OVTune 3.5L Tacoma Supercharger and Twin Turbo Systems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Sep 2, 2018.
Thread Status:
Not open for further replies.
  1. May 23, 2021 at 6:11 AM
    Pinchaser
    Pinchaser Flipper Crazy
    Alan
    2020 Tacoma ECU 04B82 AT
    All clamps are not created equal. Oetiker makes great clamps, they tend to be narrower and more clamping power, though have a narrower diameter adjustment range. I do not have a kit yet, so cannot advise to size, but can suggest AircraftSpruce.com for good pricing and service oriented supplier. This clamp is the best I have found, but even for common screw clamps, at this vendor you find the higher quality ones. Oetiker also has other styles.
    Torspd and mZiggy like this.
  2. May 23, 2021 at 7:31 AM
    Pinchaser
    Alan
    Another clamp that i like is the Norma TORRO, these are embossed worm drive. I like that these are narrow with beveled edges, for more clamping pressure. Was not sure where to get these (previously only seen as OEM parts), but came right up at BelMetric.com I have no experience with this seller.
  3. May 23, 2021 at 9:46 AM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    @OVTune
    Replaced the gasket, everything's sealed up. No longer hearing helicopter rotors with my ears nor with my stetho contraption. Sounds smooth, identical to driver side. Has been idling well.
    Took an idle log and I'm about to take a drive log, will do a couple pulls too, would really appreciate it if you have any spare time to review and confirm that I'm g2g and ready for the map update.
  4. May 23, 2021 at 9:50 AM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Awesome. I'll check the logs this evening as I'm away from my desk
    ownubad and mZiggy[QUOTED] like this.
  5. May 23, 2021 at 9:53 AM
    Shellshock
    Iowa
    :burnrubber:
    MOC221_ and mZiggy[QUOTED] like this.
  6. May 23, 2021 at 9:57 AM
    mZiggy
    mZiggy Honey badger
    Marc
    Thanks. Logs sent just now.
    Pulls were way smoother and stronger now than with the leak, I guess I hadn't realized how much of a difference it made.
    MOC221_, Shellshock and Dirk Diggler like this.
  7. May 23, 2021 at 9:59 AM
    mZiggy
    mZiggy Honey badger
    Marc
    Oh yeah :thumbsup:
    Putting miles on it just driving aimlessly around the city to try to see if it'll pop any codes or not, although I don't expect it too. Mainly I guess to see if my o2 sensor code returns, which means I'll need to look again at that downpipe connection since I have had the cel for weeks now
  8. May 23, 2021 at 11:45 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That leak prevented accurate AFR readings on that bank. Which then turns into the system trying to compensate as best it can. Causing poorer performance.
    mZiggy[QUOTED] likes this.
  9. May 23, 2021 at 11:51 AM
    mZiggy
    mZiggy Honey badger
    Marc
    Well I appreciate the suggestions given here by everyone, helped a lot
    Torspd and MOC221_ like this.
  10. May 23, 2021 at 11:54 AM
    Shellshock
    Iowa
    Finally time for that donut video! ;)
  11. May 23, 2021 at 11:56 AM
    mZiggy
    mZiggy Honey badger
    Marc
    Lol never.
    Don't care about them.
    Honestly I haven't even launched my truck with the turbos once because one, I haven't cared to, and two, idk if my clutch would chuck dueces lol
  12. May 23, 2021 at 12:49 PM
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Yup this is true! This is also true with boost leaks.
    mZiggy and Torspd[QUOTED] like this.
  13. May 23, 2021 at 6:59 PM
    Turd Hawg
    Turd Hawg Well-Known Member
    2018 DC SB OR AT (Sold)
    Any updates on the new tune?
  14. May 24, 2021 at 5:11 PM
    mZiggy
    mZiggy Honey badger
    Marc
    Oil change in progress. Oil was black. I'm currently roughly 3300mi or so on the turbos. Probably should change the oil every 3k from here on out then?
  15. May 24, 2021 at 5:12 PM
    mZiggy
    mZiggy Honey badger
    Marc
    Bump, any updates on new tune?
  16. May 24, 2021 at 5:30 PM
    OVTune
    OVTune
    color doesn't mean much. 5k miles if synthetic is fine
    new tunes will be distributed this week.
  17. May 24, 2021 at 5:31 PM
    Turd Hawg
  18. May 24, 2021 at 5:40 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    You should send a sample out. Curious what the results would be. About 30$
  19. May 24, 2021 at 5:49 PM
    Turd Hawg
    Blackstone. I do it for my outboards all the time, never have my truck though. I would but I wouldn’t have a baseline.
    Skydvrr likes this.
  20. May 24, 2021 at 5:49 PM
    OVTune
    OVTune
    Sending a sample out on the very first oil from the kit being installed would yield a flawed result. There is very likely to be excess of many things due to all the new components installed. Just like when you check on a brand new engine there is excess metal
    ownubad, Torspd and Skydvrr[QUOTED] like this.
Thread Status:
