OVTune Tacoma 3.5L Auto - Transmission / Engine - ECU Reflash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OVTune, Oct 15, 2017.
  1. Jun 13, 2018 at 5:36 AM
    #1161
    Taco16LB
    Taco16LB Well-Known Member
    Is this for real ? I have never heard of such a thing.
    Edit - did the document say what would happen if you did alter it and did you get a copy ?
    xxTacocaTxx likes this.
  2. Jun 13, 2018 at 6:28 AM
    #1162
    Mike O
    Mike O Well-Known Member
    2016 TRD OR MGM Access Premium LB
    Mobtown Sliders, SSO Slimline bumper, Baja Amber lightbar & fogs, Sumo bump stops
    Of course many states test vehicles for emissions as a part of licensing a vehicle for on-road use. I imagine the clause is there so that in the event they have to repo the vehicle, it is license-able/street legal. The result is that not only can they repo your vehicle if need be, but that they can sue you to get the vehicle back in license-able and therefore sell-able condition.
    bshammer0 likes this.
  3. Jun 13, 2018 at 6:55 AM
    #1163
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Well, my OVTuned truck passed emissions tailpipe tests with flying colors so I wouldn't be worried about it! In the Alpha thread Mat even announced that he has gotten it to pass all OEM emissions standards.
    Doesn't surprise me.. the nasty exhaust I used to have stock is what i'd consider a normal exhaust now
    ToyoDrew likes this.
  4. Jun 13, 2018 at 7:48 AM
    #1164
    ratcityrain
    ratcityrain Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    Curiosity question. So currently my driving style is ect on and I use S mode. I live mostly in 4th when on highways and city streets. I will go into 5th if I am cruising, but here in WA we have so many dumb drivers and traffic that I'm barely ever cruising ha ha.
    Will this tune more or less eliminate me having to drive in 4th all the time to stay in the higher rpm's and can drive in drive mode? Is ect really even necessary after tune?
    Just trying to compare your driving styles with the tunes to my current driving style
  5. Jun 13, 2018 at 7:34 PM
    #1165
    treimche
    treimche Well-Known Member
    Fargo, ND
    No. Even running 1.04 you'll be up in 5th gear at 35 mph. If you like to drive in the RPM range with usable power, you'll still want to use S4.
  6. Jun 13, 2018 at 10:21 PM
    #1166
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Did you lease it or something?
  7. Jun 14, 2018 at 4:07 AM
    #1167
    necrodiety
    necrodiety Well-Known Member
    Orlando
    2018 Silver TRD Sport
    OV Tune, Bakflip F1, Redline hood struts, faux pro headlights and tails, Meso: bucket, map and dome lights, fuse cover.
    No, it was purchased. This is in FL. Not sure if it's FL thing but we don't have any emissions testing here. That's why I thought it was weird.
  8. Jun 14, 2018 at 6:42 AM
    #1168
    Reganou812
    Reganou812 Member
    Ford F150
    I have tried the 1.04/87 and the 1.04/91 tune. Both are much better than stock.
    I am hearing good things about the 1.03 tune.
    How do I get the 1.03 file?
    When I got my tune the download manager wasn't working and Matt had to email me the 1.04 file.
    Just made a trip from Salt Lake City to Las Vegas. I used S5 to prevent the constant shifting from 6 to 5. On occasion it would downshift into 4th.
    The downshift was rather harsh and then I would be in 4th gear at 75 miles an hour and 3400 RPM!!!
    I don't think there's anything that can be done with the tune to fix this. I believe it's a gear ratio issue between 5th and 4th.
    Cruising at 75 mph in 5th gear and 2100 RPM there's just not enough power at that RPM to maintain speed.
    I am seriously considering a tundra at this point.
    treimche and PNWTacoma like this.
  9. Jun 14, 2018 at 7:49 PM
    #1169
    PNWTacoma
    PNWTacoma Well-Known Member
    Paul
    PDX 3rd party OV Tuner
    2025 TRD Pro | Mudbath // 2017 Offroad DCLB OG
    PNW Adventures & PNW Tuning
    Same question: how do I get 1.03? I installed 1.04 91 and don't like how the linear pull falls flat from 4-5th gear. Emailed OP a few times without response...
    EDIT: Received my file a few days shortly after.
  10. Jun 18, 2018 at 12:24 PM
    #1170
    MarcoTaco
    MarcoTaco Active Member
    Mark
    East Tennessee
    2017 TRD Sport Taco 4x4 Acc Cab A/T V6
    Hellwig rear leaf, BFG 265/70 KO2 tires, Method rims, Bilstein 5100 frt struts, ECU tune
    June 18 - re-flash
    OK everyone - The deed is done. I received my files today from Mathew. So I just re-flashed my ECU with OVT's 1.04 for 91 octane. I don't have even 10 miles on it yet, so my comments will be short. I let it idle a while and went for a test drive using both normal and ECT modes.
    The difference between the stock OEM tune and the Orange Virus tune is basically like getting a new truck. It is now quicker, smoother, faster, and it feels confident when you drive that auto transmission KNOWS what gear to be in - and gets there instantly, during up or downshifting.
    The engine's exhaust note and "growl" when accelerating even sound nicer. And when you touch, push, or release that throttle - the results are instantaneous - similar to the response that throttle cables or linkage gave you, (before fly-by-wire took over).
    I know there is a lot more to experience and I will have to comment further later after I put some more miles on it.
    But folks - It was worth it. It IS worth it. Kudos to OVT!
    June 19 Edit:
    My first day driving after the initial install of the tune, (20 miles one way to work) yielded an increase of 2 solid MPG. My mileage read 21.1 MPG. I didn't baby it, but I did not need to use "help" from the ECT mode to "launch it" at traffic lights or to accelerate to establish my place in traffic either.
    This is an entirely new driving experience. And so far ... I really like it!
    Edit October 11, 2018
    I found myself using ECT mode more and more to have the added acceleration. Now days it is routine. I am still equally satisfied with the huge improvements experienced overall with v1.3 91 oct AT.
    Any negatives noticed are so minor and intermittently encountered that I cannot see trying to assess the rare conditions for consideration to post.
    I will say that the truck is so light in the ass end that any wet road take offs will loose traction immediately. Not sure if this is aggravated by extra torque realised from the tune or just the way it is. But if such a quick take off is required, I go to 4wd at the stop before take off.
    I am currious if OVT has any plans to release any more revision for this tune - perhaps addressing the trans module itself? There was talk of that, but I have heard no confirmation.
    Overall - this tune - even as is - should be a requirement for those who care and can afford it. It greatly improves the truck in overall performance and character.
    bshammer0, taco 16, dskakie and 6 others like this.
  11. Jun 25, 2018 at 1:34 PM
    #1171
    60calHowdaHunter
    60calHowdaHunter Well-Known Member
    Dave
    Arizona
    2016 Tacoma 4x4 offroad
    none
    I've been limping around with my gutless 2016 TRD 4x4 OR for 2 yrs now, I seriously really want this thing, but what a price tag, not to mention sounds like a pain to install, and I only have a mac. Is there anyone within 100 miles of Phoenix that would be willing to do this for me? Pay you $100 bucks, a 12 pack of good beer and a Cuban cigar!
  12. Jun 25, 2018 at 1:35 PM
    #1172
    redrelyt12
    redrelyt12 Well-Known Member
    Tyler
    2016 Tacoma TRD Sport DCLB
    Derped TRD Sport Grille BAK Revolver X2 Tonneau Cover mattgecko Waterproof LED Hood & Bed light kits Southern Style OffRoad Slimline Hybrid Front Bumper Baja Designs 20" S8 Light Bar Smittybilt X2O-10 Winch Blue 3/4" Shackles
    I'll just say if I had to choose a single mod for my truck, it'd be between this and the stereo. Definitely money very well spent
  13. Jun 25, 2018 at 2:26 PM
    #1173
    60calHowdaHunter
    Dave
    Arizona
    none
    Thanks, if you have done this, can you help verify exactly what i must do? The 900+ pages of the other thread fried what was left my already depleted brain cells.
    1 - first I buy the OVTune from https://www.ovtuned.com/products/toyota-tacoma-2grfks-calibration?variant=41531259916 (looks like it's $600)
    2. at the same time i need to buy the "openport 2.0 cable" package, I found one on Amazon https://www.amazon.com/Tactrix-Open...&qid=1529960900&sr=8-1&keywords=tactrix+cable. (only $42 bucks?)
    3. THEN, i need a Windows laptop (Macs wont work), and go thru the instruction on the other thread https://www.tacomaworld.com/threads/2016-toyota-tacoma-v6-ecu-tuning-alpha-release.495735/
    Sound correct? I can do this whole thing for $642 (if I has a Windows laptop)?
  14. Jun 25, 2018 at 2:31 PM
    #1174
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    Any potential buyers in the Denver Metro Area looking to save some $$ "start a conversation" with me. I did the install (dongle-less) and have the hardware. You will need to provide compatible computer and OVTune software. I will help you with process (Computer ID, ECU ID [requires OVTune License/Registration] and ECU Tune Flash [requires Tune download from OVTune].
    Daddy_Firebird and bshammer0 like this.
  15. Jun 25, 2018 at 3:22 PM
    #1175
    redrelyt12
    Tyler
    Sounds just about right
  16. Jun 25, 2018 at 7:29 PM
    #1176
    OVTune
    OVTune
    That adapter on Amazon looks like a very bad quality chinese clone
    DrRoboto likes this.
  17. Jun 26, 2018 at 9:49 AM
    #1177
    adamf18
    adamf18 Member
    Adam
    South Carolina
    2017 Super White SR5 XP
    TRD air intake filter, OVtune, 12volt remote start
    Just completed my OVtune upload with the 87 octane automatic trans SR5 version. If your looking for major changes to acceleration and shifting, your going to be disappointed. But what it did do was smooth out everything. No more sloppy over revving shifting or restricted acceleration. So far its it great change. Might have to change it to 91 octane and try that out too.
  18. Jun 26, 2018 at 10:19 AM
    #1178
    TFly
    TFly Well-Known Member
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    If my what is looking for changes? My what is going to be disappointed?
  19. Jun 26, 2018 at 2:57 PM
    #1179
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    I see what you did there.
    Anchovy, Tharris242 and bshammer0 like this.
  20. Jun 30, 2018 at 6:57 AM
    #1180
    60calHowdaHunter
    Dave
    Arizona
    none
