Oxygen Sensor
Discussion in 'Technical Chat' started by beanders, Apr 1, 2007.
  1. Apr 1, 2007 at 12:04 PM
    beanders
    beanders [OP] Member
    I just went past 80k miles. Should I replace both my oxygen sensors?
  2. Apr 1, 2007 at 1:38 PM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    I usually replace O2 sensors at 100,000 miles unless I get an error, but I inspect them every 20,000 miles.
    ...of course that is on all my older vehicles. My Tacoma shouldn't need that kind of maintenance for quite a while. ;)
  3. Apr 1, 2007 at 2:30 PM
    4x4Runner
    4x4Runner Proud 1.25%’er Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    I'd say leave them in until you notice decreased fuel mileage or throw a CEL
  4. Apr 1, 2007 at 6:44 PM
    AUDITECH
    AUDITECH Carolina Alliance: LAZY DIVISION
    charlotte nc
    07 double cab prerunner
    none
    As a tech unless your sensors are throwing codes i wouldnt worry about it. I have been known to have been wrong before. but until our O2 sensors throw codes they are good to go
  5. Apr 17, 2007 at 5:37 PM
    bowzerdoo77
    bowzerdoo77 U.S.M.C.
    North Ogden Utah
    1997 REG CAB 4x4
    None
    where are thw oxygen sensors located on an 04 v-6
  6. Apr 21, 2007 at 7:43 PM
    AUDITECH
    charlotte nc
    none
    locate the catalytic converter and there is going to be one in front and one behind it
  7. Apr 22, 2007 at 7:16 AM
    bowzerdoo77
    North Ogden Utah
    1997 REG CAB 4x4
    None
    thanks are they expensive and easy to change? or for that fact what goes wrong with them causing them to need to be changed?
  8. Apr 22, 2007 at 3:32 PM
    twoarezee
    twoarezee Well-Known Member
    esco, ca
    00 Dropped Mini
    rims,tires,3"/6" drop, 4x4 front end, 01 tails and corners, prerunner buckets,tenzo r steering wheel w/ momo hub, b&m shifterw/ jdm trd knob, alpine system, tint, 3 3/4" autometer tach, jardine cat back, k&n, debaged, hellwig rear sway bar, kyb monomax shocks, tundra v8 oil filter w/ mobil 1 in ever
    on the 04 there is only one o2 sensor after the cats, the sensor before the cats is an air/fuel sensor. they are easy to change and some what expensive.
  9. Apr 22, 2007 at 4:56 PM
    AUDITECH
    charlotte nc
    none
    Why they go bad ia hard to say sometimes the sensors in them go out. Or they get trash of some sort or the wires go bad could be a number of reasons. the are not to hard to change you can get an o2 sensor socket or on the cars i work on a 22mm open end wrench is the right size. the only hard part is routing the wires back close to orginal location so they dont get damaged.
  10. Apr 25, 2007 at 10:03 PM
    twoarezee
    esco, ca
    00 Dropped Mini
    toyota uses 2 studs to hold the sensors in. use oem sensors because they are plug and play so you dont need to worry about the wires because they will be in the sock location. www.urdusa.com has oem denso sensors.
  11. Apr 30, 2007 at 8:35 AM
    Steve762us
    Steve762us Well-Known Member
    An air fuel sensor? Sure it's not a pre-cat O2 sensor--that the ECU compares with the post-cat O2 sensor, to verify cat operation?
  12. Aug 30, 2009 at 1:00 PM
    wsv3424
    wsv3424 New Member
    dallas
    00 toy pre runner
    hho dry cell
    looks like its normal to have to change the o2 sensors whenever they show code [lean bank one ] is it?
    think this 2000 has afr and o2 but diagram doesnt show that but forum folks say they do, confused .
    guess I'll check for vac leaks ,clean egr ,map and reset ,try again right ?
    if this is the case will mileage improve considerably? used to get around 22 hiway ,now maybe 15 .
    :confused:
  13. Aug 30, 2009 at 7:37 PM
    98tacoma27
    Ben
    Not Beech Creek
    Welcome to TW!
    What exactly is the code?
    The sensor before the catalytic converter is an AFR (Air/Fuel Ratio) senor. The one after the catalytic converter is the O2 sensor. If the AFR is bad, it will definitely compromise you fuel mileage.
  14. Aug 30, 2009 at 7:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    On the first gens, the "Sensor 1" is an A/F sensor.
  15. Aug 31, 2009 at 9:06 AM
    spasur
    spasur Well-Known Member
    New Orleans
    02 PreRunner 4cyl
    how does that differ from an O2 sensor? It seems like they would both be doing the same thing, as a wideband O2 sensor is used to measure A/F...Is it just a new name for the same old thing?
  16. Aug 31, 2009 at 9:15 AM
    98tacoma27
    Ben
    Not Beech Creek
    It's actually a Californina specification. Non-Cali 4x4's got the O2 front and back. Cali trucks and 2wd have AFR and O2, according to the FSM anyway.
  17. Aug 31, 2009 at 9:27 AM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    My O2 sensor for a 2nd gen cost about $150 for one!!! :mad:
