Lol the gasket is also definitely getting sandwiched in there, the outside material sticking to the DP in the recessed space, even if the YP is loosened enough to slide away a bit.
  3. Apr 28, 2021 at 10:07 AM
    Shellshock
    Iowa
    I spend my days in zoom. Every day hurts lol
    CanadaToy, Skydvrr and tonered like this.
  4. Apr 28, 2021 at 10:11 AM
    seelyartacus
    San Diego
    figured as much. it's little things that trip me up. for comparison, mine is pretty quiet at idle
  5. Apr 28, 2021 at 10:15 AM
    mZiggy
    mZiggy Honey badger
    Marc
    Mine was quiet at idle before this issue too
  6. Apr 28, 2021 at 10:18 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Drill and through-bolt. Is that not an option?
  7. Apr 28, 2021 at 10:31 AM
    twoL84prey
    twoL84prey Member
    Krystian
    2018 White Tacoma 6 speed manual
    Lower light bar, led projector fog lights, tailgate letters decal
    Thank you
  8. Apr 28, 2021 at 10:40 AM
    mZiggy
    mZiggy Honey badger
    Marc
    It is.
  9. Apr 28, 2021 at 10:45 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Just getchu a Cobalt bit lol.
  10. Apr 28, 2021 at 11:15 AM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    Let the truck idle, and get a buddy to hold a bunch of old rags / towels over the exhaust pipe (alot, as it will get hot quick) while you get underneath the truck to listen for any leaks. You will hear them immediately if there are any.
    H3llRid3r and Torspd like this.
  11. Apr 28, 2021 at 11:23 AM
    Speedwaytacotuesday
    Speedwaytacotuesday I love riding in my wife's Taco :p
    Calgary, Alberta
    2016 TACO LTD, 88 4runner, 4th Gen 4Runner
    TRD S/C 2.3" pulley mild ported Portmatched/cleaned intake runner Ucon EMS/cam gears/160 t-stat 840cc injectors 255 LPH walbro fuel pump Urd equal length headers Urd competition y-pipe AFE 3” Exhaust Vibrant resonator Oil Catch can Ratio-tek valvebody upgrade 3" bilstein/OME lift Dakar rear 7-leaf pack 32" KO2's load range C Stealth custom wheels Ray-10's Volk Te37X’s Tundra front 13.3” brakes Custom fab rock sliders LC-2 wideband autometer boost gauge Cravenspeed gauge pod mount Scangauge 2 SC MODS: Pulley ripp mod/belt wrap mod/ fleetrunner belt/ tensioner stop delete mod/ bypass jet delete mod
    Yes ^ this works. Best method I found tho is to stick a shop vac hose (put to blow not suck) up the tailpipe and use rags or tape it shut then use a spray bottle with dish soap and spray the suspected areas, this is how I’ve solved many exhaust flange leaks.
    I also found that if those flanges are NOT seated correctly it will just destroy the gasket and bend the ears as you tighten down. You can tighten them until your arms fall off but you will still have a leak.
    CO_Taco125, Skydvrr, Torspd and 2 others like this.
  12. Apr 28, 2021 at 12:09 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I have done this before in the past. Had to straighten out the flanges.
  13. Apr 28, 2021 at 12:17 PM
    Speedwaytacotuesday
    Calgary, Alberta
    Myself a few times too unfortunately. Now I like to, mate up the flanges correctly, use vise-grips to squeeze/hold them in place then proceed to bolt up and tighten.
  14. Apr 28, 2021 at 3:34 PM
    mZiggy
    mZiggy Honey badger
    Marc
    Also on today's episode of shit I didn't expect, I left work and started my truck and discovered that my CEL for the o2 sensors had cleared itself lol I guess those spacers with mini cats work after all
    pinochle and RedLantern like this.
  15. Apr 28, 2021 at 3:37 PM
    Shellshock
    Iowa
    :rofl:
  16. Apr 28, 2021 at 3:39 PM
    mZiggy
    mZiggy Honey badger
    Marc
    It's like I continuously trade one problem for another lmao
  17. Apr 28, 2021 at 4:04 PM
    Shellshock
    Iowa
    That’s what happens when you mess with the honey badger lol
  18. Apr 29, 2021 at 5:05 AM
    Kronan49
    Kronan49 Well-Known Member
    Ronan
    2020 Tacoma Trd Pro 6M
    I really hope this kit stays available for a good couple years once it's available to everyone so I can get my hands on it when I can afford it.
    Also @OVTune has anyone been testing the kit on a manual tacoma? Wondering how the clutch and transmission is holding up to the added power and what it's limits would be since my truck is a manual.
  19. Apr 29, 2021 at 5:35 AM
    mZiggy
    mZiggy Honey badger
    Marc
    @Jrgymie and I have MTs with the kit. I can't speak for him but I have the base kit with no fueling upgrades and I haven't had any slippage. Yet. Lol. :notsure:
    3k miles on the kit, plenty of heavy/full throttle driving.
    Skydvrr and Kronan49[QUOTED] like this.
  20. Apr 29, 2021 at 5:39 AM
    Kronan49
    Ronan
    Thats awesome man not gonna I'm quite jealous, but nonetheless glad your enjoying the kit and that so far your not having any issues with clutch or Trans. How's the power feel with the manual and any vids of pulls? be awesome to see
Thread Status:
