OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. May 18, 2021 at 4:18 PM
    Turd Hawg
    Turd Hawg Well-Known Member
    2018 DC SB OR AT (Sold)
    I didn’t see a TT thread over there
    Gen3TacomaOBX likes this.
  2. May 18, 2021 at 4:32 PM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Thanks for the tip, oops.
    Potentially problematic. Maybe we have to make one
  3. May 18, 2021 at 4:33 PM
    mZiggy
    mZiggy Honey badger
    Marc
    Well, idk I want to make a TT thread because then Mat can't update it.
  4. May 18, 2021 at 4:47 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    I'll wait-n-see. OVTune just posted in here yesterday and didn't mention anything about TT discussions migrating.
    Happy to see general vF Tuner discussions moving out of the forced induction specific thread.
  5. May 18, 2021 at 6:40 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    All VF Tuner / Software / tuning / development / etc will be migrating to our forum. It's just becoming impossible to keep up with trying to remember everything on multiple forums.
    This thread won't be migrating
  6. May 19, 2021 at 6:43 PM
    mZiggy
    mZiggy Honey badger
    Marc
    Question for the group at large, especially anyone with boost controller familiarity.
    Ever since the boost controller went in, when I floor it in 2nd and 3rd, the turbos howl like a demon from the underworld. Controller is set to 8psi from the shop that most recently worked on my truck, although like this morning at 60-deg ambient temp I was hitting 9 in 3-4gear and then when it's super hot, like 90 out, I'll hit like 6-8, depending on gear. 2-6, lower psi as gears get higher.
    I don't for a second believe it's the kind of howl you get from turbo failure. Turbos have only been onboard for 3200mi, wouldn't make sense.
    But now when at WOT, or near it, you hear this insanely loud rushing howl and I was wondering if this is basically a result of my turbos and y-pipe wanting to flow all of the air under the sun and the boost controller being like hold up, nah bro.
    Correct me if I'm not understanding what's happening there please. Just trying to find a reason for the madness.
    Pulls strong. I'll be sending Mat a datalog or two when I get the updated tune because I still think some of the powerband could use some smoothing.
  7. May 19, 2021 at 6:57 PM
    OVTune
    OVTune
    Can you video it?
    does it feel laggier than usual?
    It only happened after the boost controller install? nothing else was touched?
  8. May 19, 2021 at 7:03 PM
    mZiggy
    mZiggy Honey badger
    Marc
    Boost controller went in at the same time as the bolt repair.
    Not sure if it's laggier...hard to say because I really hadn't gone WOT much after blowing through all those map revisions with you. So it's been a bit and I can't remember 100%... definitely wasn't this loud before the controller though. When my overboosting issue was fixed but the controller wasn't in yet, I don't think it did this but I could be wrong...
    I'll try to video it. Hopefully it comes out on video.
  9. May 19, 2021 at 7:04 PM
    OVTune
    OVTune
    Does the sound only really happen in boost?
    if so, 99% the gasket is leaking only under high exhaust pressure. Was that gasket replaced where the bolt was?
  10. May 19, 2021 at 7:27 PM
    mZiggy
    mZiggy Honey badger
    Marc
    Just did some pulls, took a vid, uploading to YouTube now and will link when it's done.
    Yes, only happens in boost, only happens at WOT/near WOT i think, and I just discovered that it appears to also not happen until 4k rpm or greater, which is rare for me anyway...
    Yes, gasket was replaced where the bolt was damaged/repaired/replaced. Gasket had been fucked, new one got put in by the shop.
  11. May 19, 2021 at 7:28 PM
    mZiggy
    mZiggy Honey badger
    Marc
    It's also hard to say if it's laggier. Could be. It's still smooth and strong, but perhaps a little laggier? Idk, hard to tell. Gets you moving super fast in a hurry regardless lol
  12. May 19, 2021 at 7:33 PM
    mZiggy
    mZiggy Honey badger
    Marc
    https://youtu.be/Q2MgHHhJ8jI
    You can pretty much ignore the first pull if you'd like, since I'm not sure if it caught it very well with my windows down. Can jump forward to 0:50 or so if you want.
  13. May 19, 2021 at 7:35 PM
    mZiggy
    mZiggy Honey badger
    Marc
    Video doesn't make it seem as loud as it is. Or it's fine and I'm just hyper-analyzing every little thing since I've had things to fix lately.
  14. May 19, 2021 at 7:37 PM
    OVTune
    OVTune
    That sounds exactly like a boost leak. Like when a clamp isn't tight enough to hold boost but not loose enough to pop off.
    Dirk Diggler and mZiggy like this.
  15. May 19, 2021 at 7:39 PM
    mZiggy
    mZiggy Honey badger
    Marc
    Really. Lol
    @OVTune I swear to fucking god that's probably one of the most relieving things you could have said to me lmfao after the frustrations I've had lately, I get told it's just a boost leak hahahahaha
    And apparently I'm going crazy lol
  16. May 19, 2021 at 7:41 PM
    Shellshock
    Iowa
    Definitely heard it at the very end.
    edit: must be a Texas thing lol
  17. May 19, 2021 at 7:41 PM
    mZiggy
    mZiggy Honey badger
    Marc
    Lol
  18. May 19, 2021 at 7:42 PM
    mZiggy
    mZiggy Honey badger
    Marc
    Apparently need to rename the Honey badger to Banshee. But I don't want to piss off the HB lol
    Shellshock[QUOTED] likes this.
  19. May 19, 2021 at 7:44 PM
    Shellshock
    Iowa
    It definitely sounds pissed off lol
    mZiggy[QUOTED] likes this.
  20. May 19, 2021 at 7:45 PM
    mZiggy
    mZiggy Honey badger
    Marc
    WHYTHEFUCKAMIGETTINGALLTHISDAMNAIRSHOVEDDOWNMYTHROAT lol
Thread Status:
