p0420 code
Discussion in 'Performance and Tuning' started by tacoma20021964, Jan 27, 2010.
  1. Jan 27, 2010 at 9:36 AM
    tacoma20021964
    tacoma20021964 [OP] New Member
    2002 tacoma trd
    Hi, I had the engine light popped up awhile ago and coded it and it said rear o2 sensor.... months and gone by and finnally had to change it because of state inspection...changed 02...then p0420 is now the new code..so I changed the cat. now...my question is..I cleared the code,,but after 11 miles it came back? i was told you have to drive it at least 100 miles for the computer to reset...then everything will be good? Any help ?
    thank you...
  2. Jan 27, 2010 at 9:44 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Check for exhaust leaks.
  3. Jan 27, 2010 at 9:46 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    or 02 sensor on bank 1, from what Google is telling me.
  4. Jan 27, 2010 at 9:47 AM
    98tacoma27
    Ben
    Not Beech Creek
    X2 That is a common cause of the code also.
  5. Jan 28, 2010 at 9:27 AM
    tacoma20021964
    2002 tacoma trd
    I ran a scan..and it said both o2 sensors are supported..After changeing the rear o2 and the cat. how long miles or (cycles) do you have to drive before the light goes off... I double checked and there are no exhust leaks..that I can feel..or here..
    What is X2 ? i don't know that one Thanks
  6. Jan 28, 2010 at 9:31 AM
    98tacoma27
    Ben
    Not Beech Creek
    Hmmm...........it doesn't say in the FSM. It's a 2 trip logic that will trigger it how ever. You could always disconnect the NEG BAT side for a few minutes and see if it comes back.
  7. Jan 28, 2010 at 4:24 PM
    tacoma20021964
    2002 tacoma trd
    I did disconnect the battery..and the light came back on in about 12 miles...ya,know..I change the rear cat... maybe it is the front one?? do you know how to tell which one? thanks
