OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. May 1, 2021 at 1:50 PM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    The bolt wasn't sitting there just snapped and loose, rattling around, but it certainly broke rather easily. Enough that I do suspect that it was over-torqued and the stress of the socket wrench for removal was all it needed to snap.
    I'm talking with the other shop that helped me out with my actuator arm and that had discovered that it was too short and had been cobbled together.
    ownubad, Torspd and tonered like this.
  2. May 1, 2021 at 2:34 PM
    Jrgymie
    Jrgymie Tuf MuddR
    Jeff
    Glastonbury, CT
    18 DCSB CEMENT TRD SPORT 4x4
    Clutch is slipping only under hard acceleration at highway speeds. Haven't noticed it otherwise since I can't throttle more than 40% without creating repetitive backfires out the exhaust. It's like I have a souped up tuner where I can create a firework show on demand except my tuner isn't really "tuned"; in fact it hasn't been properly tuned since my original pump controller fried 2 brand new fuel pumps over two months ago. Still stuck on map#2 since mid February. Hopefully my engine doesn't blow like MESO's
    TWTaco and mZiggy[QUOTED] like this.
  3. May 1, 2021 at 4:51 PM
    Turd Hawg
    Turd Hawg Well-Known Member
    2018 DC SB OR AT (Sold)
    You’re talking cold running? I can’t go into boost either until fully warmed up. I wouldn’t call mine a backfire though, I think it misfires, there’s a putter feel.
  4. May 1, 2021 at 5:10 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Like a fish bite?
  5. May 1, 2021 at 5:12 PM
    Turd Hawg
    Rapid succession of boost-blowoff-boost-blowoff….a bucking feeling
  6. May 1, 2021 at 5:15 PM
    mZiggy
    mZiggy Honey badger
    Marc
    Mine did a version of this when I was overboosting. A subtle version though, the bucking was barely there and really only felt in my pedal, not the whole truck
  7. May 1, 2021 at 5:15 PM
    mZiggy
    mZiggy Honey badger
    Marc
    It was a psh psh psh as the wastegates would try to purge the excess.
  8. May 1, 2021 at 5:22 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Compressor surge?
  9. May 1, 2021 at 5:26 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    it is caused from the pressure differential between each side of the throttle blade when the engine is cold,
    vacuum boost vacuum boost vacuum boost vacuum boost. It is related to the throttle control w/ cold engine
    MZiggy your issue was compounded because you had only 1 of the turbos overboosting. So one turbo was spinning slower and bleeding pressure.
    One method I have found that I can implement that fixes it is modifying cold engine torque so that you simply can't get into boost until it's warmed up. You can floor it and only get about 20% throttle until the engine is warm.
    tonered likes this.
  10. May 1, 2021 at 6:24 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Negative. I'm in Virginia just a couple hours north of you. Order #6583. I am happy to PM or email my address or any other info that you may need.
    It's unfortunate that you can't pull in admin resources to help with the communication and emails since your time programming, tuning and designing is very valuable.
    Turd Hawg likes this.
  11. May 1, 2021 at 7:04 PM
    OVTune
    OVTune
    I've got it from your order number thanks.
    Yes logistics has been a big problem recently. Admin/email/comm has been a struggle. There are some plans in motion once all of these pending things are sorted out. I can assure everyone everything is smoothing out and will get back to normal timelines soon.
    something I don't talk about but has been a set back these last few months is that I was recently diagnosed with Menieres disease, presumably from my time in the military. It has caused an impact on my ability to work, as of right now.
    auskip07 likes this.
  12. May 1, 2021 at 7:52 PM
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    Sorry if this comes across as harsh, maybe it’s tough love, but Mat, you gotta get some helpers. Even if it’s just the BS of resetting passwords and answering emails about how vF works and what people need to buy for their specific needs, writing product manuals, packing and shipping, etc... (edit @tonered might already do part of this on TW but you need someone full time).
    I can’t speak for others but I know there are now many of us dependent on you to make Toyota’s suck significantly less. From the outside looking in it appears you are extremely talented but can’t play nice with others, which is often related to the talented part. Others can’t live up to your standards.
    We are all pulling for you to succeed, but how can you manage this solo or with the limited crew you have, which from the outside looks like 1 (you)? Customer service is critical, if it weren’t for your monopoly on ability to access most recent Toyota ECU’s, people would be reaching for another product.
    I mean this in the best possible way, please find someone to help manage the trivial stuff so you can focus on the differentiating technology you develop that ensures your future success. It appears to be the little stuff distracting you from the big fish. Again, outside looking in and guessing here. We want you and vF to succeed.
    Thanks,
    Captain Obvious (waiting on a Zendesk for what I assume is a trivial task)
  13. May 1, 2021 at 8:01 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
  14. May 1, 2021 at 8:22 PM
    OVTune
    OVTune
    I completely agree with your statement. Ive come to a similar realization already.
    To be clear I have hired a tech writer, and developer.
    However my dev is in the hospital from liver disease caused secondary from Covid.
    Believe me some things are in motion already.
    First, some stuff is just getting cut out, product / development wise. May make some people unhappy. Don't care, they will troll no matter what.
    Second, there will be a big change coming to how development is done. We will be working directly with one of our pro tuner shops. Can't get into too much details on that right now though.
  15. May 1, 2021 at 8:45 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Trolls are beneficial, just gotta reframe the way you think about em. It's direct feedback.
  16. May 1, 2021 at 9:55 PM
    BortisYeltzen
    Barrett
    Salt Lake City, UT
    Best of luck. My mom has battled Menieres for decades. It’s a bad situation when the world is spinning around you and you can’t do anything.
    Again, the vast majority of us are all fans of your work, we use it daily, weekly, etc... we’re hooked, now you have to feed us or we get hangry...
    Feed me!
  17. May 2, 2021 at 12:22 AM
    92ehatch
    92ehatch Well-Known Member
    Kinley
    Hendersonville NC
    2019 Cavalry Blue DC TRD OR 6MT
    I'm not diagnosed officially with anything.
    But after googling that disease i may ask my doctor about it. Is there a test for it? The last time i asked about it, i was told i needed to eat more salt.
    Basically i get crazy dizzy spells, can be walking along then all the sudden I'm drunk as hell and can barely walk, ears ring constantly. Set me in my chair at work for 2 hours last Thursday.
    Been happening since i was in high school.
    If that's what you are dealing with, i know the feeling and it sucks when you are trying to work or drive
  18. May 2, 2021 at 2:34 AM
    nickyreno
    nickyreno Member
    100%. If you want to promote something - Boycott it.
  19. May 2, 2021 at 6:16 AM
    Gen3TacomaOBX
    S
    That's exactly what I was afraid of. I've moved since the order (communicated multiple times) I'll send another ZenDesk.
  20. May 2, 2021 at 6:27 AM
    Jrgymie
    Jrgymie Tuf MuddR
    Jeff
    Glastonbury, CT
    @OVTune I assume I will be getting a new FPC since I have been using your prototype new FPC since February? I mailed you the old FPC and ruined fuel pumps 5 weeks ago.
    Any idea why I can't throttle more than 40% without getting hesitation with multiple backfires out the exhaust? If I push it hard the truck has gone into limp mode on two occasions so I have been driving the truck very cautiously.
    I desperately need an updated tune since I'm concerned my current tune is going to cause permanent damage.
    Not trying to be a dick but my emails with data logs have not been replied to or addressed in over a month. I acknowledge that there are many complexities to getting everyone's TT kit running smooth but some of us have been very patient waiting for these updates to materialize over the last 2 months.
Thread Status:
