P0016 code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Malcolm, Jul 10, 2019.
  1. Jul 10, 2019 at 8:45 PM
    Malcolm
    Malcolm [OP] New Member
    Ian
    2014 crew cab v6
    Need some advice. I have a 2014 crew cab with 75000KM/47000miles that is giving me the p0016 code. the truck is on a lease and is due this Sept. I have changed the vvt sensor with no luck. Is it worth going down the rabbit hole of end game possibly new timing chain and buying the truck out and keeping it or hand it back in. As far as I can remember regular oil changes done by Toyota servicing. Mechanically I understand why and how this happens but from an engineering quality stand point this does not jive with me. How can a vehicle with low mileage have this problem already? No off-roading, city and highway only. I drive above the speed limit but very little dragging off the light or hard braking.
  2. Jul 10, 2019 at 11:53 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I did a little reading on this issue.
    My understanding (which may be wrong) is that this code is set by the VVT.
    The VVT gets its data from the ECM.
    The ECM gets its data form the Crankshaft and Camshaft Sensors.
    Is it possible one of the those sensors are bad?
    Like I said, I could be wrong.
    Surely some one with more ( or correct) knowledge will come along and help you.
  3. Jul 11, 2019 at 4:44 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    I highly doubt that it's the timing chain. More likely a faulty CPS sensor or possibly faulty wiring to the sensor due to engine heat.
  4. Jul 11, 2019 at 8:03 AM
    jtaco11
    jtaco11 Well-Known Member
    Reset CEL before u turn in lease for 3rd gen
  5. Jul 11, 2019 at 9:37 AM
    Malcolm
    Ian
    2014 crew cab v6
    I am going to replace my crankshaft position sensor and then do a wire inspection. I'll see how it goes from there. Has anyone else had this problem in the later 2nd gen models? Why is this sensor intermittent as I reset it, it take a day or two to re appear. Should it not be constant?
    thanks for your help
    Ian
  6. Jul 11, 2019 at 11:22 AM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    Usually it takes a little bit of driving for the newly reset ECU to do its check/balances to find the issue again. You should d/c the battery again after CPS sensor replacement.
  7. Jul 11, 2019 at 11:39 AM
    TnShooter
    Deogee
    STOCK
    Numerous reasons it can take time to throw a MIL.
    Some checks are only run under certain criteria.
    Such as Engine RPM or Temperature ranges and time duration.
    Since our truck have variable timing, it could be that the code is not set until you reach a certain timing range and rpm range.
    I’m going to say in this situation, it would be normal for a time delay on setting.
    the MIL.
  8. Jul 11, 2019 at 11:52 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    How's the truck performing, unintended acceleration, lack of power, poor fuel economy?
  9. Jul 11, 2019 at 5:45 PM
    Malcolm
    Ian
    2014 crew cab v6
    I haven't notice anything unusual. No unwarranted acceleration or/ deceleration. Haven't noticed anything on fuel economy as I drive a summer toy this time of year and I don't track my fill ups by mileage and odometer.
  10. Jul 11, 2019 at 6:26 PM
    Extra Hard Taco
    R.J.
    Devil's Island
    So all its doing is throwing a code?
  11. Jul 11, 2019 at 7:54 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This should help:
    http://www.customtacos.com/tech.old...06toyrm/06toypdf/06rmsrc/rm2006ta/0050014.pdf
  12. Jul 13, 2019 at 1:38 PM
    dubktrd
    dubktrd Well-Known Member
    Wichita Kansas
    I had the same code on me 09 with 189k miles. Replace both oil control valve and the code went away.
  13. Apr 2, 2020 at 1:43 PM
    Luis1
    Luis1 Well-Known Member
    Alberta, CA
    2013 Tacoma DCLB TRD SPORT 4x4
    - OME 2.5 inch lift nitro charger with 886 coils in front and 2 inch lift OME nitro charger with heavy Dakar leaf pack - custom high clearance rear steel bumper with swing out made by Vertan Kustoms out of Alberta. Carts full size spare and 2 x 20L Jerry cans - Allpro Apex front bumper - Smittybilt 10000lbs winch w/ synthetic line - Dobinsons Snorkel - RA Motor sports roof rack and bed rack - 5 x 6inch Diode Dynamic light bars on roof - 2 x unknown brand ditch light pods - 5 x 285/70/17 BFG Ko2 - 5 x Black Rhino Stadium wheels - deep dish - 17x9.5 with - 18 offset - exhaust chop mod - rear seat delete - horrendous mpgs lol
    Reviving a bit of an old thread, but I am having a similar issue. I have had this code thrown for a while, tried cleaning and testing the vvt valves, no issues there, had an engine flush, diagnostics done by toyota etc etc. The truck turns over fine, runs fine no power surges no stalling no overly high or low idling no miss fires. When the code is off on its own, the engine starts and runs beautifully. When the code is on, the engine has a slight stumble then runs beautifully. I even had toyota open the valve covers and they said the timing was retarded a hair, litterly a hair and measure and remeasured and got the straightest line spossible to check and finally concluded that the timing was so close to bang on, that they didn't recommend retiming and are stumped on why it is throwing that code. Now the biggest thing here is a very intermittent code throw. The code, p0016 bank 1 sensor a, comes and goes as it pleases. I have watched it turn off and more importantly I have watched it turn on. It goes on for a few days, then turns off for about a week and back and forth. I am going to replace the sensor on bank 1 and see if that clears it. I am stumped at this point. Anyone have any similar issues?
    Edit: also my mpg tanks hard when the light is on
  14. Apr 2, 2020 at 4:34 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Have you checked / cleaned or replaced the VVT Oil Control Valve Filters?
  15. Apr 2, 2020 at 5:31 PM
    Luis1
    Alberta, CA
    Yessir already done, should have put that. Thanks though. Hopefully changing the sensor does the trick
  16. Apr 3, 2020 at 7:45 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Good luck!
  17. Nov 7, 2023 at 4:50 PM
    blk1996
    blk1996 New Member
    2014 Black Tacoma Limited (4.0l)
    Luis1 it’s been a few years curious if the code ultimately went away?
