P11EE00 P160500 codes
Discussion in 'New Members' started by Tacomatt83, Oct 12, 2022.
  1. Oct 12, 2022 at 2:01 PM
    Tacomatt83
    Tacomatt83 [OP] Member
    2018 Tacoma SR5 V6
    Had check engine light came on around 86,000 miles took it to a local shop and they said it was a misfire in cylinder 3 so I bought a new coil pack and replaced the spark plug and coil the light went off for a few days but came back so I took it to my local dealer this is what they determined.
    CHECK ENGINE LIGHT ~|~CUSTOMER STATES CHECK ENGINE LIGHT ON AUTO SHOP SAID MISFIRE IN CYLINDER 3... CHECK AND ADVISED ~|~P11EE00- CYLINDER 3 AIR-FUEL RATIO IMBALANCE (PORT), P160500 ROUGH IDLING. VERIFIED CONCERN, TEST DROVE A OBSERVED MISFIRE MONITORS, CYLINDER 3 MISFIRED 2-3 TIMES. SWAPPED IGNITION COIL 3 AND 5 AND TEST DROVE AGAIN AND DID NOT MISFIRE. ALSO PERFORMED STAL ~|~PERFORMED INJECTOR CLEAN SERVICE, CLEARED DTCS AND TEST DROVE. VEHICLE RAN BETTER, DID NOT MISFIRE NOR DID ANY CODES APPEAR.
  2. Oct 12, 2022 at 2:03 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    Increasingly talked about problem as more and more of them pop up. The typical fix is installing another cylinder head as a replacement along with new valves on the affected cylinder.
    I’m going to guess the issue comes back soon again. So far these codes have a 100% rate of needing a new head. None of the other “possible causes” (coil pack, spark plug, injector, yada yada) have been the fix in any of the threads I’ve seen.
    pdeinc, Ozark_RegCab and Steves104x4 like this.
  3. Oct 12, 2022 at 2:06 PM
    Tacomatt83
    2018 Tacoma SR5 V6
    Guess I will find out in a few more days if the light comes back on. The thing is the truck seemed to be running fine I couldn’t feel it skipping I do have a lifetime power train warranty from the dealer.
    pdeinc likes this.
  4. Oct 12, 2022 at 5:10 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    buckhuntin-tacoma likes this.
  5. Oct 12, 2022 at 5:14 PM
    Tacomatt83
    2018 Tacoma SR5 V6
    so what is the actual problem is the head or valve not sealing during combustion?
  6. Oct 12, 2022 at 5:16 PM
    BLtheP
    Plano, TX
    Nobody really knows.
  7. Oct 12, 2022 at 5:23 PM
    Skytek
    Skytek Well-Known Member
    Still a mystery it seems. There’s a recent thread about this with mention of the injector getting dirty producing a lean mixture and burning the valve. Sounds more logical to me than the “manufacturing defect” theory that’s wildly popular as it doesn’t seem to be happening to the Lexus and others and I’d expect a defect to show up a lot earlier, but who knows.
  8. Oct 12, 2022 at 5:50 PM
    Tacomatt83
    2018 Tacoma SR5 V6
    I had the 2012 Pilot with the 3.5 v6 and they had a issue with the cylinder rings shrinking and allowing oil to bypass and cause fouling of the plugs if I remember right I think it was also cylinder 3 they did a recall on those.
  9. Oct 12, 2022 at 8:41 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  10. Oct 14, 2022 at 6:50 AM
    Tacomatt83
    2018 Tacoma SR5 V6
  11. Nov 20, 2022 at 6:58 AM
    Tacomatt83
    2018 Tacoma SR5 V6
    Update
    I hit 91,000 miles and the check engine light came back on I’m going to take it back into the shop on Monday11/21/2022
  12. Nov 30, 2022 at 3:27 AM
    Tacomatt83
    2018 Tacoma SR5 V6
    Technician said it still had a fuel air ratio imbalance. I asked them to check the cylinder and exhaust valve but they didn’t they want me to replace the injector. They cleared the code but it came back on and now it’s off again. Truck is running smooth. I’ve ordered a bore camera so that I can inspect the cylinder myself I’ll give an update when that happens.
    https://www.amazon.com/gp/aw/d/B094XGX6GQ?ref=ppx_pt2_mob_b_prod_image
  13. Jan 24, 2023 at 9:59 AM
    Tacomatt83
    2018 Tacoma SR5 V6
    Just got the compression test done looks like cylinder 3 is only at 130 supposed to bearound 190
  14. Jan 26, 2023 at 11:37 AM
    Tacomatt83
    2018 Tacoma SR5 V6
    Just got the quote from my Toyota dealer today new cylinder 3 around $7000
  15. Jan 26, 2023 at 5:34 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Thanks for the update. Sucks these are happening more frequently. Too often for me to ever want a 3.5L Tacoma again.
  16. Jan 30, 2023 at 5:35 AM
    pdeinc
    pdeinc Well-Known Member
    Ken
    2019 TRD 4x4 Sport
    ARE Z topper, Roadmaster baseplate, Remco DS disconnect
    I got the dirty injector explanation too, both on this forum and from the dealer but I think that's a false flag. These engines utilize what is known as the Atkinson cycle when means the intake valve is partially open during combustion and that makes the injector look dirty leading mechanics to think it's the cause of a burnt valve. The information I got from the regional rep is that Toyota has changed the machining of the head to eliminate the problem. I don't have a date for when the change has been implemented other than that it's fairly recent but we won't know if that does in fact correct the problem until newer models don't experience it nor do those with more recent head replacements.
    BLtheP likes this.
  17. Jan 30, 2023 at 11:36 AM
    Tacomatt83
    2018 Tacoma SR5 V6
    I’m at 92,000 miles now and I’ve opened a case with Toyota to see if they will cover the work I’m hopeful they will if not I’m just going to trade it in.
  18. Apr 1, 2023 at 7:22 AM
    RTD
    RTD Well-Known Member
    Taxachusetts
