p043e p043f p2401 p2402 p2419 after changing manifolds/cats
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nad, Jul 23, 2014.
  1. Jul 23, 2014 at 8:53 AM
    nad
    nad [OP] mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    I just replaced my manifolds to fix p0420 and p0430 check engine lights that I had, now I'm getting p043e p043f p2401 p2402 p2491. From reading this is an issue with the charcoal canister. But I'm going to guess in my situation I didn't hook the vacuum lines up correcrly. I am using the torque app on my phone to monitor test results and it appears that my intake manifold has negative pressure.
    Does anyone know what I could have done wrong?
    Also the new cats do have a small leak in the manifold gaskets, would this have anything to do with it?
    I have attached screenshots
  2. Jul 23, 2014 at 12:06 PM
    nad
    Jordan
    Canada
    I think I figured it out, the valve that causes the toyota tick wasnt making any noise, I disconnected a vacuum line from it and there was no suction. I then started playing around with the wires going to it, unclipping and reclipping in the harness and it started ticking again, the suction started back up again as well. I reset my check engine lights and I'm pretty sure they wont come back on.
  3. Jan 13, 2015 at 2:09 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    I have the same 5 codes pop up. Can you point out in a photo what valve and vaccum line you're referring to?
  4. Jan 13, 2015 at 2:14 PM
    nad
    Jordan
    Canada
  5. Jan 13, 2015 at 2:50 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
