P0402 code
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kelly Girl, Apr 19, 2012.
  1. Apr 19, 2012 at 4:34 PM
    Kelly Girl
    Kelly Girl [OP] New Member
    Kelly
    Indiana
    2001 PreRunner SR5
    I have a 2001 Tacoma PreRunner 3.4L 6 cycl engine. Do you think it is the EGR valve that needs replaced? I have read some threads of the 2.7L engine but none on the 3.4L but none on my engine. Truck runs great, the check engine light just keeps coming on after it is cleared. Thanks!
  2. Apr 19, 2012 at 5:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Replace the EGR. Also check the vacuum lines going to it.
  3. Apr 19, 2012 at 9:03 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I thought the 3.4L V6 didn't have an EGR? :confused:
  4. Apr 19, 2012 at 9:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    DOH! I was thinking the 2.7. Correct, the 3.4 has no EGR.
  5. Apr 20, 2012 at 9:42 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Is it possible you transposed 2 digits?
    Maybe you have a P0420.
  6. Apr 20, 2012 at 8:37 PM
    Norton
    Doesn't P0402 point to a possible exhaust leak, O2 sensor defect, or catalyst problem?
  7. Apr 21, 2012 at 5:24 AM
    Kelly Girl
    Kelly
    Indiana
    2001 PreRunner SR5
    Rick, you may be right, I may have written it down wrong. So how do I correct the P0402 code?
  8. Apr 21, 2012 at 5:47 AM
    tc98tacoma
    tc98tacoma Well-Known Member
    Nik
    San Antonio, Texas
    98tacoma4x4
    3inch toytec coils 5100's, aal(soon to be replaced), 33/12.5 km2s, + a money hole...
    It has to do with the catalytic converters mine throws the same code cause I removed them, so I'm sure yours need to be replaced or something
  9. Apr 21, 2012 at 7:18 AM
    tan4x4
    Rick
    Folsom, CA
    Assuming you have a P0420 (not P0402) the problem is related to the converter.
    You either have an exhaust leak, bad sensor or bad converter. There should be 2 sensors, before and after the converter.
    Visually check for exhaust leak. If there is one, there would likely be black soot in that area.
    If that is OK, then check the sensors. You can do this by disconnecting the wiring plug from each one, and measuring to see if the resistance is in the correct range for each one (you'll need the FSM to locate the proper terminals). If not in range, replace that sensor.
    The sensor can be bad, even if the resistance check passes, but you need a special tools to verify it. The post-converter sensor is heated, so its remotely possible that the ECM is not sending power due to broken wire.
    If they both check out, then likely the converter needs to be replaced.
    No experience here, just reading this stuff from the 2003 FSM for 3.4 motor.
  10. May 8, 2012 at 7:31 PM
    SteveNC
    SteveNC Well-Known Member
    Charlotte, NC
    01 Tacoma 4x4 2.7l
    My wife's 2001 Tacoma 2.7l 4x4 has been throwing that P0420 code every few days for several months. When it first started I went under the truck and checked for leaks, but none found other than a pinhole after the last o2 sensor where the pipe was welded to the inlet of the muffler. Since that was after the O2 sensor and the truck has almost 100k I figured one of the catalytic converters was bad. About a week ago while I was driving the exhaust got really loud after I drove it hard. Turns out the bolts for the last O2 sensor had rusted or fallen out and the sensor came out. It must have been a little loose all those months. I cleaned out the thread, installed a new gasket and the check engine light hasn't come back in over two weeks now. Simple fix and didn't cost a thing to repair.
  11. May 12, 2012 at 1:22 PM
    enisi
    enisi New Member
    01 Emerald Green Crew Cab
    Had the same code issue. Life long friend and mechanic said it was the cats. Would not mess with the running of the truck just have to look at the light. After a few months this drove me nuts. Had another Diag. replaced both cats and all is well. Truck ran fine the entire time 20mpg in town driving. O2 sensors tested out fine. Would have rather bought new wheels tho.
