OZBoost turbo group buy 2TR-FE and 3RZ
Discussion in 'Group Buys' started by SUMMIT556, Jun 8, 2015.
  1. Jul 7, 2016 at 9:47 PM
    #161
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    The one I want is nuts. 7163 calling my name. Spools like a little guy and flows more than a gtx3071. So much engine building I would need to do. Need to whore myself out.
  2. Jul 7, 2016 at 10:07 PM
    #162
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That'sthe one that I have been looking at for a twin setup. V-band and internal wastegate. Mmmm. Power and packaging.
  3. Jul 8, 2016 at 12:33 AM
    #163
    Desertrunner33
    Desertrunner33 Active Member
    Trenton
    2005 white 2tr-fe actual prerunner
    There isn't much that's stock anymore
    Ok got the video up. I apologize if you don't like it. But I think I did a good job showing everything that came with the kit as well as some additional info on the components. Here's the link:
    https://youtu.be/Xp9wWWZRZhc
    RedLantern, MadTaco461 and Torspd like this.
  4. Jul 8, 2016 at 5:07 AM
    #164
    camojared
    camojared Well-Known Member
    Jared
    SE Ohio
    07 4x4 SR5 2.7L 5spd
    Someone actually got a oz boost kit?? I was going to go that route till I found a deal on a supercharger!
    5 Lug Fury likes this.
  5. Jul 8, 2016 at 8:11 AM
    #165
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That plastic 90° elbow, looks like where the MAF sensor installs. @KirkRio , mentioned something in his build about having an issue with the MAF adapter.
    The long silicone hoses, are for intake charge "pipes".
    The fluid with the bubble, in the fuel pressure gauge, is normal. Those are shock resistant.
    Not sure why your kit came with an additional wastegate, when the turbo's turbine housing is internally wastegated already. That blue silicone hose goes from the compressor outlet, to the wastegate.
    Still need to watch the last few minutes of the video.
  6. Jul 8, 2016 at 8:32 AM
    #166
    Desertrunner33
    Trenton
    Ok thanks. I apologize if I said anything stupid in the video. I literally had just opened everything and didn't know what a lot of it was yet
  7. Jul 8, 2016 at 8:57 AM
    #167
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    No need to apologize. I can tell you're new to these things. Just like I used to be. :thumbsup:
  8. Jul 8, 2016 at 9:00 AM
    #168
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Just make sure to ask a lot of questions. Better to be called "stupid," than make a stupid expensive mistake, due to an under informed decision.
  9. Jul 8, 2016 at 9:06 AM
    #169
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Could you take a picture of your factory fuel pressure regulator? I am curious if it is the same as the one on the 1GR. If so, or similar, you can possibly hold off on purchasing a new one, for a little while.
  10. Jul 8, 2016 at 9:38 AM
    #170
    MadTaco461
    CA
    Kinda stock
    I like the header. Looks like plumbing pipe which holds up really well on dirt.
    I have really good luck with my afe dry flow in the desert.
    That aftermarket wastegate diaphragm is so you can lower boost more with the internal wastegate. The one on it is set to break open at 8-9psi. Little high to start with.
    TireFire likes this.
  11. Jul 8, 2016 at 11:23 AM
    #171
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Ohhh. That was the diaphragm. Duh. I was thinking it was an external wastegate.
  12. Jul 12, 2016 at 5:32 AM
    #172
    sawed off
    sawed off Well-Known Member
    Randy
    Idaho
    Prerunner 2wd 2.7 SR5
    Please please keep us posted on this install as I am serious about purchasing one of these. I was told the stock ecu could not keep up with fuel demands of turbo, but that's someones opinion.
  13. Jul 12, 2016 at 6:07 AM
    #173
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  14. Aug 25, 2017 at 12:57 PM
    #174
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
  15. Aug 25, 2017 at 1:07 PM
    #175
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    5 Lug Fury and TireFire[QUOTED] like this.
  16. Aug 25, 2017 at 1:09 PM
    #176
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    Someone buy this cheap shit so I have a reason to by it and blow up this shitty engine before I buy a new one.
  17. Aug 25, 2017 at 1:14 PM
    #177
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Cough cough diesel cough cough
    BabyTaco[QUOTED] likes this.
  18. Aug 31, 2017 at 6:46 PM
    #178
    camojared
    Jared
    SE Ohio
    cough cough 2jz-gte coming soon cough cough
    BabyTaco likes this.
  19. Oct 18, 2018 at 5:48 PM
    #179
    Massione27
    Massione27 Member
    Massimiliano
    Hilux 2.7 4x4 2008
    someone here with a 2tr with turbo? how are the performance I'm about to start within 2 weeks to install my turbo.
    Steves104x4 likes this.
  20. Oct 18, 2018 at 6:02 PM
    #180
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    No but I can hardly wait to see yours!
